Selecting a mild lift (TRD Baja TX Pro + Icon AAL)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Aug 3, 2015.
  1. Mar 28, 2017 at 2:51 PM
    #181
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    1/4" top plate spacers provide 1/2" lift.
  2. Mar 28, 2017 at 2:58 PM
    #182
    Nateclimb
    Nateclimb Well-Known Member
    UT
    15 Inferno Pro SC'ed
    Ohh, okay, thanks!
    Would you do it that way if you did it again?
  3. Mar 29, 2017 at 8:43 PM
    #183
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    On the fence. A touch more lift might be nice, but if doing so I'd also leave the overloads in the rear. Really it does what I need it too and handles exceptionally well with a good alignment without UCAs, so probably not.
  4. Mar 30, 2017 at 1:24 PM
    #184
    Nateclimb
    UT
    Any specific place you recommend getting the Icon AAL from or the place to get the best price?
  5. Mar 30, 2017 at 3:47 PM
    #185
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    syswalla likes this.
  6. Apr 26, 2017 at 9:15 PM
    #186
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Why would you leave the overloads in?
  7. Apr 26, 2017 at 9:18 PM
    #187
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I was saying if running 1/4" spacers up front which provide 1/2" more lift, I'd leave the overloads in for 1/2" more lift in the rear to keep it balanced. If not running the spacers up front I'd leave the overloads out.
  8. Apr 26, 2017 at 9:22 PM
    #188
    RyanL
    Indiana
    Perfect, thanks. Great writeup / thread btw, it's been super helpful.
  9. Nov 28, 2017 at 10:58 PM
    #189
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I've revised this thread to be more about the process than the solution, to be more helpful and educational to others.
    beachingtaco likes this.
  10. Dec 21, 2017 at 9:47 AM
    #190
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Been reading this thread gotta say very nice write up. I love the amount of detail an research that has gone into this. Very thought out an deligent. I’ve read your other threads about lights I’m going to go that route. I ended up with icon setup front an rear with UCA’s for a killer deal would of done this instead if I seen it prior.
    crashnburn80[OP] likes this.
  11. Dec 21, 2017 at 8:02 PM
    #191
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    I didn’t make it through the entire thread so if someone else already pointed this out my apologies.
    Your first post incorrectly states the progressive / digressive shocks change their stiffness as they change their position. Shocks change their force with velocity not position. Progressive shocks will have a concave up shaped curve on a force as a function of velocity and digressive will have concave down. This does not mean that the force from the shock is decreasing with increased velocity, it just means the RATE of increase is either increasing (progressive) or decreasing (digressive).
    PDXKid and crashnburn80[OP] like this.
  12. Dec 21, 2017 at 9:35 PM
    #192
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Excellent catch, sometimes I over simplify in explanation. Should be position vs time, aka velocity. I’ll update the thread accordingly when I am not on mobile.
    PDXKid and Lostsheep[QUOTED] like this.
  13. Dec 21, 2017 at 10:07 PM
    #193
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    Explaining shock behavior without using calculus terms is difficult to say the least.
  14. Feb 11, 2018 at 9:05 AM
    #194
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    Just wanted to post these here and see if there’re any interest.
    2nd Gen Baja TRD Bump Stops with the correct washers. 35.00 shipped.
  15. Feb 12, 2018 at 4:45 PM
    #195
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    @crashnburn80
    How is your rear suspension holding up with the AAL since it's been 2 years now? There is quite the lively debate in the 3G forum about whether the rear shocks handle lift well or not. I venture to say they will but you've documented your setup well over the years so I'm curious to know. Granted I know the part numbers on the Baja and Pro parts are different, but I'd have to believe they are at least equivalent.
    What's your take now that you've put some time and miles on your setup?
  16. Feb 13, 2018 at 1:08 AM
    #196
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    No complaints or noticeable sagging, the truck drives fantastic. In the pro/baja the shocks are extended travel, on the 2nd gen they use the same Bilstein shock bodies and it is just valving and finish differences between them. 3rd Gen Pro uses completely different Fox shocks, so it isn't quite the same comparison. It all depends though on how much lift. I lifted my rear nearly the same as the additional extended travel provided by the Baja rear shocks, 1.5". Over-lifting on stock travel shocks will cause issues for the shock. But whether it is actually an issue you notice depends on how much lift and how you use your truck.
  17. Feb 13, 2018 at 3:52 AM
    #197
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    I wasn't 100% clear in my original question. I purchased the Bilstein kit, not the Fox kit, so I was curious about the rear pieces. Your experience pretty much sums up what I'd expect, though.
    Thanks!
  18. Feb 17, 2018 at 7:44 AM
    #198
    tommymoe
    tommymoe Member
    Tom
    Upstate NY
    13 DCSB TRD Off Road
    TRD Exhaust, K&N, Access Cover, Yaesu FT-7900R
    I apologize if I missed this, but are the front shock/springs assemble when you get the kit? If not, how hard is it to put them together. I just did struts on a Sienna, but they were pre-assembled. Worst part was rusty hardware.
    Great thread by the way. Been watching it for a while. Going to install this in the spring on my sagging 2013 DCSB TRD OR. Steering and handling are getting really weak now after 5 years and lots of off-road/hauling. Unfortunately I have the 3 leaf pack, but still planning the AAL. Thanks.
  19. Feb 17, 2018 at 8:12 AM
    #199
    1truckdriver
    1truckdriver BRO
    Daniel
    Rancho Cucamonga, Ca.
    '15 DCSB Off Road 4x4 SuperWhite
    TRD SuperCharger SCS Rays 10
    Front springs and struts come pre assembled. You good to go
    * 2015 Pro kit pre assembled
    *Baja kit does not come assembled.
  20. Feb 17, 2018 at 8:18 AM
    #200
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Id suggest to start trying to find a 3+1 pack for cheap that someone is removing for a lift. Pretty common part for people to get rid of.
