selfmade new tie down points (not only for motorcycles)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jonnie666, Mar 20, 2012.
  1. Mar 20, 2012 at 10:34 AM
    jonnie666
    jonnie666 [OP] Active Member
    Hamburg/Germany
    SR5 V6 TRD
    i use two aluminum plates (5mm thick) with 2 holes in every plate for each side.
    just two holes in the bed(each side).
    the plate under the bed has to be a little smaller.
    use self locking nuts under the bed.
    thats it !!!
    sorry for my bad grammar:rolleyes:
    and in the back you just have to remove the tail lights and just drill a hole.
    use a big (in german : unterlegscheiibe) wearing part (english??)
    the german word is : ringschraube does it mean ringbolt in english ?
  2. Mar 20, 2012 at 10:36 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You should use larger plate washers on the underside. A simple nut could potentially crack the bed or pull through if torqued enough. Otherwise, great idea! :thumbsup:
  3. Mar 20, 2012 at 10:43 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    He says that he used another steel plate, only a bit smaller, under the bed.
    I think he means he made a steel plate sandwich, with the bed material in the middle.
    Should hold very well, good job OP!
  4. Mar 20, 2012 at 10:45 AM
    Pugga
    Massachusetts
    Gotcha, I thought he did something different. Yeah, that should be pretty damn strong!
  5. Mar 20, 2012 at 10:51 AM
    jonnie666
    Hamburg/Germany
    SR5 V6 TRD
    one plate upside and one plate downside
  6. Mar 20, 2012 at 10:53 AM
    jonnie666
    Hamburg/Germany
    SR5 V6 TRD
    sandwich describes it very good
  7. Mar 20, 2012 at 10:53 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    First class! BTW, no apologies needed for grammar. Yours is better than most of us US types.
  8. Mar 20, 2012 at 11:06 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Essentially the same thing. Technically what you have pictured is an eye bolt. A ringbolt is an eye bolt with a ring through the 'eye'
    ringbolt:
  9. Mar 20, 2012 at 11:17 AM
    jonnie666
    Hamburg/Germany
    SR5 V6 TRD
    one is never to old to learn ...
    thank you xJuice
  10. Mar 20, 2012 at 1:25 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    nice mod!
  11. Mar 20, 2012 at 1:38 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Good Idea, thank you.
  12. Mar 20, 2012 at 4:15 PM
    ryansummit
    ryansummit Well-Known Member
    NY
    POWERLESS '08 v6 4x4 access cab
    smoke tails, safety rack, coffee stains, caulk, paint, tar, sawdust, foul odor
    that is an ingenius mod
    ive been lookin for the best way
    to install more tie down points on the floor of the bed
    but this will be way more accessible
    when ive got a big load
    man i got a busy weekend
  13. Mar 20, 2012 at 4:16 PM
    Aw9d
    Aw9d That one guy
    Awesome mod!
  14. Mar 21, 2012 at 1:27 AM
    jonnie666
    Hamburg/Germany
    SR5 V6 TRD
    @ryansummit
    this mod is quick and easy.
    you dont have to remove anything.
    all can be made through the wheel case.
    try to get an eye bolt with a long thread.
    and for the ones in the back use large plate washers.
    the best option is to use stainless steel !!
  15. Mar 21, 2012 at 4:53 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Nice mod man! :thumbsup:
  16. Mar 21, 2012 at 4:55 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Good One. I might look into this. The D rings I placed under the bed bolts are sometimes in a bad spot depending on what I am hauling and this location would be nice.
  17. Nov 15, 2013 at 12:27 PM
    jonnie666
    Hamburg/Germany
    SR5 V6 TRD
    Troublefree for 2 years !!!
