Sequential turbos for a six speed..has anyone done it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Welder94, Aug 27, 2024.
  1. Aug 27, 2024 at 8:08 PM
    Welder94
    Welder94 [OP] Member
    What’s up yall I’m a new member here on taco world and just started my own fab business. Was thinking about projects I could do my self to promote it and have always like the idea of sequential turbos would be sick on my 6 speed man. Gen 3. I figured since there’s plenty of people smarter than me someone has to have an idea what to do haha if any yall want new custom fab parts hit me up!
  2. Aug 27, 2024 at 11:13 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    just straight up twins make more sense. actually before covid there was a production twin turbo kit for these utilizing factory ecboost turbos.
    Welder94[OP] likes this.
  3. Aug 27, 2024 at 11:18 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I've done sequentials on other vehicles, it would be a bit hard with a 3rd Gen if you kept the stock computer because sequentials require valve for pre spool and mixing. If you ditched the stock computer you'd lose a lot of other features too so not sure I'd do that personally. Regular twins is a much more realistic task and the difference in spool time will be negligible with modern turbos anyway.
  4. Sep 3, 2024 at 10:43 AM
    Welder94
    Thanks guys this sounds like a much easier project! I was thinking using the Sequentials because like I said, my Tacoma is a six speed manual. But if a couple little twins will work that’s siiiiiick. The goal is to able to fit and put together a custom turbo package I can pump out for all my taco family! I guess the next question is good advice for recourses I research from. Thanks guys!
  5. Sep 3, 2024 at 10:48 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Two small ones to spool faster or one larger one with variable vanes would get your output where you want it a whole lot easier then a sequential set up. Turbo lag is always a complaint when you go big on a single turbo, hence the shift to two smaller ones or a variable vane setup.
  6. Sep 3, 2024 at 10:51 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    What does a manual transmission have to do with that?
  7. Sep 3, 2024 at 11:03 AM
    fxntime
    I am going to bet part of it has to do with emission RPM drop lag between shifts to keep emissions to a reasonable level.
    It was already an issue to the point some people bypassed the mech that slowed the RPM drop between shift on the manuals.
  8. Sep 3, 2024 at 2:07 PM
    BillyE
    BillyE Well-Known Member
    With the high CR is this engine really a good candidate?
  9. Sep 3, 2024 at 2:19 PM
    Speedytech7
    It's not a bad candidate if you're making appropriate use of the direct injection. BMWs M3 engines from the last couple generations utilize a high compression ratio and lots of forced induction because you can drastically minimize ping with multi event GDI spraying and other neat tactics.
    Welder94[OP] and BillyE[QUOTED] like this.
  10. Sep 4, 2024 at 5:50 PM
    Welder94
    1st -2nd gear you gotta give her gas and Ashe ain’t the quickest off the line so if I can get just a little more boost that would be nice. Plus if I figure out how to do it right I can do it for others!
  11. Sep 4, 2024 at 5:54 PM
    Welder94
    If I can find a good combo of quality small turbos and I’m assuming I quality software I have to plug into the computer for inspection purposes (I’m a NY resident) so nothing tells Uncle Sam wtf I’m doing CAUSE ITS NONE OF THEIR BUSINESS!!! Hahaha dinosaurs died and tacos were made for a reason hahaha
  12. Sep 5, 2024 at 5:38 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  13. Sep 5, 2024 at 10:35 AM
    gudujarlson
    Minnesota
    I think he was asking why you think a sequential turbo is specific to a manual transmission.
    Chew and crazysccrmd like this.
  14. Sep 5, 2024 at 10:55 AM
    Speedytech7
    No lift to shift makes for some pretty spicy action.
  15. Sep 5, 2024 at 11:57 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i remember watching that thread when it came out and looking at the money it would take to buy the kit. im so happy i waited to see if the kit panned out.
    Chew likes this.
