Self Taught Tuning : By Mooseditty17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mooseditty17, Mar 19, 2021.
  1. Jun 7, 2021 at 12:00 PM
    #101
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    That's exactly what I do.
    New tune for someone also gets a reset. Heard stories of people having high trans temps after a flash, resetting everything made that go away. So I do it to be on the safe side.
  2. Jun 7, 2021 at 7:44 PM
    #102
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    So does anyone know what calibrate TCU does?
  3. Jun 7, 2021 at 8:33 PM
    #103
    Shellshock
    Iowa
    Calibrates the tcu
    It’s the transmission control unit. You can adjust pressures and stuff
    C41n likes this.
  4. Jun 7, 2021 at 8:35 PM
    #104
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    The VF to do this isn’t released yet right?
    C41n likes this.
  5. Jun 7, 2021 at 8:36 PM
    #105
    Shellshock
    Iowa
    Correct
    1.3
    it’s also an additional unlock
    Ex 04b04 ecu + 04b04 tcu
    uploadadventure[QUOTED] and C41n like this.
  6. Jun 7, 2021 at 8:50 PM
    #106
    Chadr7858
    Chad
    Colorado
    Not tight
    shotgunbilly420 and C41n like this.
  7. Jul 11, 2021 at 6:46 PM
    #107
    WhtsDatButtonDo
    WhtsDatButtonDo New Member
    2019 Toyota Tacoma 4dr. A/T
    Stock for now
    Good Information! Much thanks to everyone for the help.
  8. Dec 16, 2021 at 10:39 PM
    #108
    Gonks
    Gonks Well-Known Member
    OC
    SOLD 2020 White TRD Offroad 4x4
    Thanks for sharing this information. I have noticed that a lot of the Taco community just has shops do the tuning, so it made me smile to run across folks doing garage tunes as well, that would make me feel more comfortable.
    Bee Finn and Willys714 like this.
  9. Dec 17, 2021 at 6:38 AM
    #109
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    The tuning community here used to work together before "things" happened...
  10. Mar 12, 2022 at 6:55 PM
    #110
    fitsofrage88
    fitsofrage88 Well-Known Member
    ATX
    Curious are there any links anyone know of per the Tundra, with basics and some editing tutorials?
  11. Mar 14, 2022 at 8:02 AM
    #111
    MPL Ops
    MPL Ops Active Member
    2018 Tacoma
    When’s the next registration for Moose Knuckle U ??
  12. Apr 16, 2022 at 3:28 PM
    #112
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    In the first post there is reference to the radius of the tire. Is this to get the speedometer back to some accuracy after a tire size change? If so does it also correct the cruise control speed display?
  13. Apr 16, 2022 at 4:00 PM
    #113
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    that Is for shift points, not to correct speedometer — you would need an in-line calibrator from rough country or hypertech
  14. Apr 16, 2022 at 5:13 PM
    #114
    Toycoma2021
    It would be so nice if one of these tuners could take care of that little problem of the changing tire size AND the Cruise Control display. But, I'd bet it is not in the engine, nor the transmission, but the Brake control unit. Probably nobody wishes to fiddle around with that CPU.
  15. Apr 16, 2022 at 5:51 PM
    #115
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    It's not that no one wishes to mess with it. There's simply no access.
    ktbell444 likes this.
  16. Apr 16, 2022 at 8:12 PM
    #116
    Toycoma2021
    So there is no CAN bus access through Techstream if I interpret your comment correctly. I would think Toyota must program the Brake Module somehow at the factory for the different sizes of tires they offer on the trucks. Has anybody, to your knowledge looked into a more direct avenue of access at the module itself? Or do they use different sizes, or tic counts on the wheel sensors. Obviously I don't know enough yet to be too dissuaded.
  17. Apr 16, 2022 at 8:52 PM
    #117
    mZiggy
    mZiggy Honey badger
    Marc
    No idea, but Mat/OVTune looked into it pretty extensively and determined that it's a different computer that he couldn't access. Although he was looking for a way to edit it from within the tunes, via the OBD port. Maybe there really is another method of access elsewhere.
    This is probably why the hypertech is an in-line solution, rather than a reprogrammed one. And I've never used one but if I remember correctly, it's behind the dash or gauge cluster. I'm sure someone will correct me.
  18. Apr 17, 2022 at 6:54 AM
    #118
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    Correct. You program it with a laptop to set up your tire size and then it plugs in-line behind the gauge cluster
    mZiggy[QUOTED] likes this.
  19. Apr 18, 2022 at 10:30 AM
    #119
    Toycoma2021
    Yes, I’m looking for something that also corrects the cruise control display too. I know no one has reported doing so thus far.
  20. Apr 18, 2022 at 10:37 AM
    #120
    758_Moto
    On my way to work this morning I engaged CC just to see...needle was at 75mph and the CC display speed read 74mph. This is exactly how it was for me with stock tires, the CC MPH always read 1-2mph less than the speedometer needle which read a few MPH faster than I was actually going.
