Seeking ECGS needle bearing removal tool to borrow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ogre73, Aug 15, 2024.
  1. Aug 15, 2024 at 5:21 AM
    ogre73
    ogre73 [OP] Member
    Jim
    2015 Tacoma Access 4x
    Hi all. I’m taking my truck in in about a week to my local trustworthy mechanic to look at and drive to diagnose a growling/humming noise in the front end, seems like drivers side.
    In anticipation of a diagnosis of wheel bearings and/or needle bearing and maybe a cost I don’t wish to pay, I’m lining up the tools and parts to do both wheels and ECGS bushing all at once while it’s apart.
    Hoping someone would be willing to let me borrow their ECGS tool to remove the needle bearing so I don’t need to buy it new.
    Please PM me if you are willing to help. I’m in Maine and we could talk about whether it’s better to meet or mail.
    Thanks in advance. Jim
    Black97v6MT likes this.
  2. Aug 15, 2024 at 6:13 AM
    545 Well-Known Member
    2015 Access Cab
    Needle bearing can be diagnosed pretty easy, does the noise stop when you put it in 4wd?
  3. Aug 15, 2024 at 8:10 AM
    ogre73
    ogre73 [OP] Member
    Jim
    I’ll need to let you know next week, as we are currently away from home for the weekend but thanks for the suggestion. Will try and see.
  4. Aug 15, 2024 at 12:58 PM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    I have an ECGS tool Ill loan you. I live in Michigan so it would be mail
  5. Aug 15, 2024 at 7:32 PM
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    same here tucson
  6. Aug 19, 2024 at 7:50 AM
    ogre73
    ogre73 [OP] Member
    Jim
    Took it out this morning to see if it still made noise in 4WD and it does. Are you saying that this indicates the needle bearing is not a problem?
  7. Mar 3, 2025 at 12:32 PM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Same issue here on an '11 single cab 4wd at 108k miles
    Noisy hum do not go away in 4wd
    In fact it really only goes away at speeds greater than 70/75 mph
    Lots of play up and down on the driver side CV axle, it's not tight no movement like the passenger side is
    Anybody else have had this issue? Point me in the proper direction!?
    Shop time to replace the needle bearing is about 5 hours I was told at the DiY shop
    This type of maintenance is all new to I :)
    What is the difficulty level to DiY this rascal and get the humming to cease LoL
  8. Mar 3, 2025 at 12:35 PM
    2015 Access Cab
    Well I assume you’ve already fixed your issue, but the answer is yes
  9. Mar 3, 2025 at 12:37 PM
    2015 Access Cab
    Wheel bearing? What have you done to diagnose the issue so far?
    Black97v6MT[QUOTED] likes this.
  10. Mar 3, 2025 at 12:37 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Perhaps just CV axle?
    I turned the wheel and heard no real noticable bearing noise
    I drove it in 4wd at 60 mph and the humming was still there!
  11. Mar 3, 2025 at 12:40 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Had it on the DiY garage lift today to change the oil filter and front diff gear oil
    Spun the wheel, no real chatter
    Rocked the wheel 12 to 6 and no play either
    Put hand on the CV axle and definitely moved up and down inside the diff... Passenger side did not move at all
    Tires are falken wild peaks at about 6/32 tread and 53k miles approximately
    This '11 taco used to be such a quiet whisper on the freeway :(
