Seized sway bar end link
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NINETY2, Oct 20, 2012.
  1. Oct 20, 2012 at 10:26 PM
    NINETY2
    NINETY2 [OP] Active Member
    Edmonton, Alberta
    06 DCLB TRD Sport
    OME 3" Lift (885, CB Drop, 2" non-TSB AAL) BHLM Debadged Tint allround
    So I figured I would start my lift tonight,
    And the very first bolt I went to take off is seized!
    The upper sway bar end link. I couldn't believe it!
    I've pb blasted the shit out of it, tried holding it with vice grips, tried an Allen wrench holding the stud while using a crescent. No luck with anything.
    It's an 06 taco and up here in Canada roads are salted so everything is rusted to shit.
    If I can't get it off, I'll order new end links, and cut them off when i get them.
    But I figured I would make a quick post in hopes that someone might have the answer to getting this bitch off.
    Thanks!
  2. Oct 22, 2012 at 8:53 AM
    Azntrutek
    Azntrutek Well-Known Member
    ATL
    08 TRDsport -Towpackage
    2".5 lift, HID head lamp and HID lights, color match tonneau cover and running board.
    get the air/electric angle grinder with 3.5 or 4" metal cutting disk. then cut it off with the surface of the cutting disk facing the the side of the control arm/ rocker arm ( i dont know what is the name of it). if you cant cut the nut off then use a grinding disk and grind the hell out of that nut. good luck
  3. Oct 22, 2012 at 9:15 AM
    speedjunkie13
    speedjunkie13 Well-Known Member
    a work in progress
    A torch (mapp or oxy/acetylene) used with some penetrating spray after you heat it works wonders. A long as you are aware of what you are doing and aren't a dumbass it won't hurt anything. most times you can actually salvage fasteners.
    If this fails, then you can still cut it off.
  4. Oct 22, 2012 at 9:18 AM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    We just cut some end links on the 04 4Runner last night. Got tired of fighting with it.
  5. Oct 22, 2012 at 9:27 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Most important part of a lift is spraying PB on every bolt & nut every day for a week before you go to remove it.
    Try heat yet?
  6. Oct 22, 2012 at 9:40 AM
    cintocrunch
    cintocrunch Special Substitute Guest Member
    MD
    2012 DCSB TRD Sport MGM 6MT
    Anytime fogs, Leer Tonneau
    This...next is heat...next is my humangous impact gun if I can reach both sides...last is cutting...
  7. Oct 22, 2012 at 9:42 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    mine was seized as well. i actually gave up and took it to a shop, where they heated it and it came off right away...of course..
