Seized Grease Zerk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RRDave, Aug 11, 2011.
  1. Sep 3, 2023 at 12:01 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    If your joint is squeaking, Its done, and the others likely not far behind
    Replace it and the other 2 joints and carrier bearing on the rear driveshaft, grease every 5k miles and never have to replace a u joint ever agin.
    otherphone likes this.
  2. Sep 3, 2023 at 1:38 PM
    Waasheem
    Waasheem
    2007 xrunner
    Wow, old thread revival.
    I touch lotsa zerks. Sometimes more than 100 in a day, occasionally none.
    It doesn’t take much damage to the male zerk to cause grease not to go in. Also if it hasn’t been lubed in a really long time, the grease that’s in there can be rock hard. Sometimes you gotta unscrew it, dig it out with a drill bit or cotter pin bent 90 degrees. Squirt some penetrant in before putting the zerk back on. Sometimes that’ll get it to clear. If not you could try something called a grease joint rejuvinator. Below is the one I use. I fill it with oil & penetrant mixed. Sometimes using a new zerk & moving the part helps. If all that didn’t work sometimes leaving the penetrant in there & trying again next time will work. Meaning I lubed all of them except the one, then next time 3 months later when it’s time to do it again, I lubed them all and the one clogged one took grease after that penetrant was soaking in there.
    https://www.amazon.com/Lincoln-Lubr...ase+joint+rejuvenator+lincoln+,aps,175&sr=8-9
    Use safety glasses. Getting penetrant squirted in your eye is no fun.
  3. Sep 3, 2023 at 5:39 PM
    Clearwater Bill
    Billy
    Largo Florida
  4. Sep 3, 2023 at 7:27 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    If the u-joint has never been greased, my guess is the grease in the passageways of the joint has gotten hard from the temperature cycling. Replace them.
  5. Sep 3, 2023 at 7:49 PM
    Clearwater Bill
    Billy
    Largo Florida
    A small nail punch with a concave tip to give it a tap after some squirts of PB blaster would likely work.
  6. Sep 3, 2023 at 7:55 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Tap on that little ball inside the jerk with a hammer,it most likely will then allow grease too flow into the joint.
  7. Sep 3, 2023 at 7:59 PM
    Waasheem
    Waasheem
    2007 xrunner
    What’s with the word ZERK? My iPad refuses to let me type it and corrects it into zero. The iPhone thinks it’s a misspelling too. It’s a grease zerk. Not zero.
  8. Sep 3, 2023 at 8:12 PM
    TacoTuesday1
    SD CA
    them folks don't do hand work
    well, would ya look at that
    LCA was squeaking like hell
    Greased it, because it's free
    now the squeak is gone
    EL DUDE likes this.
  9. Sep 6, 2023 at 11:36 AM
    Shakezula
    Shakezula Active Member
    Austin, TX
    2011 Grey Tacoma DC 4WD
    ARE Camper shell
    Lol yeah sorry y'all, I have 500 tabs across YouTube, TacomaWorld, etc. open trying to figure it out. I thought this tab was a post I had started.
