Sequoia has NO power all of a sudden
Discussion in 'Technical Chat' started by Dmcgee, Nov 29, 2012.
  1. Nov 29, 2012 at 5:50 PM
    Dmcgee
    Dmcgee [OP] New Member
    TEXAS
    2005 sequoia
    Left the house this afternoon and my 2005 sequoia has no power. The car struggled to get to 70. Check engine light is on along with two different "trac" lights. Once I stopped I popped the hood and discovered the oil cap was gone. The oil pressure and level is fine.
    What could gone wrong with the cap off?
  2. Nov 29, 2012 at 5:58 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    It's probably in "limp" mode. It prevents the engine from creating anymore damage. Get another oil cap and reset the light.
  3. Nov 30, 2012 at 6:18 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Engine runs in vacum, so with oil cap off it can not create the vacum. If you put cap off and reset computer it should be back to normal unless you suck it so much dirt that it had damaged something.
  4. Nov 30, 2012 at 9:05 AM
    Dmcgee
    TEXAS
    2005 sequoia
    Is there a way to reset the computer without a scanner?
  5. Nov 30, 2012 at 9:23 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    You could try removing the negative side battery cable for 10/15 minutes then reconnect and see if codes are reset. If not you will need access to a obdII scanner.
