Seeking Advice on 1st Purchase
Discussion in '1st Gen. Tacomas (1995-2004)' started by ss226, Dec 18, 2011.
  1. Dec 18, 2011 at 9:13 PM
    ss226
    ss226 [OP] New Member
    WA
    Hello Forum Members,
    I am about to commence my search for a 1st Gen Tacoma. My budget is 10-15K. It will be a weekend/hiking/camping/logging road truck, not a commuter vehicle. I have no preference on what engine size. I was hoping I could seek some advice on buying tips. Mainly, are there any model years/engine types that are desirable? Conversely, are there any model years/enging types I should be wary of? I am in the Seattle, WA area. Thank you all in advance!
    ss226
  2. Dec 18, 2011 at 9:28 PM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    One thing to be wary of is frame rust. IF the truck has been driven in salted winter road conditions for most of its life, I'd stay away. Or at least take it in for a pre-sale inspection and make sure they check the frame. If it's newer than 15 years old though and frame is still in good shape, dealership will put on an anti-corrosion coating for free. At least that was the case for me.
    I drive a 1997 2.7 liter 4 banger (cylinder). I love it. It's my every day vehicle, so I like having the smaller engine to save a little gas. It's cheaper to maintain a 4cyl, too. Not by much, but if you're a miser like me, the 2.7L works out great. But if you're carrying loads and just going on excursions, you might want the 3.4 liter V6. I bought my truck two years ago for $6000 at 179,000 miles. You will be able to afford a lot more.
    I'd be looking for a 2001-2004 V6, and you will likely be able to find one where the previous owner has re-done the suspension/lifted, which would be desirable for your purposes. One cross that we Tacoma owners have to bear is a crappy stock (mostly rear) suspension. So the other option, if you're inclined, is to set aside around $1400 to put in new suspension after you purchase. There are LOADS of threads on the subject. Read up on that, then head to wheelersoffroad.com and check some of it out.
    Mostly, welcome to TW. I'm pretty new myself and have learned a LOT. Good people all around.
  3. Dec 18, 2011 at 9:31 PM
    ERG80
    ERG80 Newb
    TN
    1997 T100 & 1996 FZJ80
  4. Dec 19, 2011 at 9:46 AM
    ss226
    WA
    Thanks for all the input. Great forum here!
  5. Dec 19, 2011 at 1:01 PM
    Madjik_Man
    Colorado Front Range
    I just called Boulder Toyota and they do not apply the anti-corrosion coating.
    Interesting.
  6. Dec 19, 2011 at 1:59 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    I just bought mine in Colorado Springs, ZERO rust. I bet that's probably why!
  7. Dec 19, 2011 at 2:10 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Dble cab with the door if you plan to put anything in cab--extra cab is not easy to put stuff in back. 4x4 of course. Going to haul anything? I like the manual tranny.
    If engine size is not an issue-four banger will save a little fuel.
    Off road 4x4 low gear-w/a 4cyl had pulled trees in the past-no prob w/ power.
    Going in tight areas? regular cab is going to be smaller.
    YOUR preference--
    Least amount of purchase price should be
    4cly,regular cab-
    YOU NEED 4x4 DEFINATELY-if off roading
    See the truck on my avatar? That truck would go ANYWHERE--it is a 91--GREAT TRUCK!!!!
  8. Dec 19, 2011 at 2:28 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
  9. Dec 19, 2011 at 4:12 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    That IS a GOOD DEAL=WOW
