self amplified sub not putting out much sound
Discussion in 'Audio & Video' started by rab89, Apr 17, 2012.
  1. Apr 17, 2012 at 2:56 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I have a sound ordnance b-8pt self amplified sub, I used it in my 01, then briefly in my 2008 and it worked great, now I have wired it into my 2012, using the high pass connections, split into the rear speakers.
    My ground is the only questionable thing, I sanded off a painted bolt but that would be the only thing I think isn't connected perfectly.
    I tapped into the grey ignition wire on teh back of the HU for my remote wire.
    Basically it's on, but barely putting out any sound, I can feel it shake a bit, but even on max it's not putting out much for sound.
    any ideas?
  2. Apr 17, 2012 at 10:19 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    K still working on this, I can put my ear to it and get a tiny bit of sound, but it seems like its trying to play the actual song, an not just bass like a sub should...
    Its like a really faint speaker
  3. Apr 18, 2012 at 3:58 AM
    Tommy
    Tommy Well-Known Member
    Tom
    Indiana
    2010 Access cab SR5 4x4
    May be a dumb question but do you have the power mode switch in high power?
  4. Apr 18, 2012 at 9:19 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    yea I tried both to be sure
  5. Apr 18, 2012 at 10:38 AM
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    High pass means passing the higher frequency sounds, but you are hooking up a sub - the exact opposite.
    Either there is a word use error, or else you need different wiring so that the sub is fed from a low pass (or full spectrum) connection.
  6. Apr 18, 2012 at 10:40 AM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    Got a get a high low converter then use RCA s
  7. Apr 18, 2012 at 10:48 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I think you're right, it's the "high power input"
  8. Apr 18, 2012 at 8:12 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    so i wanna get this fixed tonight, any thoughts?
  9. Apr 18, 2012 at 8:21 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    i would get a multi meter and see wat voltage ur getting to that sanded bolt ur grounding it to
  10. Apr 19, 2012 at 10:18 AM
    sun
    sun Well-Known Member
    Memphis
    2011 PreRunner
    Pioneer avic-z130bt with axxess aswc and rear cam mod, audiovox 10 flip down monitor, Pyle pl76d headrest monitors, kicker cvr tens wired down to one ohm with hifonics Brutus 1200.1, Clazzio seat covers, 20% tint on front windows, polished factory exhaust, peragon retractable bed cover, pop n lock tailgate handle with dei actuators for automatic lock, viper 5901 alarm remote start with viper smart start, hid bixenon 4500k headlights with 4500k fog lights, led map license plate lights and dome lights
    Is ur 2012 jbl?
  11. Apr 19, 2012 at 10:32 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    nope
  12. Apr 21, 2012 at 7:05 AM
    OneMentalCase
    OneMentalCase Well-Known Member
    South Florida
    10 Pyrite LB
    Did you get it fixed yet??
  13. Apr 22, 2012 at 9:01 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    haven't had a chance yet. I'll check my ground tomorrow i guess
