Seized spark plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FTB530, Mar 3, 2017.
  1. Mar 3, 2017 at 11:41 AM
    FTB530
    FTB530 [OP] Well-Known Member
    Yuba City Ca.
    2005 toyota tacoma
    level kit,air raid intake,
    Clearwater Bill. It is not the reason, I have actually been researching and looking at every type of truck on the market for the last two months, just been real hard to swallow paying 40+K for the next one, this just might be the straw break, i can't keep putting money in this truck.
  2. Mar 3, 2017 at 11:43 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    It's a no-no to mess with plugs on a warm engine, could compromise (strip) the threads.
  3. Mar 3, 2017 at 11:44 AM
    FTB530
    Yuba City Ca.
    2005 toyota tacoma
    Are you saying buy using anti seize I created the problem, I have read not too and you should use antiseize, Who to believe huh.
  4. Mar 3, 2017 at 11:47 AM
    Clearwater Bill
    Billy
    Largo Florida
    I understand. Of course there is no law saying you have to buy new either. There are nice used choices available too.
    I think you can fix your current issue for under $10 and some patience.
    When you consider that $40 large and what it could be doing investment wise (if you are a cash buyer) or what you could do with payments if you were to finance, you can spend a fair chunk of change on your truck and still be way ahead. If you can maintain it for 3 monthly payments a year, you're doing fine. And don't include things like tires, brakes, etc that the new ride will need too...........
    Good luck with your plugs.
  5. Mar 3, 2017 at 11:48 AM
    JoshO
    JoshO Well-Known Member
    Josh
    Baltimore MD
    2012 Double Cab 4x4 TRD Sport (Silver)
    Pop a Lock Bolt Codeable Tailgate Lock, Tyger Tonneau Cover, Stubby Antenna, Led Interior Lights, K&N Series 63 CAI, AVS In-Channel Visors. Upcoming Cat-Back Exahust and Lift kit
    Well I just did my plugs and they were tough but I got them out. I read not use anti-seize as it could mess with the Torque specs, plus according to NGK they have anti-seize coating on the threads of the plugs I purchased.
  6. Mar 3, 2017 at 11:53 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    X2 done this before and worked perfectly
  7. Mar 3, 2017 at 11:54 AM
    Clearwater Bill
    Billy
    Largo Florida
    That they do. So a bit more, if needed to insure even coating, isn't gonna do anything to any torque reading that the material it came with did.
    Torque values are pretty low anyway. I do mine by feeling the crush washer collapse, then just a pinch more.
    Jimmyh and SOSC like this.
  8. Mar 3, 2017 at 11:55 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    OK, I'm not disputing ... bit do you or others have any literature on this?? I'd like to better understand.
    In the past with severely stuck (3/8 - 1") bolts, socket hear we would use a torch with a pin point flame to heat the bolt to read hot then hit it with an impact. Never failed ... just saying.
  9. Mar 3, 2017 at 12:00 PM
    Blockhead
    Pittsburgh, Pa.
    Aluminum engine heads are soft and more susceptible to stripping when engine is hot. You're supposed to avoid removing and/or installing plugs when hot.
    Pabloeeto likes this.
  10. Mar 3, 2017 at 12:18 PM
    Tacoma Mike
    Southern Maine
    I've paid a good part of my house from fixing never seize issues.
    Especially from spark plugs.
    Never never never never use that crap. It's a high temp area and drys and hardens. Then you can't move it and it almost acts like locktite. Then when you move it it starts to Gaul the threads and cross thread. Now if you get them out you need to run a tap through those threads to get rid of the rest of it. A light oil presence is all you need for installing plugs.
    Do whatever you want. But no problems for 170 some odd thousand miles and you change them and add never seize and now???
    FTB530[QUOTED][OP] and Kolunatic like this.
  11. Mar 3, 2017 at 12:55 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    So then why do OEM WRAF sensors and O2 sensors come with copper based antiseize packets, and or on the threads already? o_O
    CurtB likes this.
  12. Mar 3, 2017 at 1:03 PM
    Tacoma Mike
    Southern Maine
    Not aluminum application
    Kolunatic likes this.
  13. Mar 3, 2017 at 1:05 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    How do dealers change spark plugs when customers bring their cars in hot?
  14. Mar 3, 2017 at 1:26 PM
    Clearwater Bill
    Billy
    Largo Florida
    Wait till they cool.
  15. Mar 3, 2017 at 1:27 PM
    #35
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i never used it before until i read it hear on TW. the last time i used it, i did have that weird feeling pulling them out like something was galling. next time, i might forgo it.
    Tacoma Mike[QUOTED] likes this.
  16. Mar 3, 2017 at 1:29 PM
    #36
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    well, now what do we do if we already put some plugs in with some seize on them? less than 2k miles ago might I add
  17. Mar 3, 2017 at 1:36 PM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Thanks for the clarification.
  18. Mar 3, 2017 at 2:01 PM
    #38
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I use a little copper antiseize (loctite brand ;) ) on mine every time. Works great. Tighten them down just like Clearwater Bill said. Easy peezy. Of course, I likely change mine more regulalry than most as well.
    Clearwater Bill likes this.
  19. Mar 3, 2017 at 2:24 PM
    #39
    FTB530
    Yuba City Ca.
    2005 toyota tacoma
    Thanks for all the comments and advice guys ,maybe ill get in the mood to try again in a couple of days.
  20. Mar 3, 2017 at 2:39 PM
    #40
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Nothing, you'll be fine.
