Seeking Holy Grail, Extension for Warn EVO Winch.
Discussion in 'Off-Roading & Trails' started by BKinzey, Jul 19, 2024.
  1. Jul 19, 2024 at 10:46 PM
    BKinzey
    BKinzey [OP] Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Not really up on these but mine has a D shaped plug, not sure if the round one will work.
    CAUTION: Rant Ahead!
    Warn has them. 2 types of 2' extensions. They want $100 for one and $150 for the other. for a piece of wire with molded plugs. Fer crimminey sakes! They want for a wireless control that you use an app with your phone only $89. Extensions for other winches run $20 - $30. So no, I don't want to spend that much. Also, 2' may be too short.
    TLDR:
    I'm looking for an aftermarket extension that works with a Warn EVO winch. I'm ok with a DIY built.
    photodoc likes this.
  2. Jul 21, 2024 at 9:50 AM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    how are your wiring skills? You could easily cut the control wire you have, extend the wires, solder, and heat shrink around the connections to whatever length you want. It’s just signal wire so it won’t pose a fire risk due to the splice. That would be your cheapest and most customized to what you need.
  3. Jul 21, 2024 at 8:25 PM
    BKinzey
    Beauford
    Hollywierd, CA
    Thanks for the suggestion.
    The EVO originally came equipped with a wireless remote. They had all sorts of problems and Warn changed to a hard wired controller. That has a 20' or there-a-bouts cable that plugs into the controller. I did consider I could just plug the control cable into the winch and stash the 20' of cable somewhere under the hood and unplug the controller, but that seems a little hinky to me. I thought maybe somebody around here found an aftermarket cable that works or DIY'd one.
