Sensitive Steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SoKnoTaco, May 6, 2019.
  1. May 6, 2019 at 10:58 AM
    SoKnoTaco
    SoKnoTaco [OP] Member
    2015 SR5
    Hey all, just got a 2015 Taco SR5 a few weeks ago...bone stock with 30,000 miles. I’ve noticed that this truck has the most sensitive steering I’ve ever came across. Is this normal for these trucks? I had a tire repaired and I swear it seemed to be worse after the repair (probably in my head). I checked the air pressures, all normal, possible alignment issue? Or just normal for these trucks? Thanks.
  2. May 6, 2019 at 11:00 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    i would start with having your alignment checked, whats the air pressure in the tires?
  3. May 6, 2019 at 1:02 PM
    SoKnoTaco
    2015 SR5
    30 PSI cold
  4. May 6, 2019 at 1:05 PM
    Jester243
    Dan
    Spokane, WA
    I used to run the fronts I think around 32 and the rears around 29
  5. May 6, 2019 at 1:27 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    PSI should be 29 front, 32 rear.
    But yes I believe the Tacoma has twitchy steering and is probably magnified if you run a large bulky tire that has a "flat" tread profile (rather than a "rounder" profile). Alignments will matter more on these trucks as a result.
  6. May 6, 2019 at 3:36 PM
    08RC
    08RC Well-Known Member
    32 is if you have a load in the back. You sure as hell don't need that for an empty bed if you only run 29 in the front . I go 30 all around on the road. Im betting on caster issue
  7. May 6, 2019 at 3:40 PM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    sensitive? details please
  8. May 6, 2019 at 5:14 PM
    brac2015
    brac2015 Well-Known Member
    Dan
    Victoria BC
    Barcelona Red 2015
    Mine was a bit" darty" and some bump steer. Fresh shocks and an alignment and it's 100% better.
  9. May 6, 2019 at 5:15 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Sounds like not enough caster. If you get more, it'll make the steering a bit heavier and more stable feeling. Shoot for about 2 degrees if you're on stock suspension.
    b_r_o likes this.
