Seeking used long bed, not long cab.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hjourzt, Feb 5, 2023.
  1. Feb 5, 2023 at 12:21 PM
    Hjourzt
    Hjourzt [OP] Member
    Longbed Pickup that will fit in my garage
    Hi Gang:
    Just discovered this forum after weeks of research. I picked this channel because I think 2nd gen Tacomas are more likely to fit my needs. I hope someone here can help with my very specific quest:
    Long bed Toyota pickup, 2wd, not long cab, not wide body. 4 cyl preferred, will take V6.
    I once had a 1985 Toyota long bed basic 2WD. Regular cab, no extras, didn't even have a rear bumper. I loved it because I could lie down in the bed under my camper shell with enough room for a pillow and not hit my feet against the gate. But I also loved the fact that it was not a behemoth otherwise, and I could fit it into my limited San Francisco garage space and I was able to walk around it. Mileage was pretty good, too. 20 years later; it got old, it was loud, it wasn't befitting my station, etc. I sold it and bought an Odyssey.
    That was a mistake, and now I want to get a newer version of my old truck, only to discover that it seems to be impossible to get a long bed without an extended cab, or 4WD, both of which are deal breakers. (I could deal with one of the slightly extended cab versions, if I could find accurate info about the dimensions.) It doesn't help that a lot of websites are incomplete or have questionable information, such as overall vehicle length.
    So I ask: What is the most recent Toyota that is most like the pre-steroid vehicles that used to be so common?
    I don't need someone to find the actual vehicle, I'm just trying to narrow down the make/model/year that fits.
    Thanks.
  2. Feb 5, 2023 at 12:29 PM
    MR5X5
    MR5X5 Well-Known Member
    Try a Wikipedia search
  3. Feb 5, 2023 at 12:47 PM
    Waasheem
    Waasheem
    2007 xrunner
    Cars.com
    If I remember correctly, it has pretty detailed information regarding what the different models had.
    Used Tacoma’s are sought after and don’t stay on the market for long. If you find one that suits your needs, run to go look at it. Don’t spend too much time thinking about it, it’ll get sold. They all have issues with frame rust so look there first.
    I haven’t kept up with what’s going on with the chip shortage. It must not be as bad now because I see vehicles in the dealerships again. It might still have an indirect effect on used prices and availability.
    There’s several different models, something like 20-30. When I looked at new models in 2019, the dealer had a 3 page long list of models and what each came with.
  4. Feb 5, 2023 at 12:53 PM
    Hjourzt
    Hjourzt [OP] Member
    I forgot to mention: I am seeking used, around 2015 or earlier. Can't afford new, and wouldn't buy new if I could. It also seems that the newer models are far from the smaller vehicle I'm seeking, based on what I read.
  5. Feb 5, 2023 at 1:24 PM
    Matt Sierra
    Matt Sierra Well-Known Member
    NorCal
    2020 TRD Pro MT
    Maggy SC, C4 Overland front bumper
    Sounds like you want a regular cab 5 lug 2nd gen. Wikipedia gives the overall length at 190.4 inches, so it’ll still be longer than your 84 pickup. I have a 1990 pickup and it’s only about 175 inches long.
  6. Feb 7, 2023 at 4:30 PM
    Hjourzt
    Hjourzt [OP] Member
    Thanks, all, for the tips. After hours of research, I am now certain that the compact long bed pickup I want does not exist. The last small pickup that Toyota issued with a long bed was 1993, and I am not willing to adopt one of those from the shelter. I do have another plan, however, which I will detail in another post because it is fundamentally a new project.
    See you on the flip side....
    SR-71A likes this.
  7. Feb 7, 2023 at 7:08 PM
    dbittle
    dbittle Member
    2013 Tacoma 2.7 auto
    Sad. You should adopt one from the shelter! It’s the right thing to do…..
  8. Feb 7, 2023 at 7:32 PM
    Matt Sierra
    NorCal
    2020 TRD Pro MT
    Got it, you wanted a full size 8’ bed.
    These days in Tacomaland a long bed is 6’ and a short bed is 5’.
