Self Recovery Advice
Discussion in 'Off-Roading & Trails' started by gonzo6up, Jan 22, 2009.
  1. Jan 22, 2009 at 10:03 AM
    gonzo6up
    gonzo6up [OP] Well-Known Member
    Middle Tn
    09 tacoma SR5 4x4 sport
    tint/ vent visors/ seatbelt chime mod/ DTRL Mod
    I'm looking for some advice on some basic self recovery items that i would need in case i get stuck by myself. I don't off-road by myself but one of my hobbies (arrowhead hunting) takes me through some rough terrain sometimes( logging roads/ creeks) I usally always have a buddy with me so i not to concerned about the saftey issue of being alone but we are always in one truck. I know the obvious would be to get a winch but that's not in the budget yet. Any ideas would be appreciated.
  2. Jan 22, 2009 at 10:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    You can get a cheap come along until the funds are available for a decent winch. I also suggest carrying some small sections of 6x10 board (2' to 4'). Placed infront of the wheels, they can give you enough traction to crawl out of ruts or muddy holes. It is also good to carry a recovery strap and/or a long chain.
  3. Jan 22, 2009 at 10:24 AM
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    Here is a little info.
    Get a set of chains for the rear and practice putting them on at home first. This will help ya understand how they go on easier if your stuck in the mud. Chains will help ya get out of a lot of muck where as tires just spin. Keep a pair of channel locks to tighten the chains unless you get cam lock type chains. Make sure you get the heavy duty off road chains because they are designed for heavy off road use.
    Then get a hilift jack and some long straps and or chain. The hilift jack can be used as a winch, slow but affective.Also get some shackles for attaching the chain or straps. Also if your stuck in mud or sand try to find hard objects like brush, branches or logs to get under your tires for traction.
    Hope this helps a little.:)
  4. Jan 22, 2009 at 10:25 AM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    Highlift can be use a winch. some recovery straps and shackles. ^^^he types faster^^
  5. Jan 22, 2009 at 10:33 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    Maybe try a come along. One end to the truck, one end to a tree and lots of elbow grease.
  6. Jan 22, 2009 at 10:58 AM
    gonzo6up
    Middle Tn
    cool guys, i'll pick up either a come-along or a high lift jack for now. i already have the chains. thanks for the info.
  7. Jan 22, 2009 at 11:08 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I would suggest the HiLift instead of the come along simply because it will still be useful after you get a winch.
  8. Jan 22, 2009 at 11:25 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
  9. Jan 22, 2009 at 11:38 AM
    Snyperx
    Snyperx Seniore Marcos
    Tree strap would be a good thing to grab as well. Didn't see that mentioned.
  10. Jan 22, 2009 at 12:11 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  11. Jan 22, 2009 at 5:06 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    There's an art to using a Hi-Lift as a winch - you'll be needing 2 chains or at least one chain and a non-stretching strap. Do some practicing at home before you're knee-deep in mud!
  12. Jan 23, 2009 at 8:31 AM
    gonzo6up
    Middle Tn
    thanks for all the good links and info. all i need to get is a high lift jack and some shackles and i should be ready to go.
