Selling my Topper: How do I remove brake light wiring?
Discussion in 'Tonneau Covers, Caps and Shells' started by jacobswx, May 19, 2021.
  1. May 19, 2021 at 5:49 PM
    jacobswx
    jacobswx [OP] Well-Known Member
    Colorado
    2020 Cement Tacoma TRD Off Road
    Hey guys,
    I’m selling my Leer 100R and was wondering if there is a way for me to remove the wiring that the topper company installed in my truck to connect to the topper. I’d like to give it to the guy I’m selling it to. I did some googling and couldn’t find anything about removing the wiring. Any help would be greatly appreciated.
  2. May 20, 2021 at 2:51 AM
    jacobswx
    Colorado
    Bumping for some early east coast help.
    boston23 likes this.
  3. May 20, 2021 at 3:13 AM
    Bigmo
    Bigmo Well-Known Member
    Brian
    Indiana
    2017 Off Road DCSB 4X4 6MT
    They probably tapped a tail light. You will have to look to see if that's what the did. When I sold mine I unplugged the topper and new owner bought the part of the harness from a Leer dealer that taps the tail light. I guess you could cut the wires close to where they tapped them and then seal them up real good to prevent moisture getting in.
    jacobswx[OP] likes this.
  4. May 20, 2021 at 3:20 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    remove the tail lite lens, probably on the driver side of the vehicle, the splice will be inside there. Leave about an inch or two as a pigtail and cut the cap wiring. Put shrink wrap of the correct size on the pigtail and heat it so it shrinks onto the bare end leaving a tail that isn't covered then wrap that in a little electrical tape to hold it to the other wiring. If they did put plugs there to unhook, unhook them, put a little silicone [electrical type that doesn't dry out] in them and wrap them in a little tape. That way they can be used down the road for something else while keeping water out of them.
    Bigmo and jacobswx[OP] like this.
  5. May 20, 2021 at 4:48 AM
    jacobswx
    Colorado
    Thanks man!
    Bigmo[QUOTED] likes this.
  6. May 20, 2021 at 4:49 AM
    jacobswx
    Colorado
    Great, thanks for the info!
  7. May 20, 2021 at 5:26 AM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    There are two ways the installer might have wired the topper to the truck. The first is by tapping the tail light wiring, as explained above. The second way is the use of the Leer "T" harness, that intercepts the 7-pin trailer connector. Look under the rear bumper to see if that's what you have.
  8. May 20, 2021 at 8:16 AM
    SJBlack
    SJBlack Well-Known Member
    Jacobswx, thanks for posting this. I had the same question. It looks like my original 3rd brake light still works, but my trailer light don't so I'll need to check if they may have tapped into those. Thanks again!
  9. May 24, 2021 at 10:45 AM
    jacobswx
    Colorado
    thanks man!
  10. May 24, 2021 at 10:46 AM
    jacobswx
    Colorado
    Glad it was helpful for you!
