serious engine trouble, loud engine rough idle...HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PVT Clark, Jan 3, 2012.
  1. Jan 3, 2012 at 10:07 AM
    PVT Clark
    PVT Clark [OP] Well-Known Member
    chase
    Missouri City
    07 tacoma 4x4 4.0L
    train horns, rhinoliner bumper and fenders, 3" ProComp lift, HID's, GT Racing seat covers, smoked tail lights.
    2007 toyota tacoma 4x4 4.0L with 120,000 miles.i have a cel code p0022 (a code related to timing issues i believe) and the engine is running very rough with loud mechanical noise coming from the engine. recently i went mudding and sucked water into my intake which caused the truck to die on site at the mudpit, but i was able to get it to start soon afterwords but the engine ran very sluggish. i changed the oil twice to get all the watery oil out, cleaned my intake, cleaned the throttle body, and ran seafoam through the engine. the engine ran fine for about 10 miles of neighborhood driving and had a normal idle, but when i got onto a major highway, the motor wouldnt go past 60 and began to deteriorate in efficiency very very quickly....engine started making a large clacking noise consistent with a rapidly flashing low oil light in the cab. is my oil pump out? is my timing off? i have no clue. please help!
  2. Jan 3, 2012 at 10:14 AM
    PVT Clark
    chase
    Missouri City
    07 tacoma 4x4 4.0L
    im not sure what that sounds like...it just sound like the engine is not lubricated and doesnt have any oil in it. but i know i filled it correctly...
  3. Jan 3, 2012 at 10:18 AM
    PVT Clark
    chase
    Missouri City
    07 tacoma 4x4 4.0L
    it also dies sometimes when in drive or reverse. is the timing off you think? i mean thats obviously waht the code says haha but those things can get triggered by different things. i also had a random misfire and another timing code before but they went away.
  4. Jan 3, 2012 at 10:20 AM
    Large
    Large Red
    Change your plugs.
  5. Jan 3, 2012 at 10:24 AM
    JEA86
    JEA86 Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    did the motor go into limp mode? or did the Camshaft Position sensor somehow get fried?
  6. Jan 3, 2012 at 10:28 AM
    PVT Clark
    chase
    Missouri City
    07 tacoma 4x4 4.0L
    what is limp mode? and it might have im not sure how i would have done that though. i got alot of water into the intake...like i saw water running out of the cold air intake tube. but i drove it home, maybe 10 miles, and that was it. i didnt drive it again till i changed the oil and changed everything. could the plugs have gotten screwed up and now its just misfiring very badly? im not getting any misfire codes...
  7. Jan 3, 2012 at 10:55 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You are most likely in need of new engine...
  8. Jan 3, 2012 at 11:06 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    oh my........
    thats what im thinking
    op,why would you want to drive your truck anywhere let alone restart it after you sucked in all that water in the engine????????you should of had it towed to a dry place and did your changing of the fluids.i guess for you its live and learn.
  9. Jan 3, 2012 at 12:19 PM
    BlueT
    NorthEast
    x2
    OP made string of big mistakes.
    OP
    None of us is in position to tell you what exactly is wrong since we have no access to the truck. From description it sounds like there are multiple failures, with your limited understanding quickest route is to start looking for engine replacement.
  10. Jan 3, 2012 at 12:30 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    X2, and from the sounds of it, also a reputable shop to do the work.
  11. Jan 3, 2012 at 3:03 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If it ingested water it most likely bent a connecting rod at least or even sheared it off and the remains are clattering around in the engine. A compression check will tell you a lot and after that drop the pan and have a look.
  12. Jan 3, 2012 at 3:06 PM
    Large
    Large Red
    What he said ^
    Do a compression check on each cylinder I think it's supposed to be 120 psi? Correct me people.
  13. Jan 3, 2012 at 3:10 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    X2
    I bet you partialy hydrolocked your motor at the mud hole..and it was only time before a catastrophic failure to happen
  14. Jan 3, 2012 at 3:18 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd drill a small hole at the bottom rear of the muffler to get any water out of the exhaust.
    So, the engine runs? I'd be disconnecting electrical connections then clean and dry them out.
    Maybe a fried ignition coil; unplug one coil at a time then start engine. If it runs worse it's not that coil. Test all 4.
    I bet it's electrical but perhaps an engine compression test would tell alot.
  15. Jan 3, 2012 at 3:55 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Compression check will tell you all you need to know it really does not matter as to what it should be just that one or more is way low compared to the others. A bent rod will lower the compression a lot a broken rod will come in at zero. This may explain the cam sensor reading retarded if it stopped fast enough to jamb the VVT tensioner.
