Serious Alpine CDA-117 issue
Discussion in 'Audio & Video' started by Silentknight11b, Mar 15, 2011.
  1. Mar 15, 2011 at 4:32 PM
    Silentknight11b
    Silentknight11b [OP] Member
    SC
    2011 Doublecab TRD Sport 4x2
    TRD exhaust, PIAA bulbs, AFE drop in, N-FAB stepbars, more to come.....
    Ok, I finally had time this past weekend to install my new Alpine CDA-117 headunit- and I must say I am quite underwhelmed.... I realize it is "Just a headunit swap" but really- the system has almost NO A$$ to it. Less bass than the factory setup and rather hollow sounding. I have tried every setting and combination I could come up with regarding the parametric or graphic EQs as well as the Media Expander. I am seriously OCD with wiring, so the adapter harness and the wires for the actual headunit are good- no polarity reversing. So- ANY IDEAS? Sounds the same on Ipod, CD and tuner- no better for any. I have ordered a powered 6 inch Bazooka tube to HELP as I am not going to give up all my storage or rip out welded brackets- but ANY tweaks or hints you have discovered about the CDA-117 would be GREATLY appreciated....
  2. Mar 15, 2011 at 8:46 PM
    95tojo
    95tojo Well-Known Member
    Jared
    So IL
    '19 Cement Grey TRD Sport 4x4 6MT
    Well thats a pretty descent headunit (even if it is alpine :p). Ive seen this a few times before when putting an alpine in with factory speakers, and to help the issue, it just takes time to sit there and make the adjustments. For starters, most of the time that you put an aftermarket in, it will sound different because of the freq differences between the outputs of the fact and the aftermarket. Try changing the speakers out for a descent set of aftermarkets and see what you think.
    and honestly, i hate the bazooka tubes. they sound like crap to me.
  3. Mar 16, 2011 at 4:30 AM
    Endurozw
    Endurozw War Damn Eagle!
    Zach
    Birmingham, Alabama
    09 PreRunner DC SR5 w/ tow package
    Fold-a-cover G4 - Wranger Duratrac 265/75/16 Audio Upgrades: Pioneer AVH-P4200DVD / JL Audio HD600/4 amp / Hybrid Audio 6.5 Clarus up front / Arc Audio 10 in subwoofer
    I think I remembered reading that the factory headunit adds "bass" by distorting the music...so it's more bass that you hear? That might have been completely off base but I know what you mean, I was actually pretty disappointed at first when I swapped my HU out. Honestly it wasn't a huge deal unless I was listening to hiphop but you're right that it definitely sounds very different. I just put it on the heavy bass eq when I'm listening to rap and you get used to it after a few weeks.
  4. Mar 16, 2011 at 6:07 AM
    Silentknight11b
    SC
    Well- the stock head unit just had more low end. I was not expecting to upgrade to Alpine's big boy head unit and have worse sound. I have never had a bad experience with an Alpine unit until now. I have tried maxing the low end (+6 on the EQ) and turning the highs all the way down (-6) and it is still too hot on the highs... I have tried the graphic and parametric EQs- neither did a lot. I tried the Media Expander- actually made it worse. I know Bazooka tubes are not ideal- but I will not give up all of the small storage behind the seats- so the tube is a resort- not a choice. I am not sure what else to try- I woul dnormally think the polarity of the speaker wires had gotten reversed if I heard someone else with this issue but I triple checked the wiring before installing the unit. Really at a loss and rather pi$$ed......
  5. Mar 16, 2011 at 6:32 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Throw those stock speakers in the trash. They're garbage. Have you seen the magnet on those things? It's about the size of a 2liter bottle cap. The stock speakers lasted all of 1 hour in my truck when I bought it and they were quickly replaced with aftermarket components as soon as I brought the truck home.
    If you want bass, you will never get it out of speakers and have it sound decent. You need a sub. I have a 10" sub in mine. I put my box and amp behind the 60 side of the 60/40 seat. I still have full use of the driver's side compartment.
