Security System
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VicNic3, Jun 1, 2018.
  1. Jun 1, 2018 at 9:36 AM
    VicNic3
    VicNic3 [OP] Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
    Has anybody installed the alarm/glass breakage system in their Taco?
    Toyota Part Number: PT398-35160
    Designed to integrate with the keyless entry system—no need for an additional remote
    Automatic rearming and relocking, door-ajar warning, interior light activation, panic alarm, rolling code technology and disabling of the starter
    Glass breakage sensor(GBS)includes a highly sensitive microphone that detects the sound -frequency of an object striking on glass or glass breakage
    Warn-away alarm is triggered if an object strikes a window
    Alarm Is activated if someone tries to force open a door or if glass is broken
    Instructions
    http://toyotaparts.sparkstoyota.com/install/PT398-35160inst.pdf
    Toyota Parts
    https://www.toyotamcdonoughparts.com/oem-parts/toyota-security-vehicle-security-system-pt39835160
    auskip07 likes this.
  2. Jun 1, 2018 at 10:32 AM
    CBRDude
    CBRDude Well-Known Member
    Scott
    This is not the right kit! I have the part number, but I'm at the different local today and don't have access to it. I can send the correct kit to you on Monday. The GBS kit does not require the use of the techstream tool.
  3. Jun 1, 2018 at 10:37 AM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
  4. Jun 1, 2018 at 1:55 PM
    VicNic3
    GA
    Sorry ,looks like I left a zero off in my post
  5. Jun 1, 2018 at 3:51 PM
    02Duck
    I just printed off the instructions for the kit I have and the last step is using a tech stream to configure. Do you have another way? I don't have access to techstream.
  6. Jun 2, 2018 at 7:46 AM
    VicNic3
    GA
    Just found out my truck has the engine immobilizer anti theft system. No need to upgrade other than add the glass breakage system. Thanks for the info..
  7. Jun 5, 2018 at 11:10 AM
    okichewy1
    okichewy1 Just chuggin' along!
    Ken
    Kimberly, Idaho
    2018 DCSB TRD Sport Quicksand
    Ultra Flex bed cover, TRD PRO Grille, 32" LED light under grille, Pop n' Lock on tailgate, OCD organizer for center console and glove box, LED bed lights, OEM bed mat, black TACOMA tailgate letters, LED illumination light package, black vinyl overlays for badges, OEM bed step, plasti-dipped front valance and mirrors, 15% tinted windows and sun strip, vinyl letters on dash, vinyl letters on tailgate handle and door sill protectors, TRD Pro shift knob, home-link rear view mirror, mountain vinyl decal above Tacoma on door, FN FX pro wheels, AVS bug deflector, AVS in-channel window vents, front bed rail, red line hood struts, LED interior lights, TRD Pro skid plate, slim line front license plate holder, CaliRaised LED Ditch light brackets with LED lights, Bilstein 5100's, OME 888's, Dakar HD leaf springs, cubby covers, CaliRaised LED Fog light kit,
    Just bought this kit on Sunday, should be here tomorrow.
  8. Jun 5, 2018 at 5:29 PM
    VicNic3
    GA
    Keep us informed.
  9. Jun 12, 2018 at 11:50 PM
    YotaMan
    YotaMan TTC #0091
    Austin, Texas
    2020 Tacoma TRD Pro 4x4
    De-Badge,UltraGauge,Westcott Designs fox lift, 18” fuel rebels, Nitto Ridge Grapplers, interior led lights.
    Can you send me the right part number you were referring to? I have a 2017 off-road auto with tech package? Thanks
  10. Oct 27, 2019 at 4:13 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Did you ever install this? What did you do about tech stream?
    Also, has anyone else purchased another type of tech stream program from Amazon that can complete this installation?
  11. Oct 27, 2019 at 4:41 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    If you already have factory keyless entry is this system plug and play?
  12. Dec 15, 2019 at 6:04 PM
    SactoMan
    SactoMan Member
    Simon
    2019 Silver Tacoma SR5 ACLB 4x2 3.5L V6 AT
    Hello, I bought a 2019 Taco SR5 and tried to install the GBS using the V2 guide, which instructed to discard the dummy hood switch jumper since my taco doesn't even have that harness in the front; my hood latch doesn't have the alarm harness nor microswitch that tell my ECU the hood status. I installed the GBS and module from the OEM security system package and activated the security system with Techstream. However, upon activation, the hood ajar warning appears on my dash, and I cannot arm my alarm with the hood ajar error. So do you guys by any chance have a solution to this problem? Thank you all in advance.
  13. May 7, 2021 at 4:34 PM
    Bigmistertut
    Bigmistertut Member
    No one every answered the main question here and the answer is..if you have a 2016+ Tacoma with the factory alarm (blinking red light on the dash that goes solid after 30 seconds) and you have the smart key system (pushbutton start), I can confirm that you can install this plug and play. No tech stream needed. I just finished installing on my 21 Pro. GB sensor seems to work perfect on 6.
  14. May 7, 2021 at 4:50 PM
    ChrisIz
    ChrisIz Well-Known Member
    Texas
    2023 TRD Off-road
    It's plug and play, I have it installed on my 2020 OR with smart key. I set the sensitivity on the module to the max and it works flawlessly. Should not take more than 20 mins to install, In my case the front harness where the dummy plug goes to already had something plugged in to it and skipped that step.
    Bigmistertut likes this.
  15. Nov 20, 2021 at 12:45 PM
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    Does anyone know if this GBS will also detect if someone is cutting the catalytic converter off of the truck? Just curious if I should buy this.
  16. Nov 20, 2021 at 4:37 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    No it won’t. On a truck a the closest thing would be a shock sensor, but you’d probably have to set it so sensitive to detect cat theft that it would be going of falsely all the time. Tilt sensor that would detect vehicle being jack up is the best for this, but the Tacoma doesn’t need to be jacked up to remove cats.
  17. Nov 20, 2021 at 5:29 PM
    TacoTruck808
    Oh well. Thanks.
