Seeking AC Expert Opinions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JSB10, Mar 15, 2018.
  1. Mar 15, 2018 at 4:17 PM
    JSB10
    JSB10 [OP] Well-Known Member
    2005 Tacoma
    I had my frame replaced last week and when I turned on my AC it didn't come on until it had been on for 10 minutes. It is on now but it doesn't seem to be running like it did when it would absolutely freeze me out. Here is what is doing now that it wasn't before the frame swap. When I turn it on it seems to take a few minutes to get cold when before it seemed to be cold from the get go. When the compressor cycles off the air coming out of the vent warms up but isn't like hot. I don't remember it doing that before. The air coming out always felt cold nonstop. Does this seem like a normal operating AC system or ...
  2. Mar 15, 2018 at 4:40 PM
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    When I had my frame replaced I believe the freon was recharged since I think they had to open ac system in doing the frame replacement. So I assume a vacuum was performed and Recharged to specs. Mine was fine when returned. Go back and have them check it. I think my parts list of what was Done showed that on invoice. There was no charge for this. Good luck
    JSB10[OP] likes this.
  3. Mar 15, 2018 at 5:55 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    when they did my frame on my 05 wasnt blowing as cold
    I asked the dealer who did work and they said had nothing to do with them
    Dealer was a$$ hole
    I just took it mechanic around the corner from me, hes a toyota guy
    Recharged the system and it was fine $60
    Didnt want to hassel with dealer again
  4. Mar 15, 2018 at 6:21 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    They probably under-charged it by accident or it has a leak
    JSB10[OP] and ovrlndkull like this.
  5. Mar 15, 2018 at 9:44 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    get some gauge readings for us.
  6. Mar 16, 2018 at 1:33 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Another satisfied customer. Thanks Toyota dealership
