Seeking snow/rain tires for 4x4 in KY
Discussion in 'Wheels & Tires' started by Geoffnel10, Jul 26, 2023.
  1. Jul 26, 2023 at 4:42 PM
    Geoffnel10
    Geoffnel10 [OP] New Member
    Stock 2023 Tacoma SR
    I bought my Tacoma last summer and have done no major mods/upgrades so I am new to all this.
    I am looking to upgrade to more capable tires outside of the stock tires. I have a job in the medical field that requires me to be at the hospital rain or shine day or night at the drop of a dime and I don’t want to have ti worry about getting stuck in snow at 3am on the way to a work emergency.
    What are some good (and good looking) rain/snow tires that I could look at purchasing that would fit stock 17in rims and suspension. I’ve read that 275/70/17 tires fit stock without rubbing but everybody already seems to have a lift with said tires so I am getting mixed signals.
    Any help or recommendations is appreciated. Thank you!
    updated: truck is 4x4 and I live in central KY on back roads so winters can range from pretty mild to moderate (1-6in average)
  2. Jul 26, 2023 at 5:09 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    P265/65R17 is the stock size tires on my 17 inch Sport wheels. I am all pavement and need to get around in snow too. I like Michelin LTX Defenders if your SR is 4x4. If it is 2WD, I will let others chime in as you may need more aggressive tread in the back when it snows.
    https://www.michelinman.com/auto/tires/michelin-defender-ltx-m-s
    hiPSI and Geoffnel10[OP] like this.
  3. Jul 26, 2023 at 5:13 PM
    dklehman
    dklehman Well-Known Member
    Darin
    Eastern wa
    2021 TRD off road
    If you are all about the use and don't care much about the look buy a good street tire and dedicated snow tires for winter
    Geoffnel10[OP] likes this.
  4. Jul 26, 2023 at 5:27 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    A 275/70/17 will probably require some modifications to the truck to prevent rubbing. A 265/70/17 should work. It is about 1" taller than stock, same width. It is when you go wider that complicates things.
    Is your truck 4X4 or 4X2? Where you live matters too. There is a big difference between the twice a decade snows in the south and the blizzards in Buffalo NY.
  5. Jul 26, 2023 at 5:42 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Your stock SR has 17" rims??
    You looking for a single set of tires for every season? Or a dedicated snow tire?
    Great 4 seasons imo are Toyo Open Country ATIII
    Geoffnel10[OP] and 6starwars like this.
  6. Jul 26, 2023 at 5:52 PM
    6starwars
    6starwars Well-Known Member
    VA
    24 TRD SPORT DCSB 4x4
    I live in Central VA and have winters similar to yours. I love my 265/70/17 Nitto Ridge Grapplers. Previous tires were Terra Grapplers, but the Ridge Grapplers have a more aggressive look.
    Geoffnel10[OP] and LeakyAC like this.
  7. Jul 26, 2023 at 5:58 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Hakkas or Blizzaks and you’re in good shape
    :thumbsup:
    LeakyAC and hiPSI like this.
  8. Jul 26, 2023 at 6:07 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Mickey Thompson Baja boss A/T
  9. Jul 26, 2023 at 6:07 PM
    TRD_Seeds
    TRD_Seeds Well-Known Member
    York, PA
    2019 Cement Tacoma TRD OR
    As others have recommended, I’d go with a 265/70/17 over a 275. Chance you might rub, and more importantly, you’ll have a LOT more tire options in the 265. Most all of the 275/70/17’s are E rated only, which you may not enjoy.
    6starwars likes this.
  10. Jul 26, 2023 at 6:56 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Falken wild peaks .. great for street snow and rain . And they are quiet . Only downside they wear out pretty quickly .
  11. Jul 26, 2023 at 6:59 PM
    Mallcrawler20
    I liked those tires but the noise level was just not acceptable. It really made me hate driving my truck .
  12. Jul 26, 2023 at 6:59 PM
    KorbenMyMan
    KorbenMyMan Active Member
    E Tex
    2018 Tacoma SR5
    Way too many to list
    I’d highly recommend that you look at Nitto’s Terra Grappler G2. They’re not as aggressive looking as the Ridge Grapplers, but I’ve heard good things from people that have them. They also have good reviews for wet/snow traction.
    I also think you should focus on the 265/70r17 size instead of 270s. 265s are less likely to rub and they come with more load options like standard and C. Most all 270s come in E load, and even Falken’s 270 C load Wildpeaks weight in at over 50 lbs per tire.
    33yrsoftoys likes this.
  13. Jul 26, 2023 at 7:02 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    Whatever you choose try and stay with an SL rated tire. Your ride and MPG's will be much better.
    LeakyAC likes this.
  14. Jul 26, 2023 at 7:03 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Best answer. Not sexy, but best.
    eurowner and TA2016[QUOTED] like this.
  15. Jul 26, 2023 at 7:03 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Fucking no.
    eurowner, Bishop84 and LeakyAC like this.
  16. Jul 26, 2023 at 7:04 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yes but winter only.
  17. Jul 26, 2023 at 7:04 PM
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    Used duratracs on an ambulance up in the arctic, and blizzaks. Great tires, for sure consider a summer and winter (3 peak rated) set of tires.
    I rip around backcountry roads in alberta alot, during winter & summer. I have the stock wranglers for summer & blizzaks for winter. Never had an issue with our fairly extreme winters.
    hiPSI and LeakyAC like this.
  18. Jul 26, 2023 at 7:08 PM
    LeakyAC
    How are those on hardball in the rain tho?
  19. Jul 26, 2023 at 7:12 PM
    LeakyAC
    No way? I run those on 245/75 on 16s and they're super quiet. My bro ran some 33 or 35 OC ATIII on his F series and said they were loud af too..go figure
  20. Jul 26, 2023 at 7:18 PM
    Yossarian
    Yossarian Well-Known Member
    Arizona
    2023 4Runner SR5P 4x4 / 1996 3.4L 4x4 AC
    Diode Dynamics fogs, HIR reverse light, Hefty Fab sliders, Wet Okole seat covers / Fabtech coilovers, 33" KO2s, Hella 500FFs, Hella ECE headlights, tube bumper, sliders
    Why? The reviews I've seen say they're excellent in snow and at worst average in rain.
    AmateurTaco1313 likes this.
