Security Light Flashing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Celtic Bob, Apr 10, 2010.
  1. Apr 10, 2010 at 2:55 AM
    Celtic Bob
    Celtic Bob [OP] Well-Known Member
    I just finished installing an amp and head unit in my new 2010 Tacoma. I have now noticed that the dash security light (by the clock) keeps flashing untill the key is in the ignition. I never noticed this before. Did I mess something up or is this normal on the 2010's?
    Thanks
    b.
  2. Apr 10, 2010 at 3:20 AM
    Celtic Bob
    Thanks
    It goes out once the key is in but back on once it is taken out. I just never noticed it before on this one or my previous 06
  3. Apr 10, 2010 at 4:17 AM
    Celtic Bob
    all is good, adios
  4. Apr 10, 2010 at 11:01 AM
    kenstar
    kenstar Get a Lil Mud on the Tares
    Ken
    Wrenching in the garage.
    10 4x4 TRD OR
    Pop 'n' Lock, EGR In-Chan, Bakflip G2, 6112, 5160, Dakar Set. Redline hood struts. WildPeak At3. TRD Pro Wheels. Apex Fab Fog lights; Other shit I can't remember.
    rofl. I noticed this the first night I brought my car home. My dad noticed it. After thumbing through the manual found my answer.
  5. Apr 10, 2010 at 11:37 AM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    Yep, just the electronic immobilizer. Prevents the truck from starting when a key without the proper chip is used. It's standard (by law) on Canadian vehicles, and optional on American vehicles. If you have a key made at the local hardware store, you'll be able to use it to open the doors, but if you try to start the engine with it, the light will stay flashing, and the engine will won't start.
  6. Sep 30, 2012 at 6:10 PM
    moelov
    moelov Well-Known Member
    USA
    09 PreRunner SR5 Lifted
    Removed the Mud Flaps, Rock Deflectors and Head Rest. Limo Tint, I had 3" Toytec Lift, Procomp Nitrogen ES6000 shocks and Struts. AllPro UCA, AFE Pro Dry drop in filter, WeatherTecs. Now I have LR UCA's, Maxtrac Spindles, Eibach's, 5100's up front, Expos, 5160 for the rear, U Bolt Flip Kit, and Extended Brake lines.
    Ok so I'm having this problem now. Last night I sat in the truck finishing a phone call.
    This evening I got into the truck and before I put the key in I noticed the light flashing.
    I turned the key started the truck then turned it off, pulled the key out and the security indicator came on.
    I know forsure in the past the light only comes on when I lock the truck.
    What could be causing this?
  7. Oct 1, 2012 at 5:54 AM
    moelov
    USA
    Weird, I just don't ever remember seeing the security light flashing when I'm sitting in the truck on a call while the keys are out of the ignition.
    Anyone else?
  8. Oct 1, 2012 at 7:46 AM
    photonashville
    photonashville Well-Known Member
    2006 Silver 4x4 long bed with Leer
    That flashing light is not an issue. My wife's 2000 4Runner does it and so does my 2006 Tacoma. It's just part of the vehicle security. No one reads owner manuals anymore.
  9. Oct 1, 2012 at 3:42 PM
    moelov
    USA
    No, I searched before before starting a new thread.
    And yes I looked it up. Page 76 in the 2009 Owners Manual.
    Well I guess It never really bothered me before. I swear I don't remember.
    Thanks.
  10. Oct 1, 2012 at 3:57 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    This should explain everything...then again maybe not. :rofl:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/64376-theres-car-key-blinking.html
