Self Taught Tuning : By Mooseditty17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mooseditty17, Mar 19, 2021.
  1. Mar 29, 2021 at 6:30 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    awesome thread moose :hattip:
    Mooseditty17[OP] likes this.
  2. Mar 29, 2021 at 9:00 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    So here's a question for you guys - can you explain why the truck "surges" a bit when it shifts gears? Is this the "rev hang" you guys have mentioned in other threads? Or is this something else - I'm suspecting my transmission fluid might be low since the truck hangs a bit during gear shifts, even after it's been warmed up.
  3. Mar 29, 2021 at 9:07 AM
    Shellshock
    Iowa
    Rev hang is a manual trans thing
    trans fluid is definitely worth checking
    I think moose and some others have been tweaking AT parameters to smooth out shifting. Sounds like @PapaRee has worked some magic, maybe he can provide some additional insight
    PapaRee, Mooseditty17[OP] and C41n like this.
  4. Mar 29, 2021 at 9:11 AM
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Best thread ever.
    Mooseditty17[OP] and Shellshock like this.
  5. Mar 29, 2021 at 9:15 AM
    SELAroadrunner
    SELAroadrunner Well-Known Member
    Ron
    WSNC
    17 Sport
    wheel decals
    Program of study: M.MD
  6. Mar 29, 2021 at 10:13 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Are you tuned? The surge could be rated to throttle limits set for each gear. You will end up with a surge If they are set too far a part for a given accelerator positions. There is also torque converter clutch engagement. It will cause RPMs reduction during the engagement.
    Hanging shift is byproduct of increased limits and some tunes are going into a single torque map, which needs to be dialed.
  7. Mar 29, 2021 at 10:18 AM
    tacoman45
    Orygun
    I am tuned. I have been using VFTune (33" Premium THX) so far and the "surge" is probably the only thing needing to speak to - everything else is great. I did reset the LV's about 120 miles ago, so I'm wondering if the transmission is still acclimating to the new tune.
  8. Mar 29, 2021 at 10:23 AM
    Vlady
    Issy, WA
    Happens in 4th gear?
  9. Mar 29, 2021 at 10:40 AM
    tacoman45
    Orygun
    No, I'd say it's less noticeable in the higher gears. You feel it more under throttle and in the lower gears - think 1st thru 3rd
  10. Mar 29, 2021 at 12:46 PM
    Tech708CC
    Tech708CC Well-Known Member
    2020 trd off-road
    So I went through the same except with D3 Performance software. He has less parameters it seems but it does make it a bit easier to learn. I have been tuning for several years with hptuners on other applications so tuning is not new to me.
    Op just a fyi I did the same thing on the 3-4 shift and yes it felt like I was loosing a driveshaft.
    Most of my work in the tune has been in cam angles and ignition timing parameters.
    What have you found that yours liked in the intake and exhaust cam angles?
    What about ignition timing on 93 octane?
    Have you done any 0-60 Draggy passes or quarter mile?
    I have seen quite a bit of gains with just some relatively small changes.
  11. Mar 29, 2021 at 5:49 PM
    Mooseditty17
    Mooseditty17 [OP] Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Are you running a user made tune or your own?
  12. Mar 29, 2021 at 5:52 PM
    Mooseditty17
    AJ
    WI
    Have you tried to combine your torque shift maps? all but 4 low and sport? That really seems to make things very predictable, as well as ensuring ALL your shift maps match the Primary. This will require some dialing in though.
  13. Mar 29, 2021 at 5:54 PM
    Mooseditty17
    AJ
    WI
    Raising base intake valve angles in the higher load areas make the truck "hold" a gear much better. Seems to give it some grunt. Gotta watch the Knock F/B values though and adjust timing accordingly
  14. Mar 29, 2021 at 7:17 PM
    4x4G
    4x4G Well-Known Member
    Gavin
    2019 TRD Sport, 4x4
    Motofab 3” in the front 1” in the rear 17” Fuel Vandals 285,75,17 Hercules Mud Terrains
    Anyone else not been able to up their red line? I was looking to get to 7k (or somewhere in the ballpark) really just for shits and giggles but when I flashed it I can’t get it to go past 6k?
    I’ve tried twice in the last half hour or so (getting on the highway)
  15. Mar 29, 2021 at 7:23 PM
    #35
    Losv
    Losv Active Member
    2019 Tacoma TRD Off Road 4x4
    Thanks for making a tutorial. If I decide to do my own tube I will for sure have this saved and available for when I need it.
  16. Mar 29, 2021 at 7:57 PM
    #36
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Well done! Thanks for putting this together.
    If you or someone can explain the octane settings (ignition, spark control, etc) that would be appreciated!
  17. Mar 30, 2021 at 2:07 AM
    #37
    Mooseditty17
    AJ
    WI
    Look at the lat part of first post on here. It explains this. It also states you can go too far. I get about 6800 with the values pictured. You're not allowing the truck to go fast enough to rev any higher, that's all.
  18. Mar 30, 2021 at 4:03 AM
    #38
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    That's a struggle with AT's. Shift logic is dictating that you shift before reaching redline. With the MT's you can reach that redline. Gearlock would do the trick for AT's
    Or as canadian-wildlife-titties says, give it moar skinny and hope it doesn't upshift. Lol
    Shellshock and Mooseditty17[OP] like this.
  19. Mar 30, 2021 at 6:52 AM
    #39
    Shellshock
    Iowa
    :rofl:
  20. Mar 30, 2021 at 11:13 AM
    #40
    Tech708CC
    2020 trd off-road
    How is the shift schedule set up in the ov software? Do they use OSS?
    I data logged mine to find the OSS for a good wot shift.
