SeekingZero - Adventure Build
Discussion in '1st Gen. Builds (1995-2004)' started by SeekingZero, Nov 11, 2014.
  1. Jul 12, 2017 at 9:12 PM
    #241
    SeekingZero
    SeekingZero [OP] Well-Known Member
    Ben
    Sierra Mountains, CA
    01 Xtracab 4x4 SR5 TRD Supercharged
    4th of July was such an awesome weekend! It was good to get out wheeling again with friends and get a chance to open up some trails for the season! Not to mention, test out the new chassis and modifications on the truck!
  2. Jul 12, 2017 at 9:15 PM
    #242
    SeekingZero
    Ben
    Everything went really well up until we were set to leave on Tuesday. Then I realized that the noise I had been looking for the whole trip had disappeared, but I found what had made it...much to my dismay.
    Luckily my policy covered 24/7 roadside and we were close to Quincy where we got it repaired with some bolts from the hardware store that was surprisingly open and I was able to limp home.
    I had the spindles swapped out with new bolts and she's good as new.
  3. Jul 12, 2017 at 9:31 PM
    #243
    SeekingZero
    Ben
    Since I got the truck back, I got her all cleaned up, adjusted a few things and got started on finishing a few mods and adding a few more before I go back out.
    The SwitchPros SP8100 still hadn't been mounted since I installed it in February, so I took off what I needed to to drop the front of the headliner, punched the mounting bolts through and cut a slit for the cabling, then buttoned it back up.
    It was also time to move the handheld HAM radios to backup and install the mobile unit. I got the Yaesu FT-7900R as it was the cheapest one with the removable faceplate and since the first gen cab is tiny, I need space efficient things.
    I knew the unit would be tucked away in the space under the center console, so I took that out and got to drilling. Since my unit was almost perfectly sized for this space, I am waiting on elbows for the PL-259 antenna connector and the 3.5mm audio for the speaker which I will figure out where to mount this weekend.
    I picked out a spot on the dash that was both out of the way, easily accessible, and slightly hidden from prying eyes. Turns out that it was a clean mounting spot to and I'm extremely happy with it.
    And with everything in its place.
    TRD_IV, Dalandser, cbechtold and 4 others like this.
  4. Aug 2, 2017 at 5:03 PM
    #244
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    How does that super cap seal work? I seen it in the products discussed. I need to replace the crappy double sided tape as my camper still takes on water
  5. Jan 5, 2018 at 6:30 AM
    #245
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Hey Ben, I'm wondering how close you were able to get the yakima tracks to the roof of your ext cab. I know the hump is rather extreme. Do you have any pictures from the side? Is there a gap?
    I'm considering mounting a prinsu in the same way that you did. Did you cut off the original mounting tabs?
  6. Feb 9, 2018 at 10:12 PM
    #246
    SeekingZero
    Ben
    I'm not convinced it does. I feel like it absorbs water, but I would think it was closed cell foam. For the most part, the back is dry though, so I'm not complaining.
  7. Feb 9, 2018 at 10:15 PM
    #247
    SeekingZero
    Ben
    There is a gap. I didn't realize this before I put the tracks on, but PrinSu has designed the first gen rack to bolt directly to the roof, not to tracks. So I did all that for nothing. I left the feet on the rack, too lazy to cut them off.
  8. Feb 9, 2018 at 10:37 PM
    #248
    Dan8906
    Daniel
    Concord, California
    Yeah I bought it, I don’t think it works very well. Sucks
  9. Apr 25, 2018 at 9:24 PM
    #249
    SeekingZero
    Ben
    Update time. I haven't been online much, cuz let's be honest here, I don't care much. But I appreciate the time that others take to provide information about their builds that sometimes helps me in a decision. So this is more of my way of paying it forward. But enough about me.
    Truck additions:
    • swingout
    • winch
    • airbox
    • snorkel
    • suspension work
    Finally getting the truck dialed in to go faster more smoothly without breaking. The Fox setup is great, but I know from racing, that good suspension can be made better. So I sent my front shocks down to Accutune Offroad to give them what they needed. I also had them swap out the 600# springs for 700#. What a world of difference in feel now! I didn't adjust the preload before I put them back on, and was so busy, I just drove the next adventure with my front end jacked up a bit, BUT it rode smooth and I could finally go desert fast! Preload has since been adjusted right with about 1-2" of thread showing now. I'll send the rears down soon with the next downtime.
