Seeking advice: steering column rattle/clunk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by traviswesttx, Aug 13, 2024.
  1. Aug 13, 2024 at 10:08 AM
    traviswesttx
    traviswesttx [OP] Member
    2013 Toyota Tacoma 4x4 SR5
    Just seeking some advice I couldn't find from searching the forum...
    My 2013 Tacoma (4x4, 190k miles) suddenly developed a loud clunking/rattle on the driver's side, right under gas and break, at slow speed over bumps. Fine at highway speed. Mechanic says it's just an aging steering column - no loose/worn out/broken parts he can find - "just some play" causing the rattle/clunks. Says he can't find anything to fix, would just need a total steering column replacement (which I presume is quite expensive.)
    Thoughts on that?
    I've seen forum posts/YouTube videos about addressing loose or shaky steering, but this isn't that - it's a loud clunking/rattling outside the cab, underneath the driver's side. It steers/handles just fine.
    Thanks for any advice y'all can offer.
  2. Aug 13, 2024 at 11:03 AM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Upper and lower steering shafts.
    Firewall isolator.
    just replaced all 3 in my truck because of similar issues.
  3. Aug 13, 2024 at 11:36 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    What was the cost on these parts and how was the install? I had my rack replaced recently and have been thinking of doing these steering column parts too.
  4. Aug 13, 2024 at 12:08 PM
    steveo27
    Pittsburgh
    ~600$ in parts after shopping around.
    Couple hours of my time.
    There’s good DIYs on here and YouTube.
    Don’t skimp and buy aftermarket junk.
    This was the 2nd time I’ve replaced them because I didn’t wanna spend the money the first time.
    Dustrider and clenkeit like this.
  5. Aug 14, 2024 at 11:44 AM
    Thefinalfight
    Thefinalfight Born for the road
    Calvin
    Pittsburgh pa
    2013 Tacoma trd 4x4 v6 4.0
    Brake controller (aftermarket) Receiver hitch
    I have the same problem. Check your lower control arm bushings, and get up under your truck and shake your CV axle around on your driver side. Is it also happening when your parallel parking?
  6. Aug 14, 2024 at 11:45 AM
    Thefinalfight
    Calvin
    Pittsburgh pa
    Same
  7. Aug 14, 2024 at 1:23 PM
    traviswesttx
    After checking back in with the mechanic today - looking like it's not a steering column/shafts problem.
    They replaced the driver's side CV joint already - wasn't the problem - but, the CV on that side does indeed have way more play than on the passenger's side. Mechanic said maybe it's the CV joint bearing that's worn out on that side. But he recommended just replacing the entire front axle for that issue, so...gonna get some other opinions, hah.
    If anyone's had a bad rattle from that ^ particular problem though, happy to hear more about it...
  8. Aug 14, 2024 at 2:02 PM
    traviswesttx
    Now finding some older threads on excess CV axle play - and fixes via replacing the existing needle bearing with this bearing.
    But sounds like this approach could more to address vibration/hum than actual clunks from the CV axle area?
  9. Aug 14, 2024 at 5:54 PM
    traviswesttx
