Seeing two different pairs of part #'s and prices for Bilstein 5100's
Discussion in '1st Gen. Tacomas (1995-2004)' started by cjaz, Jul 11, 2022.
  1. Jul 11, 2022 at 2:31 PM
    cjaz
    cjaz [OP] Well-Known Member
    chris
    philly
    About to order some 5100's for the rear and I'm seeing two different pairs of numbers. One pair is 33247724 and 33247717. The other pair is F4-BE5-D559-T0 and D560. Bilstein Lifts sells both pairs and advertises them at slightly different lengths. They are also different prices.
    Bilstein 5100 1-1.5" Rear Lift Shocks for 1995-2004 Toyota Tacoma 4WD (bilsteinlifts.com)
    Bilstein 0-2.5" Lift Rear Shocks 1995-2004 Toyota Tacoma (bilsteinlifts.com)
    Wheelers advertises the second group of part numbers as 5100's. It's a little confusing, as they seem to be slightly different products.
  2. Jul 11, 2022 at 2:37 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    I went with these versions (33247724 & 33247717) a couple years ago - I went straight to Bilstein's site for part numbers. I vaguely remember reading about this discrepancy on TW once. I think the other versions don't come with bellows and there are probably other differences I am forgetting.
    Left and right rears are different lights, albeit slightly.
  3. Jul 11, 2022 at 2:40 PM
    Jim=2015 TRD PRO
    Jim=2015 TRD PRO Well-Known Member
    Jim
    MD
    2015 TRD PRO
    @memario1214
    Hook this guy up with what he wants
    memario1214 likes this.
  4. Jul 11, 2022 at 3:31 PM
    cjaz
    chris
    philly
    I replaced my front shocks with Bilstein 6112's, supposed to be set at 1.75" of lift. I also replaced my rear leafs with a heavier duty set of leaf springs from a local company. Truck is definitely higher in the rear but I don't know how much lift those springs gave me as I didn't take a measurement before, plus the old leafs were so shot that i don't think a measurement would have been that useful. I'm getting 37 1/4 and 37 1/2 from the floor with 265/70/16's. How much lift is that?
  5. Jul 11, 2022 at 4:00 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Honestly never heard of the 1-1.5" 5100's for Tacomas. I've only ever seen the 1-3" ones. Having a 1/2" range of applicable lifts seems like a waste
    The ones in your first link are out of stock, anyway.
    In other words, the D559/60s are probably what you want anyway.
    Either way, you need a set of add-a-leafs or an extended shackle for them to work.
    Yota_goon likes this.
  6. Jul 11, 2022 at 4:17 PM
    GoPedTed
    GoPedTed Member
    2002 TRD 4x4 Dbl Cab
    The D559/60 are what I have with 1.5-2" lift. Their side specific and have difference travel distance. Theres also 5125s.
  7. Jul 11, 2022 at 4:29 PM
    cjaz
    chris
    philly
    I don't understand why I need add a leafs or an extended shackle for them to work. Bilstein lifts says they are fine using them for stock height and my truck is definitely sitting higher than stock height due to the replacement leaf pack that I have. This is where I get confused. There are so many different parts choices for these trucks, making sure everything can work together that way it should is frustrating - for me anyway. At a quick glance rear shocks on these trucks look super easy to replace. Am i missing something?
  8. Jul 11, 2022 at 4:35 PM
    cjaz
    chris
    philly
    The 5100's in the first link are also sold at tirerack.com. they have them in stock.
  9. Jul 11, 2022 at 4:36 PM
    GoPedTed
    GoPedTed Member
    Super easy!
  10. Jul 12, 2022 at 9:30 AM
    cjaz
    chris
    philly
    After a little more research the first part number is the Bilstein 5100, and the second part number is the RCD Bilstein 5100. Bilstein doesn't list the RCD version on their website. I wonder if there is a difference in the valving or relative stiffness?
    tha_roost likes this.
  11. Jul 12, 2022 at 9:37 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    It's probably not higher than stock- it's more likely to just be higher than the old sagged springs you replaced. Your new springs will settle, as well.
    The shocks are extremely simple to replace. 2 bolts, top and bottom. Just don't over torque the bolts on the way back in. I used to take mine on and off before and after wheeling (before I did a shock relocation) and fubared one of the upper mounts. They are a pain to get a helicoil in there, but possible.
  12. Jul 12, 2022 at 10:09 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    So the 1st Gen Tacomas have side-specific 5100s. Why? It's intended to compensate for travel characteristics when you shim/level the truck to compensate for the additional weight of the fuel tank on that side. However, the same part number will work on both sides and the layman wouldn't know the difference. It pretty much comes down to do you want more up-travel or more down-travel? All said, we haven't seen a shipment of the "right side" ones come in for over 6 months... So I hope you like the characteristics of the left ones :rofl:. That said, the "left side" 724s are the shorter of the two so your uptravel concerns are lessened. Either way, since you have an unknown leaf pack that is providing some lift you'll want to make sure that you test out your uptravel to make sure you're finding the bumpstop before the shock. You can use a shock as a limiting strap, but not a bumpstop!
    BatteredTaco likes this.
  13. Jul 13, 2022 at 8:05 AM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    It’s for the shocks to work as designed.
    They are easy to replace. If you need to compress them you can use a ratchet strap.
  14. Sep 1, 2023 at 6:26 PM
    BatteredTaco
    BatteredTaco Well-Known Member
    J Lo
    SoCal
    02 3rz stick 4wd ext
    JDM 3rz@300k Yota1 cylhead@400k ARB-OME 880/5100s
    Colton,
    I want to figure out assembled ~1.5” front coils/bilstein shocks and 1.25” rear springs, for a 2002 ext taco 4x4 2.7l.
    Please message me when you can.
    Thank you,
    Joseph
    memario1214[QUOTED] likes this.
  15. Sep 1, 2023 at 10:15 PM
    memario1214
    Colton
    Missoula, MT
    Message sent!
  16. May 18, 2024 at 5:45 PM
    tha_roost
    tha_roost Member
    Deep East TX
    03 PreRunner DubCab TRD SR5
    The D559-560s (L&R) are the ORIGINAL Bilstein 5100's that were sold exclusively by Race Car Dynamics and are listed at having a 1.5"-3" lift over stock depending on application. The other part numbers are the regular Bilstein 5100s 33-247724 (L) and -247717 (R) are listed as giving 1-1.5" of lift. There are also two versions of the 5100s for the front as well. They have different parts if I remember correctly. One having a metal stopper on the shaft and the other having a plastic dust shield. I think their might have been something different about the valving, but I'm not certain.
