Seized Diff Lug
Discussion in 'Technical Chat' started by PreRunnerMan, Dec 2, 2015.
  1. Dec 2, 2015 at 10:25 AM
    PreRunnerMan
    PreRunnerMan [OP] Well-Known Member
    Alex
    SoCal, Whittier
    White 2010 PreRunner SR5
    ADS Coilovers LR UCAs Bilstein shocks in the rear Dakar Leaf Pack CMC 287/70/17 BFG K02s
    The lug on the rear differential is seized, and I was wondering if anyone knew how to remove it or any tips on doing it. I would like to change out the diff fluid pretty soon, so any help would be great thanks.
  2. Dec 2, 2015 at 10:27 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Have you tried soaking it in WD-40 for a few hours? Breaker bar didn't work? Try an impact gun to see if that'll bust it loose. Is it the drain or filler plug that's seized?
  3. Dec 2, 2015 at 10:30 AM
    PreRunnerMan
    Alex
    SoCal, Whittier
    Filler Plug. At jiffy lube they tried an impact gun and wouldn't come out. Have not tried the WD-40. I will try that once they finish pouring the concrete for my driveway and its all dried up. Thanks
  4. Dec 2, 2015 at 11:16 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    WD-40 is not going to cut it .
    You need a penetrating oil of some sort P Blaster Kroil something along those lines
    You might need to weld a new nut on.
    You Gotta love Jiffy Lube!!
  5. Dec 2, 2015 at 12:31 PM
    PreRunnerMan
    Alex
    SoCal, Whittier
    What do you mean by weld a new nut on? Like drill a new hole or what? Sorry I'm a bit confused
  6. Dec 2, 2015 at 12:35 PM
    ZachPrerunner
    Southeast TN
    I don't think penetrating oil is even going to cut it in his case. If an impact gun won't take it off, he'll probably need to weld a new nut like you mentioned.
  7. Dec 2, 2015 at 12:43 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I don`t have a Plug in front of me so I am just guessing on the size
    You find a nut you have a 6PT socket for
    Weld it to the stuck nut .
    Did they round it off using the wrong size or Just being stupid ??
    Going the wrong way perhaps.
    I just use a 6pt socket on my 1/2 ratchet once the old plugs or out.
    I always put new plugs in when I get a new vehicle coming through here.
    Have new plugs to replace Never Seize them and snug them up
  8. Dec 2, 2015 at 12:48 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Give it a few love taps with at least a 3lb sledge then try again. If anything you can always remove the vent thingy on top and fill the fluid from there if you absolutely can not remove the fill plug.
  9. Dec 2, 2015 at 1:26 PM
    ZachPrerunner
    Southeast TN
    OP you might have to grind down the edge of the socket. Standard sockets have that round lip that isn't flush because mine wanted to slip when I was trying to remove the drain plug.
  10. Dec 2, 2015 at 3:18 PM
    PreRunnerMan
    Alex
    SoCal, Whittier
    alright great thanks, I will investigate further as soon as i can have access to my garage to get some tools out.
  11. Dec 2, 2015 at 4:39 PM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    Had that issue with an older toyota pickup. I put a heat gun on maximum 1500 watt setting directly on the nut for about a minute or when it seems pretty hot. I then hit it with the impact and it came right off. WD 40, pb blaster, sledge hammer would not work for me.
  12. Dec 2, 2015 at 6:55 PM
    PreRunnerMan
    Alex
    SoCal, Whittier
    I may have to go look at getting heat gun if all else fails. Thanks
  13. Dec 7, 2015 at 6:39 AM
    tgear.shead
    tgear.shead Well-Known Member
    I'm surprised that a little heat gun like that would have any impact at all. Usually when you heat something threaded to disconnect it, you need something a lot more serious, like an acetylene torch. Blast it until it is *REALLY* hot (but not melted), and crank it off.
  14. Dec 7, 2015 at 6:40 AM
    tgear.shead
    Jiffy lube? They probably impacted it in the wrong direction and tightened it to 300 foot pounds.
