Securing bed mat
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redneck_Toyota, Feb 23, 2023.
  1. Feb 23, 2023 at 3:35 AM
    Redneck_Toyota
    Redneck_Toyota [OP] Well-Known Member
    2019 DCOR
    Anyone have some ideas on securing the bed mat in the bed? Learned the hard way that the air blowers at my local touch free car wash do a fine job of making that thing airborne and gone. My only thought is self tapping screws with a washer. Thought someone would have a more elegant solution. Tired of rolling that thing up a shoving it in the back seat every time I wash it.
    Search turned up nothing.
    Phaaronite likes this.
  2. Feb 23, 2023 at 3:45 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
  3. Feb 23, 2023 at 3:46 AM
    Toolndie7
    Toolndie7 Well-Known Member
    2019 Sport DCSB Cavalry Blue
    Is this a factory bed mat? Would not have guessed that would be a problem given how heavy they are.
    RIX TUX, MadKatt, Chew and 6 others like this.
  4. Feb 23, 2023 at 3:50 AM
    Redneck_Toyota
    2019 DCOR
    Yes, OEM bed mat. Maybe the blowers at my car wash are unusually strong, but it’s unlikely.
    Toolndie7[QUOTED] likes this.
  5. Feb 23, 2023 at 3:51 AM
    Redneck_Toyota
    2019 DCOR
  6. Feb 23, 2023 at 5:25 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
  7. Feb 23, 2023 at 5:34 AM
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    Totally this.........From toting it just once on my DCLB, never again. Thing weighs a freakin ton.
    I know its not the answer you were looking for, but this is one solution to the issue that Ive found works a treat:
  8. Feb 23, 2023 at 5:55 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    A ton, really? :D
  9. Feb 23, 2023 at 6:04 AM
    Knoxtaco20
    Knoxtaco20 Well-Known Member
    Knoxville
    2022 Tacoma DCSB 4x4
    My OEM bed mat also disappeared after a car wash about a month ago. When I realized it and went back they said it has been happening a lot and they actually had 2 of them there. Definitely not something I expected but I guess air pressure over a large surface can do crazy things.
  10. Feb 23, 2023 at 6:41 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Stay away from car wash's.
    HiBillyMaysHere and BC Hunter like this.
  11. Feb 23, 2023 at 6:52 AM
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    Load bar? Dual purpose, even. Just put it in the middle of the wheel wells down low during washes. Hide it up front when not needed...
    Chew likes this.
  12. Feb 23, 2023 at 6:57 AM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Get a tube of sand and toss it in the bed when you go through the wash.
    They are very cheap, $5, and you get the added bonus of extra winter traction (if you live in an area that snows)
    Redneck_Toyota[OP] likes this.
  13. Feb 23, 2023 at 7:11 AM
    MTBTACORN
    MTBTACORN Well-Known Member
    Ontario, Canada
    23 Tacoma TRD Pro 21 Sportster S
    Did this on my old 2nd Gen and works like a charm. Also acts as a theft deterrent. I should do it again on my 3rd Gen.
  14. Feb 23, 2023 at 7:50 AM
    Phaaronite
    Phaaronite Active Member
    Quinton
    2022 Tacoma TRD Sport - Magnetic Gray
    I just had this same experience yesterday! Thanks for posting so I don't have to!
  15. Feb 23, 2023 at 9:12 AM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    I don't have a bed mat. I was actually going to buy the OEM one soon. Would velcro at the 4 corners hold it down? That stuff is pretty amazing. It's easy to apply or remove, and no tapping of holes.
    Just curious if anyone has tried the velcro industrial grade tape.
  16. Feb 23, 2023 at 9:21 AM
    JdevTac
    Josh
    MD/GA
    2nd gen
    I doubt the adhesive would hold against the rubber very, especially if the truck bed sees sun, unless supplemented with epoxy or something strong like that. Drilling out the hole in the bed isn’t that big a deal. The hole itself (at least in 2nd gens) is already there as a drain hole.
    G2.M6[QUOTED] likes this.
  17. Feb 23, 2023 at 1:13 PM
    2022mgmtrdsport
    2022mgmtrdsport Well-Known Member
    22 TRD SPORT 4X4 DC/LB
    5% tint all around, Raptor grill lights, ProComp 17x8.5 Rockwell wheels, Maxxis 265 / 65 / 17 AT tires, TRD skid plate
    I had the same issue, I just ran bungie cords in an "X" pattern into the "D" hooks in the bed. No issues after that.
    Chew, JHP, RIX TUX and 2 others like this.
  18. Feb 23, 2023 at 2:35 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    Question: Does using a load bar create the stress that bed stiffeners are supposed to protect against?
  19. Feb 23, 2023 at 2:48 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    My mat doesn't move either. But I use cargo this bar too for other things, and it too hides nicely up front under the mat.:thumbsup:
  20. Feb 23, 2023 at 3:05 PM
    Cushmaat
    SE AZ
    If you really crank it down, it would. Mine has rubber feet, so a little tension goes a long way. And I usually try to place it strategically in the spaces where the bed has indents (i.e. the 2x4 slots, etc).