    Reversed polarity wouldn't cause the speakers to sound too high. It would just made the sound out of phase.
  6. Mar 16, 2011 at 6:37 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Can you control the high pass filter? I can set my pioneer to super bass and set the eq to +6 and if the filter is set at 125hz I'm not gonna get much bump. Turn the hpf off though and you'll hear me coming before you see me
  7. Mar 16, 2011 at 6:44 AM
    Hondarider08
    Hondarider08 "That's what she said..."
    Justin
    Logan, UT (Originally Pocatello, ID)
    05 Tacoma TRD
    Leveling kit, K&N drop in, and a Loud Ass Stereo :)
    The JBL designed system in these toyotas are designed to work efficiently with the stock unit and the stock speakers. If you change any of that, then you're going to change the whole way the system works.Most head units like that aren't designed to put out a lot of juice. Granted, some of the higher end units will give you a few more watts, but not enough. The aftermarket HU's are there to allow you to use an external amplifier. This is where you will get the most sound and bass. If you're looking for bass, and you're not willing to give up some space for a sub, you might as well give up. :rolleyes: Get rid of the trash stock speakers, buy some aftermarket ones, and put them on an amp. Most four channel amps will fit underneath the driver seat. That's where you're going to get the sound you want.
  8. Mar 16, 2011 at 6:48 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    hmmm...I don't have any advice, but when I put the CDA-117 in my truck it was like night and day how much better and LOUDER it was. I really love mine, hopefully you can figure out what the issue is because these are great stereos, in my experience.
    EDIT: Did you also add the steering wheel controller? Did you make sure to solder on the proper resistors when you installed it?
  9. Mar 16, 2011 at 7:38 AM
    Silentknight11b
    SC
    I did use a steering wheel adapter- but I used the Metra ASWC. It is 2 wires to solder and it auto programs. nice little piece of kit. No resistors or such to add it. I have the HPF off and bass on the EQ maxxed. Just hallow/no low end at all... I am pretty much monkey humped.
  10. Mar 16, 2011 at 6:37 PM
    95tojo
    Jared
    So IL
    that SWC has nothing to do with the way it sounds. Is it a JBL system ?
  11. Mar 17, 2011 at 4:27 AM
    Silentknight11b
    SC
    No- not a JBL system. Just the standard setup.
  12. Mar 17, 2011 at 10:53 AM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    I'm at a complete loss as to why your CDA-117 sounds so bad? You've addressed everything I could think of to check. I just don't get it. :confused:
    I purchased my CDA-117 as the first step to a complete system overhaul. My truck is a daily driver so I had to replace components a little at a time over the course of a couple of months. My CDA-117 ran my stock speakers for a couple weeks and I was not blown away by the sound. After a couple of weeks I deadened the doors & back panel which made a dramatic improvement... the stock speakers had a much fuller sound. In fact my wife thought I had installed my new speakers it made such a difference. I then replaced the stock speakers, added an amp and a subwoofer and have been very pleased with the system as a whole. I've found the built in equalizers, high pass filter adjustments, time correction, & subwoofer adjustments on this unit to be excellent... but I only tweeked them while using the external amp & aftermarket speakers.
  13. May 10, 2011 at 9:23 AM
    PeachEater81
    PeachEater81 Well-Known Member
    San Gregorio
    2005 Tacoma DCSB TRD Sport 4x4
    Icon C/O, Icon 2.0 Resi's, LR UCAs, Alcan 8 leaf pack, Aero 2525XL, Michelin LTX MS2, Lifetime LED heads and fogs (bad company and product - don't buy), aFe Pro Dry filter, Weathertech mats, Best Top, Hybrid Audio, Arc Amp, Arc Sub, Ram matting, Core/Hurst Short Throw Shifter, OEM Bed Mat, Antenna X....
    Check your crossovers
  14. May 11, 2011 at 12:20 AM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    Stock speakers suck, no head unit will fix that.
