Sell me on a rear bumper!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 85yote09taco, May 10, 2011.
  1. May 10, 2011 at 6:27 PM
    jhodge83
    jhodge83 Any dog under 50# is a cat and cats are useless... Moderator
    SC
    09 Timberland Mica DC 4WD Sport
    wat?
    you're on the west...sshhhh:D
  2. May 10, 2011 at 6:54 PM
    85yote09taco
    85yote09taco [OP] Well-Known Member
    Eric
    York, PA
    Tacoma TRD OR
    3'' OME lift, TRD CAI, Built Right UCAs, 285 Goodyear DURATRACS, black steelies, Fog light anytime, DTRL, Alternating turn signal, Diff breather relocated, Carrier bearing drop, Weathertechs, Bestop, Extended SS brake lines, CBI Sliders w/kickout, Cab mount chop, Total Chaos LCA skids, All Pro skids, Satoshi(HomerTaco), Bruteforcefab ''HC'' rear bumper, Bruteforce Hybrid front bumper
    Nice I appreciate the comments, how hard is the cutting of the bedsides? Is there a method? I'm torn between a few of these bumpers.
  3. May 10, 2011 at 6:57 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    A grinder and patience, with emphasis on patience. I didn't trust myself enough, so I let Mr. ATO make the final cut. You do have a little room for error (like 1/8th inch) due to the application of door-edge moulding to the cut section.
    Also, if you need the pro-tip on installing the edge moulding, let me know. I finally got it figured out last weekend.
  4. May 10, 2011 at 7:02 PM
    85yote09taco
    Eric
    York, PA
    Tacoma TRD OR
    rep for jandrews, Is there an install thread somewhere that I'm not seeing, for the ATO? I likey
  5. May 10, 2011 at 7:06 PM
    jandrews
    How handy are you? Depending upon how you feel with tools, it could either be self explanatory or Jesus-Take-The-Grinder.
  6. May 10, 2011 at 7:09 PM
    85yote09taco
    Eric
    York, PA
    Tacoma TRD OR
    You know there is a saying for a guy like me it goes....."jack of all trades, master at none" I do get nervous when it comes down to doing crazy amounts of damage. But I believe if i studied a thread and took my time I would be fine.
  7. May 10, 2011 at 7:15 PM
    jandrews
    It helps to have three people.
    Basic process:
    - Remove stock bumper/hitch assembly. Heavy.
    - Measure twice, tape once.
    - Rough cut with grinder ~1" below final cut level.
    - Clamp new bumper in place to check rough cut.
    - Final cut. Take your time. Be less nervous than I was.
    - Debur, Prime, Edge Mould.
    - Install panel braces.
    - Bolt on new bumper. Heavy.
    There's a little detail to the cut under the taillight section. You'd wanna check with Mr. ATO on that.
  8. May 10, 2011 at 7:18 PM
    85yote09taco
    Eric
    York, PA
    Tacoma TRD OR
    The only part I dont understand is the edge mould. Is that something that is supplied with the purchase, I believe I know what youa refering to but would like a better idea.
  9. May 10, 2011 at 7:21 PM
    jandrews
    I found a picture where it's fairly visible. This picture also happens to have Larry's ass crack in it.
    Bear with me.
    See the black edging running along the bottom of the cut quarter panel from the taillight to the fender flare? It's standard door-edge moulding from your local auto parts store, pretty cheap. You slap it over the cut section after priming to give it additional weather resistance and a nice factory look.
  10. May 10, 2011 at 7:32 PM
    85yote09taco
    Eric
    York, PA
    Tacoma TRD OR
    nice, thanks i figured thats what it was. I guess the only part that I'm slightly uneasy about would be the cutting. But maybe I'll get more input from the guys at ATO.
  11. May 10, 2011 at 7:43 PM
    pat's taco
    pat's taco Well-Known Member
    Alabama
    2013 XSP-X DC
    Weathertech, ECG Fabrication retro grille, K&N intake, Magna flow dual, UWS low profile toolbox, NFAB & 30" light bar bumper, Spidertrax. 1.25, Mob Amour, XSP-X package
    thats a pretty sweet tree stump jack you got there and as for the ass crack :puke:
  12. May 11, 2011 at 2:56 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
  13. May 11, 2011 at 3:33 PM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    You don't really care, do you.
    Sure there are better and sturdier, but also usually heavier and more expensive. Not everyone can afford the "best", or like the looks of what may be considered the "best". It's a matter of compromise between looks and function. Most anything else aftermarket is better than the 1/10000 of an inch thick stock bumper IMO
  14. May 11, 2011 at 3:38 PM
    Jason'sLawnCare
    I agree but as far as the heavier part goes, I like the extra weight over the rear tires. The rear end of our trucks are pretty light as I'm sure you know and having some more is nice in the rain.
  15. May 11, 2011 at 3:39 PM
    #35
    jhodge83
    SC
    wat?
    i agree with them being heavier and anything being better than stock, but the price concerns arent there. the AP rear bolt on + wraps is $800. My ATO HC (minus the tire carrier) w/ hi lift jack points, hitch, and shackle mounts would have been $830.
    EDIT: and from looking at their site, the weights are pretty damn close as well...
    Bumper—72.0 lbs.
    Side Pieces— 36.0 lbs.
    Receiver Hitch—32.0 lbs.
  16. May 11, 2011 at 3:53 PM
    #36
    85yote09taco
    Eric
    York, PA
    Tacoma TRD OR
    anyone know off hand how much the stock rear bumper would cost at dealership price? I'm taking it to get appraised for my insurance company and was wondering how much of a difference there would be on price, so I can use the money to get the bumper i really want.
  17. May 11, 2011 at 4:17 PM
    #37
    jandrews
    I've heard lol numbers, over ~$1000...Get the check for it, get a plate bumper, and pocket a few hundred bucks...
  18. May 11, 2011 at 4:27 PM
    #38
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    I saw the wraps on another Taco and didn't care for them at all. I decided to go without. The group buy saved me some good coin, too :) AP definitely isn't the highest clearance bumper by far, but I'm glad they reinforced it.
  19. May 16, 2011 at 11:13 AM
    #39
    allpro
    allpro Well-Known Member Vendor
    Montana
    All Kinds Of Toyotas!!!
    I'm glad you're happy with your AP bumper, as are hundreds of others, nearing a thousand by now. Not everyone wants to cut their bedsides for more clearance, and IMO it just doesn't look good. We have the most trail tested products out there, and due to the popularity of our rear bumper, we can now buy material in larger quantity and pass that savings on to our customers, making the new low price only $499 (unpainted)!
  20. May 16, 2011 at 11:18 AM
    #40
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    I like the wrap arounds for the AP rear bumper. :D
