Seeking Opinions Regarding Two RVs
Discussion in 'Towing' started by kenlor2, Jul 4, 2012.
  1. Jul 4, 2012 at 2:05 PM
    kenlor2
    kenlor2 [OP] New Member
    Ken
    Santa Fe, NM
    07 TRD Off-road
    I have an '07, 4x4 TRD Offroad w Towing Package and 6500# towing capacity, short bed and dual cab. I'm considering two trailers. One trailer has a 4770 GVWR while the second has a 5743 GVWR. The first trailer is a very nice trailer, but the heavier trailer has more space and comfort features. But, I'm concerned with the extra weight. Although "compliant" from a specifications standpoint, I will be towing from my location in northern NM to mountainous areas in CO, UT and the northwest. Assuming that the trailer is properly set up as noted in the "Towing Bible", I don't want to find myself "not having fun" while towing near the limits for long distances. Thoughts on this very subjective topic?
  2. Jul 4, 2012 at 2:12 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Go for the lighter trailer, or a bigger tow vehicle.
    Don't expect better than 50% of your normal MPG. Seriously, a lightweight "pop-up" or tent trailer is a much better way to go.
  3. Jul 4, 2012 at 2:12 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    the GVWR is before all your people, gear, and fluids in your trailer tanks...that'd easily put you over 6500.
  4. Jul 4, 2012 at 2:49 PM
    BC Overlander
    BC Overlander Active Member
    British Columbia
    2011 Tacoma 4X4 TRD Off-Road
    Gross Vehicle Weight Rating is the maximum the trailer can weight with all your people, gear and fluids in the tanks.
    UVW or Unloaded Vehicle Weight is before your people, gear and fluids.
  5. Jul 4, 2012 at 3:33 PM
    theredofshaw
    :facepalm:
    oops...those numbers always seemed a little low to me.
  6. Jul 4, 2012 at 4:34 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    But most important is the GCVWR of the tow vehicle.
    You have the Tacoma's GVWR, and you have the trailer's GVWR.
    With the Tacoma at GVWR, you will exceed it's GCVWR long before the trailer hit's it's own GVWR.
    2012 Tacoma GVWR is 5350.
    2012 Tacoma GCVWR is 11,100 (with the tow package).
    2012 Tacoma max towing weight is 6500.
    5350 + 6500 = 11,850
    Your curb weight is 4045, leaving only 1300 pounds for passengers, cargo, fluids, fuel, etc....
    So realistically, passengers and packed for a vacation, you are likely going to be at or VERY close to your 5350 max for the Tacoma... leaving an absolute max trailer weight of about 5750.
    Ya... that's greater than the 5743 of the trailer you're looking at... but neither you nor your Tacoma are going to be happy campers.
  7. Jul 6, 2012 at 11:07 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    If he is at the GVWR of the Tacoma before hooking up the trailer, his real max trailer weight is zero. That's because any tongue weight attached to the rear of the Tacoma would push him over the GVWR.
  8. Jul 6, 2012 at 11:19 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    500lb tongue weight would drop his available total capacity to under 800lbs.
    4 passengers and a case of beer would be over.
  9. Jul 6, 2012 at 11:30 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Well it sounds like you can get the heavy trailer if you pack lightly, but if you never want to worry about being over weight the lighter one is the way to go. Or now you have an excuse to get a 5.7l tundra :)
  10. Jul 8, 2012 at 1:42 PM
    kenlor2
    Ken
    Santa Fe, NM
    07 TRD Off-road
    Thanks for the replies to my question. This was my first post and it has been very helpful. Ken
  11. Jul 8, 2012 at 3:28 PM
    theredofshaw
    that's what TW is for :D
    just gotta be careful of a few people on here, they like to dish it out and some new people don't realize they are joking.
  12. Jul 12, 2012 at 7:32 AM
    Gunga
    Gunga Well-Known Member
    Glendale, AZ
    2008 TRD OffRoad DC 4x4
    Based on where you live and where you want to go you will not be happy with that heavy of a trailer. IMO.
  13. Jul 12, 2012 at 7:42 AM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    I have the exact same truck, and tow a 3500 lb loaded travel trailer. It does great on the flat roads, but it does struggle a bit when I start hitting the hilly roads at the bottom of the mountains. I really think I'm at the limit for towing weight with the power plant of the Tacoma. I plan to put a supercharger on it to help pull in the mountains. I don't want to be that guy in the right lane on the highway doing 45 mph on every steep incline.
    Stability wise, I have the OME dakar leafs and 886 coils. It handles the trailer perfectly with no sway or bouncing. So it's only the power that I need to fix.