    Working backwards on my list. I got tired of banging out all the dust in my air filter from being left in the dust. Time to change that. Pretty painless install, nothing new here. It would help to take the fender off. I ended up having to unbolt the lower fender to be able to get a hand up to tighten the upper inside nut. Otherwise, straightforward.
    Before that, I replaced my airbox because the filter access tabs had rusted and one broke. Probably another reason for all the dust...
    Winch time. It has been long overdue, but I've never put myself in a situation where I needed it and everyone I wheel with has one. Mostly they are used to move tress. So, hopefully I never have to use it. but better to have it and not need it...
    Warn Zeon 10-S:
    The stupidly stylish control box obviously wasn't designed for this bumper. Just a lot of empty space anyway...so I got rid of it. This little box is all you need.
    Drilled some holes in the bumper and mounted it out of sight and away from harm. Then made the necessary jumper cables because why pay for a patch kit. Reinstalled the bumper, mounted the control connection next to the airbox under the hood and done. The new springs on the shocks took the weight like it wasn't there.
    Onto the finale! I never wanted a swingout. But, I couldn't argue against the practicality anymore especially since I didn't want to put my tire on the roof anymore and I won't even have that option soon. :spy: I like my bumper, I didn't want to buy a new one. It was more cost effective to just build the swingout onto what I had. So, with the help of someone with a welder, I got the perfect solution and made sure it was beefy! Half the time spent was just fabricating the hinge assembly. It had to sit flush due to my original tolerance with the tailgate, but still be strong enough to take the weight.
    Hard part done. Swing out itself was easy, just sticking metal together. Another design aspect I wanted to incorporate was a way to ensure the weight was stable and secure when offroad. Swing outs fully built with the tire and gas and whatever else you put on there end up adding a lot of weight that will make the whole arm sag, and cause them to not latch correctly or potentially break the latch if it ends up inadvertently becoming a load bearing point. So we used the receiver hitch as a load bearing point. If you notice in the next picture, we added a curved plate that will allow the arm to nicely slide its weight onto the center of the bumper and the latch will take zero load at that point.
    We also added mount points for the hilift to sit behind the tire horizontally and in such a way that secures the hilift against the rubber of the tire so that it doesn't rattle or squeaky. That way I can listen for actual things that are breaking on the truck. Smooth it out and off to powder coating.
    We added on the All-Pro gas can holder, but realized after the fact, that the dimension for it make it completely unusable for any application other than sticking a cooler in it. So, that's up for grabs if anyone wants to haul around their cooler in style for their family picnic...
    I left a can of gas on top of the truck instead for the shakedown trip to Mojave.
  10. May 17, 2018 at 4:46 AM
    #250
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    So you are getting an RTT?
    I'm going from an RTT to a camper shell with sleeping platform. Curious to hear anything you don't like about the setup.
  11. May 24, 2018 at 9:34 PM
    #251
    SeekingZero
    Ben
    Nope. I love the shell setup I have, it's great for me. I'm going to something a little more roomy so its easier for two.
  12. May 25, 2018 at 4:31 PM
    #252
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Nice. Sounds like its gonna be good
  13. Sep 4, 2018 at 1:06 PM
    #253
    SeekingZero
    Ben
  14. Sep 4, 2018 at 3:21 PM
    #254
    Dan8906
    Daniel
    Concord, California
  15. Sep 4, 2018 at 7:44 PM
    #255
    SeekingZero
    Ben
    A Drifter
    jubei and otis24 like this.
  16. Sep 5, 2018 at 6:56 AM
    #256
    Dan8906
    Daniel
    Concord, California
    That will be awesome.
  17. Sep 5, 2018 at 7:45 AM
    #257
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    That's a good looking truck.
    Do you have any fuel mods like 7th injector, etc for the supercharger?
  18. Sep 5, 2018 at 9:17 AM
    #258
    SeekingZero
    Ben
    Thanks Mark. No, I thought about doing 7th injector but its not worth the effort to me. I have plenty of power with the S/C alone and I don't want to introduce another point of failure to the engine.
    Edit: have since done the URD 7th injector kit since pinging is bad...
  19. Sep 5, 2018 at 9:52 AM
    #259
    otis24
    Mark
    California
    I've been considering going for an S/C just so my truck can get out of it's own way, especially at elevation. I have the same thoughts as you..why introduce another failure point and it'll have plenty of power on its own.
  20. Sep 5, 2018 at 10:40 AM
    #260
    SeekingZero
    Ben
    Highly recommend the S/C! I wouldn't drive my truck without it. Never driven a 3.4 without forced induction, but I can just image it's terrible.
    otis24[QUOTED] likes this.
