SEMA wheels/285s clearance with JBA UCAs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma13_NC, Nov 24, 2023.
  1. Nov 24, 2023 at 12:05 PM
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    Currently running 265/70/17s on SEMA TRD wheels with a 2" coil lift and JBA UCAs. Someone on another forum told me the 285s will rub the JBAs with the SEMA wheels. I think clearance is ok on the truck body with this offset wheel, but I'm concerned about the UCA. Does anyone have firsthand experience with the SEMA wheel and JBAs with 285s? Thanks!
  2. Nov 24, 2023 at 12:11 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    The Sema TRD wheels, I believe, are 0 or at least a positive offset. You will need a minimum of a -10 offset wheel or just put on some 1.25" Spidertrax you you will be all set for 285's. I have JBA UCA's with a 285 and with my -10 offset wheel it just barely doesn't rub.
    Tacoma13_NC[OP] likes this.
  3. Nov 24, 2023 at 12:18 PM
    Tacoma13_NC
    Ok thanks! I might just stay with 265s for now and avoid the unnecessary headache of 285s.
  4. Nov 24, 2023 at 12:40 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    SEMA wheels are 7" wide. 285/70-17 tires typically specify a permitted wheel width range of 7.5-9.0"
