Seeking opinions on Metra ASWC Universal
Discussion in 'Audio & Video' started by azgunrunner, Sep 26, 2011.
  1. Sep 26, 2011 at 11:59 PM
    azgunrunner
    azgunrunner [OP] A guy that knows a guy, that knows a guy...
    George
    06 DCLB Sport
    OME Coils, TMJ struts and shocks, Dakar leaf springs KMF sliders CBI Ditch light mounts Bumpers pending OBA pending TJM rear air locker pending
    Anyone have any experience with this unit? Looks like a newer/easier unit to use.
    http://www.metraonline.com/part/ASWC
    Only 3 wires to install.. checked out Amazon and there are some pretty good reviews.
    thoughts?
  2. Sep 27, 2011 at 5:05 AM
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    I bought it and the tacoma harness they offer. Plugged it right in, and didn't touch a thing. It programmed itself and my buttons work perfectly
  3. Sep 27, 2011 at 11:33 AM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Same purchases and experience for me - hooked up to a Pioneer X930BT.
  4. Sep 27, 2011 at 2:46 PM
    XPOTRPR
    XPOTRPR #safetydevelopment
    Moose
    Chandler, AZ
    Mid-Travel, Boosted, Expo Taco
    CHECK BUILD
    Dude, just installed mine like two weeks ago with my new stereo. Had SGT Taco (Scott) help me with the install. After he saw how easy it was, hes getting one. three wires, iit programs itself, and your done. definitely recommend one.
  5. Sep 27, 2011 at 11:08 PM
    azgunrunner
    George
    06 DCLB Sport
    Awesome! That's what I was hoping to hear, I'm definitely going to order one for my 4300. Thanks for all of the replies!
  6. Sep 28, 2011 at 7:23 AM
    XPOTRPR
    Moose
    Chandler, AZ
    CHECK BUILD
    Right on man. We have the same set up too. Avh p4300. so it will definitely work.
  7. Apr 3, 2012 at 7:51 PM
    idgara007
    idgara007 Active Member
    tx/CA
    09 TRD Sport double cab
    Curious if this harness also works for the bluetooth controls on the right side of the steering wheel? I want an aftermarket headunit but dont want to lose the wheel controls (audio or bluetooth). If so, the new receiver should have bluetooth built in correct? Unless I want to shell out $$$ for a bluetooth adapter for the receiver right... Thank you very much for your help!
  8. Apr 3, 2012 at 9:41 PM
    XPOTRPR
    Moose
    Chandler, AZ
    CHECK BUILD
    Unfortunately, you'll lose your BT controls. Youll be stuck with the Bluetooth on the headunit. which shouldnt be a real Issue honestly. You hit a button on your steering wheel, or a few inches away on the stereo. maybe theres a way to use the volume controls to answer and hang up. Best of luck.
  9. May 7, 2012 at 11:44 AM
    mk7
    mk7 Active Member
    Michael
    Austin, TX
    '11 4x4 TRD Off Road
    looks like a nice product, I'll have to remember to buy this when I decide to change my headunit.
  10. May 7, 2012 at 12:25 PM
    DavidS
    DavidS Well-Known Member
    Dave
    Pacific Northwest
    2012 Tacoma TRD Sport
    What BT controls did you loose? Mine work find, but I did need to manually program the on/off hook button. Not a big deal...
  11. May 7, 2012 at 6:01 PM
    XPOTRPR
    Moose
    Chandler, AZ
    CHECK BUILD
    My current aftermarket deck doesn't have BT (I didn't use it enough in my 06) so I'm not sure to what extent.. but I don't have any control with he BT buttons.. maybe the Metra can do it.. i just didn't try. That along with everything else I read and heard.. it won't work. But if does.. right on! Maybe ill ill try it down the road if I ever get the BT add-on.
  12. May 7, 2012 at 6:22 PM
    DavidS
    Dave
    Pacific Northwest
    If your HU doesn't have any BT functionality, you will not gain or loose them by installing the Metra. The Metra is simply a module that takes the wired inputs from your stearing wheel controls and passes the inputs along (through wires) to your HU. If you want BT, you'll want to look into some kind of BT add-on specific to your HU.
  13. May 7, 2012 at 6:27 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I ordered this from Crutchfield this time last year. It worked perfectly, once I spliced the correct wires together.
    Do not use the instruction book it comes with. Go on Metra's website & get the instructions for your vehicle.
    Item# 120ASWC Metra ASWC Auto Sensing Steering Wheel Cntrl Intrfc $69.99
    Hooked it up to a Pioneer DEH-6300UB CD Receiver.
  14. May 7, 2012 at 9:53 PM
    XPOTRPR
    Moose
    Chandler, AZ
    CHECK BUILD
    I know.. i said i didnt have BT... I have the Metra and have it hooked up to use my steering wheel controls.. just not my BT.. because I dont have BT. lol
  15. May 8, 2012 at 7:14 AM
    RevAdam
    Adam
    Upstate SC
    11 TRD OR 4x4
    You can reprogram the BT buttons to do other things :)
