Securing a motocross, show me how its done.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RN923, Apr 27, 2019.
  1. Jun 10, 2019 at 1:04 PM
    #61
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    I just use the stock hooks in the side of the bed :notsure:
    Alexely999 likes this.
  2. Jun 10, 2019 at 3:09 PM
    #62
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Trailers are easy-mode.
  3. Jun 10, 2019 at 3:32 PM
    #63
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Loves me some WRR
    What a great bike
  4. Jun 10, 2019 at 4:13 PM
    #64
    RN923
    RN923 [OP] Well-Known Member
    Quebec Canada
    08 Tacoma TRD Off Road 6-MT
    The stock hooks don’t seem solid at all. 1 of the roads up to the track is nasty too. Highway speeds and with oncoming traffic you have to decide between smoking a pothole that makes you cringe or taking the dirt slightly better shoulder. I don’t trust the stock hooks for 2 hrs of that each way.
  5. Jun 10, 2019 at 4:16 PM
    #65
    RN923
    Quebec Canada
    I build a nice trailer just for hauling bikes but when I moved I didn’t have the room to store it anymore.
    Deck was finished with 2x6’s
    PoweredBySoy[QUOTED] likes this.
  6. Jun 10, 2019 at 4:49 PM
    #66
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The stock big silver loops at the front of the bed on the vertical walls is what i use for all my bikes... multiple bikes in the bed over nasty terrain for long periods never an issue. I always do a 3rd strap down from the outside handlebar to the middle D rings i put in the bed, this makes it so bikes dont move around hardly at all... then a ratchet strap holding the rear tire down from the stock D rings at the back of the bed. Litterally been blasting dirt roads in the truck, truck in the air over jumps dirtbike in the back, stuff not moving around haha.
  7. Jun 10, 2019 at 4:53 PM
    #67
    RN923
    Quebec Canada
    Mine didn’t come with those silver loops in the box, hence adding the sprinter van D-rings to the box bolts.
  8. Jun 10, 2019 at 5:26 PM
    #68
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I dont even tie down the rear tire, but yeah they work great. Ive used them for 2 bikes and 10+ hour roadtrips. Through twisties as well
    Ah that explains it. Definitely would not recommend tying anything into the bed rails themselves
  9. Jun 10, 2019 at 11:07 PM
    #69
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    I agree with you on that for sure. Ive tied a piece of rope to the cleats on the rail and pulled. The whole thing flexes not to mention I could swear the cleat itself said max 50 lbs. Or something like that. Ive used the front square silver ones and they are solid. Same test...trucks tires off the ground at a decent speed over rough terrain, lol. Its fun except for the hand fatigue after a while. But the strapless idea makes it super quick and easy to bug out for a trip. Its noisy as hell if the bike isnt back there and you leave em attached though
  10. Jun 10, 2019 at 11:45 PM
    #70
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    ATH product above looks good, or I have a CCR Sport bed buddy.
    Wheel chocks of some kind definitely help with keeping the wheel straight when tightening the bike down, also also slipping during transport.
    And add some D rings to the bed bolts, or metal loops to the bed rails.
    I would not use the oem plastic sliding tie down cleats as anchor points for even a light dirt bike.
  11. Jun 11, 2019 at 6:53 AM
    #71
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    A buddy and I built a trailer hitch carrier. It works well but it is all steel and heavy as hell. They make lighter units that you can pick up for around $150 last I saw.
  12. Jun 11, 2019 at 7:02 AM
    #72
    Sacrifice
    KS
    DCSB OR 4X4 LT
    i tried an aluminum one. wasnt happy with how the truck handled with the weight so far behind the axle. plus loading/unloading honestly wasnt any easier imo
  13. Jun 11, 2019 at 7:40 AM
    #73
    nd4spdbh
    SoCal
    Ah yes, I think the big beef silver loops were added on 2012+
    Yeah the bed rails, uh, leave a lil to be desired. The ONLY time i use them for any moto hauling, is for the 3rd strap that i go down from outside handle bar to mid bike if im hauling 2 bikes in the bed and cant get to my D rings mid bed bolt.
    I have a hitch mount carrier, and its probably been used by friends more than I have for those same reasons, its more of a pain in the ass to load on a hitch mount than just throwing the bike in the bed, that stated, it works out great when I have a bunch-o camping gear and need all the space my lil shortbed can offer and want to take my dirtbike somewhere.
  14. Jun 11, 2019 at 7:54 AM
    #74
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Yeah it would work nice for camping. I want to keep as much departure angle for those moments (if theres any wheeling included) so i plan to still throw it in the bed. Ive gone back to basics for camping gear as well so no bulky items other than the fridge or cooler.
  15. Jun 11, 2019 at 11:49 AM
    #75
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Don’t waste your money. Fork seals aren’t blown from compressing your forks; that’s a myth. They’re blown from the inner tube getting a knick from a rock or whatever on the track. Those tiny knicks are sharp and they cut the seal when the fork compresses while riding. That’s why if you DIY replace your fork seals, a lot of times they’ll be blown again a short time later if you don’t file down that knick.
    Compressing your forks while transporting your bike does absolutely no harm to them. You also don’t have to put that much pressure on them. Most people go way too tight on the straps.
    Even if you don’t believe me, you still shouldn’t waste your money. You can make your own support out of scrap wood in two seconds. Then you’ll just be wasting your time and not your money lol.
    Sterling_vH111 likes this.
  16. Jun 11, 2019 at 12:03 PM
    #76
    Sterling_vH111
    Sterling
    socal
    Agreed.
    Straps in the proper angle and placement on the bike hold them down just fine with relatively low pressure.
    Tried only if those supports a while ago, and it just fell out... due to the suspensions upward force. Maybe would work if using ratcheting tie downs, which aren’t needed really for Moto bikes.
    I release my bikes if they will be sitting overnight or longer though, mostly for peace of mind.
  17. Jun 11, 2019 at 12:04 PM
    #77
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Ive never used one of those either. Never will. Havent blown out a shock once. But i have seen those fork supoorts fall out and then you have a loose bike essentially.
  18. Jun 11, 2019 at 12:08 PM
    #78
    rmorse
    Bobby
    Bowie, MD
    Yea I loosen mine overnight too even though I know it would be fine if I left it tight lol
  19. Jun 11, 2019 at 12:08 PM
    #79
    rmorse
    Bobby
    Bowie, MD
    Yuuup I’ve seen them fall too.
  20. Jun 11, 2019 at 12:11 PM
    #80
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I like the ratchet style. Dont like the idea of possibly coming loose. I use ktm straps that have the built in soft loop.
