Sell it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeffch, Mar 22, 2024.
  1. Mar 22, 2024 at 7:02 AM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    Grinder, maybe like flapper wheel from top, like you are sanding it instead of cutting and expose valve stem?
    Jeffch[OP] likes this.
  2. Mar 22, 2024 at 7:04 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    If you can get your hands on Unicorn piss. It will free anything
    RIX TUX, Karpata, Steves104x4 and 4 others like this.
  3. Mar 22, 2024 at 7:11 AM
    Jeffch
    Jeffch [OP] Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    haha my wife actually got me one of these not sure I will be able to find it.
    I’ll look later
  4. Mar 22, 2024 at 7:12 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I was gonna use a Christmas tree cutter and get close to the threads.
  5. Mar 22, 2024 at 7:17 AM
    T4R_hereforbearings
    WA
    08 4Runner
    that’s like a fancy burr? I think you will get it handled one way or another.. spinning tool of choice lol
    Jeffch[QUOTED][OP] likes this.
  6. Mar 22, 2024 at 7:19 AM
    mootiger49
    mootiger49 It’s mine, not yours!
    23’ Lunar Rock OFF ROAD. 24’ Underground 4-Runner. 2000 IJM OFF ROAD
    V2 grille OTT Tune 5100’s Pro rims
    s[​IMG]
    spray some of this on each one
    RIX TUX, mrtonyd, Steves104x4 and 4 others like this.
  7. Mar 22, 2024 at 7:19 AM
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    HEAT GUN! Seriously - not too hot, just enough to convince those pesky caps to give it up. You can also orient the caps facing with valves at 12 o'clock and drip some soapy dw solution around the upward facing cap before heating them up.
  8. Mar 22, 2024 at 7:23 AM
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
  9. Mar 22, 2024 at 8:12 AM
    PeteSATX
    PeteSATX Well-Known Member
    2003, Tacoma, V6, 4X4 MT, SR5, TRD
    None, Original Owner, 130k miles
    It's ruined, Part it Out!
    Happy Friday everyone.
    Peter
    Steves104x4 and Jeffch[OP] like this.
  10. Mar 22, 2024 at 9:03 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Damm it is Friday!
    Enjoying work so much I didn’t notice.
    Happy Friday everyone enjoy the day!!!
  11. Mar 22, 2024 at 9:08 AM
    wayne0
    wayne0 Well-Known Member
    Yeah, I made that stoopid mistake too. Had to cut one off with a Dremel. Fucked up the stem. The rest got silicone grease.
  12. Mar 22, 2024 at 9:10 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Lawfarin[QUOTED] and Jeffch[OP] like this.
  13. Mar 22, 2024 at 9:19 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I heard it smells like cotton candy:confused:
    Steves104x4 and Lawfarin[QUOTED] like this.
  14. Mar 22, 2024 at 9:34 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Found this think it should fix me up!
    turbosnail and Steves104x4 like this.
  15. Mar 22, 2024 at 9:58 AM
    #35
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    Yeah, sell it. OR replace the valve stem caps ...
    $1.27 at Walmart
  16. Mar 22, 2024 at 10:59 AM
    #36
    BG_TX
    BG_TX Active Member
    Mr toyota put valve stems and caps on for no reason, they can be removed without any negative consequences. Search 'valve stem delete', tons of threads on this already.
  17. Mar 22, 2024 at 11:08 AM
    #37
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I learned the hard way too. Tried steel, aluminum and even brass. No more fancy hot rod metal caps for me. I use hard black plastic now on all my wheels including Taco and Vette and wife's CRV. My nose gets pimples and other lumps on it and my dog sometimes has poo on his butt, oh well, ha ha.
  18. Mar 22, 2024 at 12:03 PM
    #38
    Clearwater Bill
    Billy
    Largo Florida
    Speaking of such weight savings, I only have 5 lug nuts on each wheel. So you can toss 4 of yours while removing those pesky stems.
    RIX TUX, Steves104x4 and Jeffch[OP] like this.
  19. Mar 22, 2024 at 12:16 PM
    #39
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Good idea across from each other or beside each other?
    I already run helium in my tires floats down the road nicely!
    My 33’s are heavy but I’m getting like 40mpg!
    Downhill a steep downhill with it shut off!:rofl:
    Weather is saying 8-17” of snow tomorrow! May have to go out and play!
    Steves104x4 likes this.
  20. Mar 22, 2024 at 1:06 PM
    #40
    canuck guy
    Alberta
    23TRDOR
    How do you get air in and out of tires without valve stems? Or are you using solid rubber tractor tires? You mean caps right?
