Send me to LED Light Bar School
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Diego1931, Nov 13, 2016.
  1. Nov 14, 2016 at 1:31 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Don't get led light bar get round hids like kc high lights or Kragen hids throw light much farther and truer than a light bar
  2. Nov 14, 2016 at 1:33 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    It's about as simple as bringing wires through your firewall boot and mounting your switch. Took me about 15 mins to mount and install the whole light bar. Same amount of time when Un installing
  3. Nov 14, 2016 at 1:36 PM
    elkhutn
    elkhutn New Member
    ty
    2018 red TRD off road
    I did mine and it was really easy. I just used the switch that came with the kit. I will have to look at wiring it into my high beams. They are really bright.
  4. Nov 14, 2016 at 1:38 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  5. Nov 14, 2016 at 2:34 PM
    Soccer Mom
    Soccer Mom Well Endowed Member
    2017 MGM SR5 DCSB
    METHOD | SOS | C4 | RIGID | PRINSU | OME | TC
    I've read something about dedicated relays for light bars...is that included in the wiring harness?
  6. Nov 14, 2016 at 2:37 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    Worong harness should be all you need comes with in line fuse and shit only super paranoid people run relays. There is no need for them
  7. Nov 14, 2016 at 2:44 PM
    turbosmitty
    turbosmitty Well-Known Member
    Vegas
    2017 Tacoma TRD OR
  8. Nov 14, 2016 at 2:47 PM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    Purpose of the relay is to remove risk of having 20+ amps at the switch in the cab. A $6 relay is worth it to me to not have 20 amps at the switch.
    Silverspool likes this.
  9. Nov 14, 2016 at 2:48 PM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    I absolutely love my 31.5" 5D @CaliRaisedLed Light Bar with the Stealth brackets being the lower grille!
    Here are some output shots of it!
    ripkinc and Spare Parts like this.
  10. Nov 14, 2016 at 2:53 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I like light bars.. and for my use of once or twice a month during the summer when I'm out in the desert looking for camp spots after dark they work great. However, for my use I see them as a convenience item and can't justify spending top dollar on them. I've had a Totron brand 30" bar for about 3 years of pretty light use and it still works just fine.
    I have the behind the grill bracket from SDHQ and will be putting 2x Ebay light bars in there wired up with a switchpros unit.
  11. Nov 14, 2016 at 2:56 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    So what your saying is the the in-line fuse that comes with most light bars isn't enough protection? I'm not trying to sound like a dick if I sound that way I just don't understand what a relay does and I personally think the fuse is made for the proper power source and proper protection. If you can explain the use of the relay I'd love to learn something
  12. Nov 14, 2016 at 2:59 PM
    trdNick
    trdNick Odie
    Texas
    For anything over 10 amps, personally no I don't think so. A fuse is meant for an over power event, when the device pulls too much current. A 300W light bar will pull 20.7 amps during normal operation. This means it will either have a 25 or 30 amp fuse in line. So every time you turn on the bar, there will be 20.7 amps going through the switch, which the switch itself might not be rated for.
    Edit, a relay is an electrically powered switch. It receives the trigger power from the in-cab switch at 14.7 volts, and virtually no amps. The amps that the device draws(light bar in this case) flow through the relay, and not the switch. If there were to be a short or other event, the danger would be isolated in the engine compartment, not in the cab.
  13. Nov 14, 2016 at 3:15 PM
    Pnwoutdoors
    Pnwoutdoors Well-Known Member
    2017 Tacoma sr5 4x4 DCLB
    I used the cali raised bracket and used this light bar https://www.ebay.com/ulk/itm/191641256016
    Sagebrush[QUOTED] likes this.
  14. Nov 14, 2016 at 3:48 PM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    We are still deciding if we are going to
    Do a sale or not.
  15. Nov 14, 2016 at 3:49 PM
    #35
    CaliRaisedLed
    Jake
    Texas (DFW)
    In the link I provided the video is in it, if not look up CaliRaisedLed on YouTube.
  16. Nov 14, 2016 at 3:49 PM
    #36
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    How are you guys running your wire Harness? Has anyone bumped the fuse up to 50 amp? I am trying to figure out where I am going to mount the wire for best protection and a clean look. I have the hidden 32inch behind the bumper with a simple wire harness kit. Also are you guys running a second harness and set up for each of your Light bars or running a fuse bracket.
  17. Nov 14, 2016 at 3:52 PM
    #37
    trdNick
    trdNick Odie
    Texas
    Bumping the fuse size up is not good. If the fuse keeps blowing there is another problem that needs to be addressed.
    Each bar would need its own relay, each with its own fused power source. Now the two relays could be powered from one switch
  18. Nov 14, 2016 at 3:53 PM
    #38
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    Jelly of your LED game :p
  19. Nov 14, 2016 at 6:07 PM
    #39
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    We'll see now that makes sense then I haven't ever used them before but might start giving them a shot to see if I like them could completely change my wrong on everything
  20. Nov 14, 2016 at 6:21 PM
    #40
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    ‘25 MT6 Off-Road
    Also to the point of relays electrical current running through cable will encounter resistance. Resistance can equal heat. Heat can create fire. Fire is bad. Well, under your hood at any rate. By using a relay you can use shorter lengths of cable, especially important when dealing with high draw items like winches and HIDs.
    trdNick likes this.
