semi synthetic 76 lubricant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Jun 12, 2009.
  1. Jun 12, 2009 at 10:59 PM
    bra
    bra [OP] Well-Known Member
    2008 TRD sport access cab
    Smoked headlights with White DTRL, Michelin
    Hello, I have bought some 5w30 today for my tacoma
    What do you think of the 76 lubricants brand?I've took the super synthetic blend motor oil it is a semi synthethic engine oil...
    Big differences between 100%synthetic and half?
  2. Jun 13, 2009 at 6:43 AM
    PT6
    PT6 Who's flyin this M#$*&! outa here?
    Indiana
    SR 5 Off Road Magnetic Gray
    Protecta bed mat Undercover toneau cover Weathertech mats Scan guage Rear Leaf TSB Transmission TSB
    I ran synthetic blend in my 91' S10 for most of its life. It has 163k on it now and will rust out before it ever has an engine failure. As stated many times before it all comes down to routine maintenance. Many vehicles are running around for a long time with just dyno oil in them. You will be fine and your truck will run many miles and years on the synthetic blend. Look at the post above with the old lady and her Ford. Straight dyno oil is adequate for everyday driving. A blend will be even better.
    As far as 76 (assume you mean Unocal 76) they have been around forever (Gulf oil). I have never heard anything bad about them, so I believe you have a quality product.
  3. Jun 13, 2009 at 7:45 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^I agree. Besides, you have to go with what you find locally because, like I said in your other thread, it's going to cost you an arm and a leg to ship a case of oil out to you.
  4. Jun 13, 2009 at 7:49 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    man get my dad, uncle and grandfather started on this stuff!
    My uncles owns a john deere dealership/service center and remembers the day when gulf/76 ruled his equipment haha
  5. Jun 13, 2009 at 7:58 AM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    The 76 motor oils are part of the Conoco/Phillips empire. They also produce the Motorcraft oils for Ford, TropArtic for Phillips, and Kendall motor oils. All are reguarded as high quality lubricants at reasonable prices. The Motorcraft 5w-20 is very highly reguarded on a leading oil forum. Returns excellent UOA's for 5K runs. All of these oils are very similar, and will give excellent results. The modern blends on the market today are 20 to 30% syn and the rest a high quality conventional oils. Hope this helps.
  6. Jun 13, 2009 at 8:38 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Are you referring to the semi-syn, dino or fully syn? My Honda Pilot takes 5-20 and I'd be glad to pick some up if it gets such rave reviews.
  7. Jun 13, 2009 at 11:44 AM
    91r100gs
    Dan
    Kansas City area
    It is the Motorcraft Syn Blend, it is $11.50 for a 5qt jug at Wal-Mart. A good value IMO. If I cant find BOGO or FAR deals, it would be my top choice in 5w-20 at a reasonable price.
  8. Jun 13, 2009 at 12:44 PM
    bra
    Many thanks to all of you, but do I need to use only synthetic oil now for the next oil change?Or I can use anything? I don't plan to use mineral, it's just in case of...
    Otherwise I trust 76 lubricant now because of you and because it is made in the USA, it costs me 7$ for 1 quart, I have bought 7quarts.
    It was so hard to find the 5W30, most of the stores told me that I will not find and I will need to use the 5W50 100%synthetic for my hot region
  9. Jun 13, 2009 at 2:13 PM
    PT6
    Indiana
    You can swich back and forth at will. There are no negative effects by swiching between dyno-blend-synthetic. As far as the heavier oil for the hot climate I would consult your dealer or a knowledgable mechaninc. I believe several of the latter are represented on this board. What sayeth the experts?
  10. Jun 13, 2009 at 6:45 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    I can't imagine it being much hotter than SC in the summer (low 90's July and August) and I still run 5W30. I forget the temp scale but it stays within spec.
