security and remote start recomendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crazyengineer, Mar 2, 2011.
  1. Mar 2, 2011 at 5:42 AM
    crazyengineer
    crazyengineer [OP] Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    I am looking at getting a remote start and alarm system for my 05 tacoma, does anyone else have one?
    if so, what are good brands and/or models
    also, how much should i expect to pay with a clutch bypass
    (i drive a clutch and have had it priced before, it was like an extra 30 dollars, and the car wouldnt shut off unless it was in neutral for safety reasons)
  2. Mar 2, 2011 at 7:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have keyless entry? Have you thought about having a Toyota factory alarm put in?
    Many years ago, I had an alarm system on another car and although it wasn't the most expensive setup and not as advanced as todays...but after a few years it started acting up, getting funky, arming itself, going off by itself... lots of headaches, leaving me sit.... I'll personally never get an aftermarket alarm again. I'd go with factory stuff just because its designed to work with the vehicle/programming.
  3. Mar 2, 2011 at 8:48 AM
    crazyengineer
    patrick
    Bristol, TN
    i do have keyless entry, and i have an audio shop that i use, they can install both for me, since i dont like dealers (highway robbery in my opinion)
    i was thinking about getting a combo so that i had both on one remote and one key fob
  4. Mar 2, 2011 at 8:52 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Python or Viper have good reputations although not your only options. I'd ask your local shop for a recommendation especially if you have a relationship with them already.
  5. Mar 2, 2011 at 9:26 AM
    DevL
    DevL Well-Known Member
    I have and recommend a viper 5901. I do not recommend anything factory I also recommend adding a glass break sensor as a minimum.
  6. Mar 2, 2011 at 10:17 AM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    i LOVEE my python 990. Put it in when i used to work it an audio shop, plus if you have the rear slider window the unit accepts mag switches as well. So if it gets pried open the alarm activates. I vote PYTHON for your needs. :D
  7. Mar 2, 2011 at 10:20 AM
    Kyle
    Kyle Mckeown343
    Arcata
    05 PreRunner
    3 inch toytec, magnaflow exhaust, KNN intake, URD MAF, HID 55 watt, Hella 500 HID, Smoked tail lights LED running lights, Pioneer deck with 8 inch infinity sub, Focal 165VB and 165CVX with JL 320/4, Tinted all around 3%, Tinted interior lights.
    Same thing here except I have the 991. I would not get anything but Python. The rear window sensor is so bad ass!!
  8. Mar 2, 2011 at 10:27 AM
    DevL
    The python 991 and viper 5901 are the exact same alarm.
  9. Mar 2, 2011 at 11:21 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    Have an autopage RS730 w/remote start. $350 installed.
  10. Mar 2, 2011 at 1:27 PM
    snowgod06
    Rob
    06 Access Cab
    Their is no need for a back up battery, most systems have hood pins to install so even if the hood is popped the alarm will activate.
  11. Mar 2, 2011 at 1:46 PM
    gregp
    gregp Well-Known Member
    MA
    '13 V-6 4x4
    I had my dealer install a Compu Star system in my new '11 Taco 5 speed for $200 (negotiated price) when I bought it. It works great!
  12. Mar 2, 2011 at 6:10 PM
    DevL
    You can cut the battery without popping the hood. I have a glass break sensor, pin switches on the hood and tail gate, a back up battery, and a dual zone motion detector with a defeat switch.
    Then again I'm paranoid someone is going to steal my stereo.
  13. Mar 2, 2011 at 6:12 PM
    snowgod06
    Rob
    06 Access Cab
    how can you cut the power cable for the battery with the hood closed? just curious because if its easily accessible Im going to shift the wire around.
  14. Mar 2, 2011 at 6:57 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    X2 i love it. Two way system so I know whats going on even when I am out of earshot.
  15. Mar 2, 2011 at 7:08 PM
    Erll
    Erll Well-Known Member
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    When you do get one, consider the Smart Start add on. It is some James Bond stuff. Lets you start, stop and lock and unlock from your smart phone. I have had it for about a month, and use it more than I thought I would.
  16. Mar 7, 2011 at 5:12 PM
    DevL
    I did not get it because it lacks 2 way functionality... you dont know if your alarm goes off via phone, you dont know if your car actually started or not etc. Its just a one way system, does not replace your remote, and costs $300. When it can replace my remote I will get one... perhaps in a few years. Thus, I dont reccomend it.
  17. Mar 7, 2011 at 5:46 PM
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    It does have 2 way communications, but only for lock, unlock and start / stop. You are correct about the 2 way for the alarm part. I believe that you can get the add on module for most newer viper / aerostart systems for around $100. I have enjoyed my system. Hopefully they will continue to expand the communications between phone and vehicle in the future.
  18. Mar 7, 2011 at 5:57 PM
    MikeD20
    MikeD20 Active Member
    Azusa
    2011 4X4 TRD Sport DC LB debadged Tacoma
    TRD CAI, TRD oil cap, TRD radiator cap, TRD catback exhaust, 8K HID headlights, 3K Yellow HID fog lights, 2.5 in Velocity front leveling kit, 1.5 in Velocity Rear leveling kit, TRD Trail Team Edition wheels, Westin Ultimate Bull Bar, Weather Tech floor liners, limo tint all around, Viper 5901 w/remote start, Pioneer 4300DVD HU, ipod adapter, XM Radio, Image Dynamics XS65, Image Dynamics CTX65, Image Dynamics IDQ10V3, JL 500/1 and JL 300/4 amps, Mr,Marv custom sub enclosure and amp rack, RAAMMAT and ensolite sound deadening.
    I have the Viper 5901 on my 2011. You cant go wrong with either Viper, Python, or Clifford as they are all manufactured be DEI. Just some of the features and some cosmetic differences on the the remotes.
  19. Mar 7, 2011 at 6:37 PM
    DevL
    So it tells you how many minutes your truck will run for till it stops and let you know when it times out on the remote start? It tells you if it failed during the remote start sequence? If you lock with the phone and ulock with the remote it indicates this on the phone?
