Sensor 1 Bank 1
Discussion in 'Technical Chat' started by NH03TacomaTRD4x4, Dec 21, 2011.
  1. Dec 21, 2011 at 11:13 AM
    NH03TacomaTRD4x4
    NH03TacomaTRD4x4 [OP] Well-Known Member
    Doug
    New Hampshire
    03 TRD Double Cab 4x4 Tacoma
    Hi guys my check engine light came on and I had it checked it said sensor 1 Bank 1 AFR. is this something I can fix in my driveway? its an 03 TRD 3.4 liter. Had a mechanic look at it and said the sensor cost $179 his cost.
    Any help is appreciated
    Thx
  2. Dec 21, 2011 at 2:54 PM
    NH03TacomaTRD4x4
    Doug
    New Hampshire
    Thx Meatman I called around to local autoparts places and the cheapest one was Sanels at $150.29 for the sensor. And at Rockauto.com they are $97.79.
    Thx for the info. Now I need to find out if I can do it myself or not.
  3. Dec 21, 2011 at 4:35 PM
    slidyr
    slidyr Member
    I recently did mine the rear harness is easily accessible. Also don't know if your truck is 5 speed or not if it is you will have to remove the trim and boots to access the harness which will be located toward the rear and down a little, you can see it once you get to it just be careful unplugging the old harness. And PB blaster or something similar will make the bolt removal easier.
  4. Dec 22, 2011 at 3:55 AM
    NH03TacomaTRD4x4
    Doug
    New Hampshire
    Does anyone have a write up on how to do this or know of a book that explains it? My truck is a 3.4 liter V6 Automatic. and it is the front banks I need to replace.
    thx
  5. Dec 22, 2011 at 4:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    This is for a manual....
    http://www.lieblweb.com/o2replacement.html
    The only difference - is probably the routing of where the wires go and where its plugged in. Not that hard to figure out.....
    Just remove the sensor and follow the wiring to the plug & unplug it.
  6. Dec 22, 2011 at 4:26 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    In 12+ years in this business i have never recommended both sensors be replaced at the same time. I have on many occasions replaced one or the other with no issue. Save your money OP.
    It is just 2 nuts, they are 12 mm nuts, go easy with them when you remove them, i have had more than a few strip out on me during removal. The heat is a bitch on them.
