Selling a truck with CMC?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ccrames2018, Nov 2, 2019.
  1. Nov 2, 2019 at 4:57 PM
    Ccrames2018
    Ccrames2018 [OP] Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    Has anyone here had trouble selling a truck with a CMC and major trimming, or had someone try to sue for injury in an accident because of a CMC? I want to do one and run 305/70R16s but I'm hesitant due to the possible long term repercussions since it's permanent. I'm more of a function over form guy generally but it would sure look badass with my Ray10s...
    Also, I was debating just writing up a bill of sale if/when I ever sell it and getting it notarized. Would that be worth doing as a CYA kind of thing?
    Thanks, been thinking about my options for a couple months now and can't decide.
  2. Nov 2, 2019 at 5:02 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    I wouldn't be worried about it. Everything I have sold was modified, even old lawnmowers were modded.
  3. Nov 2, 2019 at 5:10 PM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    Trim and plate it and you won't have anything to worry about :thumbsup:
  4. Nov 2, 2019 at 5:13 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    You're overthinking this.
  5. Nov 2, 2019 at 5:25 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    In general, with a 12 year old vehicle (like yours), there could be any number of things unsafe. The CMC wouldn't be any worse than selling your truck with rust holes in the frame, worn brake pads, dry-rotted spare tire, leaking fuel line, ECM harness chewed by rats...
    Bottom line: If you're selling the truck as-is with no warranty from you, then it's 100% buyer's responsibility to inspect the truck to make sure it's safe and roadworthy.
  6. Nov 2, 2019 at 7:22 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    Yeah I suppose I might be. I wasn't sure if maybe it wasn't legal to sell a truck with a modified frame or something, but I know it would look great with 33x12s so I might just do it. I've had the BAMF plates for a while now anyways.
    JKU3000 likes this.
  7. Nov 2, 2019 at 7:26 PM
    Bishop84
    Bishop84 Well-Known Member
    You're good bud, its nothing to worry about.
    Even if you removed all the airbags and disabled the light there's no recourse. They get it inspected, if you lie about it, then its an issue.
    Ccrames2018[OP] likes this.
  8. Nov 2, 2019 at 7:50 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    thats hardcore
  9. Nov 2, 2019 at 8:09 PM
    badger
    badger Well-Known Member
    07 SR5
    OP, You need to start worrying about Lightning. It's a much bigger threat.
    TireFire likes this.
  10. Nov 2, 2019 at 8:11 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Frame isn’t modified with a CMC. Body is.
  11. Nov 2, 2019 at 8:34 PM
    Mully
    CA
    Here is a basic mod to the generator. Runs alot smoother now.
  12. Nov 2, 2019 at 8:56 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    How do you figure? You cut the frame where the cab mounts to it. You don’t cut the cab. You can do a CMC, remove the cab, and the part you cut will still be attached/welded to the frame.
  13. Nov 2, 2019 at 9:00 PM
    T4RFTMFW
    That’s right. I was thinking about something different, so only half thought that out.
    :anonymous:
  14. Nov 4, 2019 at 3:37 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    Ok, so I decided to go for it. Stellar Built Off Road in Sacramento wants $250. Is that reasonable or should I shop around? I mostly care that it's quality work since I can't weld myself.
  15. Nov 4, 2019 at 3:46 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    Where are you located?
  16. Nov 4, 2019 at 3:51 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    Ok, thanks for the help. I'll look around in the NorCal threads.
  17. Nov 4, 2019 at 3:53 PM
    SDRider858
    SDRider858 Well-Known Member
    San D Aygo
    2019 DCSB OR 4x4 cement
    Anyone know of a good deal on CMC in San Diego? Hell how about full install?
  18. Nov 4, 2019 at 4:33 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
  19. Nov 4, 2019 at 5:15 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    Just cut it yourself. Welding a "plate" back on there is a waste of time. There's a 3" hole in the bottom for fuck's sake!
  20. Nov 4, 2019 at 5:21 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's just the kinda guy he is. ;)
