Semi-afforable suspension kit for 3rd gen?
Discussion in 'Suspension' started by FernGomez17, Jan 19, 2018.
  1. Jan 19, 2018 at 9:26 PM
    FernGomez17
    FernGomez17 [OP] Well-Known Member
    Fernando
    2017 tacoma off road
    method NV wheels
    Hello TW,
    I'm looking for a semi-afforable suspension kit. I was thinking about going with Total Chaos UCA's and Fox coilovers in the front with some fox shocks in the rear?
    I really wanna go fast when I hit bumps and considering that my rig is only 2wd this will be the most action it will see!
    Let me know what you guys think.
  2. Jan 19, 2018 at 9:30 PM
    tcjacado
    tcjacado Well-Known Member
    I would look at the bilstein 5100 lift and call @HeadStrong Off-Road How much lift do you want?
    tcBob likes this.
  3. Jan 19, 2018 at 10:16 PM
    FernGomez17
    Fernando
    method NV wheels
    2 inches in front, basically leveld out.
  4. Jan 19, 2018 at 10:16 PM
    FernGomez17
    Fernando
    method NV wheels
  5. Jan 19, 2018 at 10:26 PM
    FernGomez17
    Fernando
    method NV wheels
    is the fox suspension and total chaos UCA's overkill?
  6. Jan 19, 2018 at 10:45 PM
    tcjacado
    What do you want to do with you truck? Take it to the mall?, fire road and light off road?, or balls to the wall run for all she is worth?
    Edit... btw that's a nice set up and you can't go wrong with that choice really
  7. Jan 19, 2018 at 10:51 PM
    FernGomez17
    Fernando
    method NV wheels
    I guess balls to the wall ! And some light off roading lol. Wiish I had 4x4 my FJ cruiser was but I never used the 4x4 option.
  8. Jan 19, 2018 at 10:55 PM
    tcjacado
    The fox set up should do fine, unless you wish to move up to the king suspension.. but then it becomes a tad expensive. King and fox are same type of shock (progressive) as icon and bilstein are similar (digressive)
  9. Jan 19, 2018 at 10:57 PM
    FernGomez17
    Fernando
    method NV wheels
  10. Jan 19, 2018 at 10:58 PM
    FernGomez17
    Fernando
    method NV wheels
    icon coilovers and total chaos UCA !
    tcjacado likes this.
  11. Jan 20, 2018 at 11:40 AM
    tcjacado
    Nice FJ!
  12. Jan 31, 2018 at 7:14 AM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    5100’s for someone that wants to “drive fast over bumps” while offroad?
  13. Jan 31, 2018 at 7:21 AM
    tcjacado
    Bilsteins are the same as icon being a digressive shock. The icons work better with a little speed and so did the 5100's I had on my truck. On road was a little stiff along with off road going around 15 mph. Once you got them up to 30 to 40 they performed great. Only issue I saw or had was that going for extended periods of time off road made them really hot. So you have a smaller window of run time before the shocks overheat and blow out vs say a 2.5 or bigger diameter shock.
