Separated my balancer
Discussion in '1st Gen. Tacomas (1995-2004)' started by COMAtized99, Jul 9, 2017.
  1. Jul 9, 2017 at 3:33 PM
    COMAtized99
    COMAtized99 [OP] Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    My plan was to strip down the front of my 3.4 and prep it for a new TB, and WP. I picked up the tool in the picture to hold the crank pulley. As I applied force,the center broke free. The center section looks have been held in by some kind of rubber?
    I assume it would be frowned upon to run the pulley without this center section?
    Note to self: buy a chain wrench...
  2. Jul 9, 2017 at 4:02 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Wow. I'm guessing without it wouldn't work harmonically? Lol.
    I ruined a HB using one of those chain wrenches...
  3. Jul 9, 2017 at 5:01 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    Yea, I'm not a fan a a chain wrench because of the marks it leaves. Figured I'd done the right thing getting the SST for once...
    Turns out my impact was plenty strong to get the bolt off...
    With the engine in the truck, I've always used a breaker bar and layed it on the frame rails and bumped the starter... However, since the engine is on a stand, this method doesn't really work..
  4. Jul 10, 2017 at 12:55 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Better you found this little issue now rather than driving down the road .
    If you ripped it loose from the rubber it was not long for the world
    COMAtized99[OP] likes this.
