Selling Hellwig 2005-2015 Toyota Tacoma (up to 2inch lift)3/4 inch diameter Rear Sway
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by chueflee, Apr 17, 2022.
  1. Apr 17, 2022 at 1:44 PM
    chueflee
    chueflee [OP] Well-Known Member
    Chue
    2013 toyota tacoma TRD offroad extended cab 4x4 v6
    afe intake, urd spec u headers, urd y pipe, 76mm throttle body, kelford camshaft, trd supercharger, urd cam gear, urd thermostat, ucon ems, NST pullies, ipt valve body, stoptech disc brake 323mm front, sos rear disc conversion
    Brand new never open. Sold my bass boat don't need anymore 300$ includes shipping
    Description
    This Hellwig 7731 3/4 inch diameter Rear Sway Bar is an ideal suspension upgrade to improve handling performance and to control side to side leaning or sway. Using mounting points on both the driver and passenger side at or near the Rear axle, the sway bar applies a torsional effect to the suspension. When your Toyota Tacoma begins to lean to one side, the Hellwig Sway Bar will apply pressure to the opposite side to resist the transfer of weight. This keeps weight more firmly distributed to all four tires to stay more level with the road. Sway Bars improve cornering traction, turning capabilities and reduce body roll for overall safer driving conditions making them a perfect upgrade for your Toyota Tacoma 4wd & 2wd.
    Features and Benefits
    • Reduces Body Sway and Leaning
    • Better Cornering Traction for Safer Driving and Turning Capabilities
    • Helliwg 7731 is custom fit for the Toyota Tacoma
    • Keeps Vehicle Level by Distributing Weight Evenly to all Tires
    • Effective, Affordable Suspension Upgrade
    • Limited Lifetime Warranty
    • Proudly Made in the USA
    • 3/4 inch diameter 4140 Chrome Moly Spring Steel
    • Hot Formed and Heat Treated
    • Simple Installation
    • Polyurethane Bushings
    Tech Specs
    Bar Diameter: 3/4 inch diameter
    Average Install Time: 1 to 2 hours
    Weight: 20.00 lbs.
    Part 7731 fits: 2005-2015 Toyota Tacoma
