Selling Rear recovery points
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by 21TacoTRDPRO, Nov 10, 2024.
  1. Nov 10, 2024 at 8:44 AM
    21TacoTRDPRO
    21TacoTRDPRO [OP] Follow my IG @21toyoduh
    ordnaS
    SoCal
    21 Tacoma TRD PRO
    Exterior Gears: 5.29 revolution Lift: @Wescottdesigns UCA: @jbaoffroad Leaf springs: @ivdsuspension Wheels: @stealth_custom_series Tires: @yokohamatire Yoko MT Front Bumper @drtfabrication Rear bumper @outgearsolutions HC with tire carrier Roof rack: @Prinsudesingstudio w/2 Load panels 44" light bar Rock Sliders: @rcioffroad 20 BYND 4X4 tactical camper Bed stiffeners:@ChassisUnlimited @cali_raised_led P/S molle panels and Ditch light brackets Sequential led side mirror turn: @MesoCustoms Cat shields: @cali_raised_led Oil: @FUMOTO oil drain valve AC mod Rear Differential Breather: routed to fuel door CMC: @ironrynofabrication Fender Flare Trim: @21toyoduh Rock lights: @RoughCountry Hood scoop 12" LED amber / white + strove light bar Tailgate power lock/unlock: @toyotausa Hood Struts: @redlinetunninginc Rear recovery points: @nytop.store Rear sway bar: @progressgroupinc Tire carrier: Fishbone Offroad Interior Power Switch: @switch.pros.official Power tray: @powertrays @ragofabrication Center Console molle panels /bridge & wifey mount Footwell lights: @VLEDS front /rear + sunvisor vanity lights @Weathertec floor liners, in-channel guards, hood guard @DongarTechnologies rear view mirror USB @AJTDesign minimalist key fobs On board Air: @viaircorp 400P Wifey Air System CMD Center: @expeditionessentials @3TPAM 4x @RAMmounts GMARS: @MidlandUSA MXT275 GPS/Safety: @Garmin Overlander, Garmin Montana 700i
    Selling my NYTOP recovery points for a 3rd gen Tacoma **firm**$200 No shipping. Located in Riverside close to the 15 and off the 91
    2016-2023 (3rd Gen) Toyota Tacoma Rear Recovery Points (Pair). (Estimated lead time 8-14 weeks.)
    Our Toyota Tacoma Rear Recovery Points are finished in powder coat, and made with 1/2 in - 5/8 in high-strength steel to ensure durability.
    These rear recovery points allow you to mount any standard 3/4 inch D-rings, or soft shackles for emergency off-road recovery. We recommend the use of a bridle while using these recovery points in off-road situations.
    They can also be used as alternative anchor points for your trailer safety chains (may require longer chains). Always cross the safety chains underneath the hitch and coupler, make sure to leave enough slack for turning.
    The recovery points mount to the OEM rear tow hitch receiver mounting locations, and have a Working Load Limit of 11,000 lbs each.
    The factory bed step can be reinstalled, but a smaller diameter M12 washer (not provided) will be needed for the lower bolt to fit through the bed step mounting bracket. Our provided bolts (longer than the OEM bolts) will be needed for the factory bed step to be reinstalled on top of the recovery points.
    Torque down all the bolts to 75 ft-lbs./101 Nm.
    ca08tacoma and eurowner like this.
  2. Nov 12, 2024 at 6:35 PM
    Turbo422
    Turbo422 Well-Known Member
    2017 Toyota Tacoma TRD Sport
    PM Sent. Thank you
