Serious first gen 3rz problem.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Skiddz_2j, Dec 31, 2017.
  1. Dec 31, 2017 at 10:57 PM
    Skiddz_2j
    Skiddz_2j [OP] Active Member
    Wendall
    95.5 Tacoma single cab 4x4 manual locking hubs
    Okay tacoma world, in need of some serious need of help with this damn truck.
    I have a 95.5 3rz 4x4 5 speed, I got rid of the truck to a kid I know awhile ago, well I just got the truck back on a trade, and it has an issue that I cannot figure out for the life of me. I'll go into detail on the problem/symtoms that the truck has, and what I have done to try to diagnose it...
    It takes awhile to start, and when It does decide to start it has a dead misfire on cylinders 1 and 4 and it will only accelerate if I barely press the petal. It breaks up and back fires through the intake as if its out of timing or something. And it will not run if the mass air flow sensor and/or the tips is plugged in, it will only run if they are unplugged.
    Now on to the list of new parts and things I have done to try and fix it.
    It has a new mass air flow
    new tps
    new distributor
    New distributor cap and rotor
    New fuel pump
    New fuel filter
    New spark plugs
    New crank position sensor
    It has good compression across the board
    I noid lighted the injectors and they all fire fine
    To eliminate a dirty injector, I sprayed some ether in the intake while giving it a little gas to see if the misfire cleared up, yet nothing.
    I've scanned it for codes and all that keeps coming up is a crank shaft position code.
    But it throws that code with the old sensor and the new one as well.
    I've even went as far as swapping the ecu with a "known working" ecu from a friend's truck and the problem is still there... I'm sure there is more information I am forgetting but this is all I got for now. Any ideas? I'm growing tired of this problem already and loosing hope for this truck. Someone please help! Lol thanks for any info!
  2. Dec 31, 2017 at 11:23 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Bad injectors would be my guesstimate.
    Skiddz_2j[QUOTED][OP] likes this.
  3. Dec 31, 2017 at 11:24 PM
    Skiddz_2j
    Wendall
    Bad injectors would cause a crank position sensor code?
  4. Dec 31, 2017 at 11:47 PM
    rzgkane
    Hmm. I missed that part.
    I’d be looking for a poor connection at the sensor or damaged wiring between it and the ECU.
  5. Jan 1, 2018 at 2:00 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    What's the exact code, P0335 or P0336?
    P0336 could be the distributor not installed correctly, like off by a tooth and the computer detects the difference between the crank position sensor and the cam sensor built into the distributor on 95.5-96 models. This would also cause an early spark and explain the backfiring.
    Use an old school timing light to check the timing at the crank pulley or just try reinstalling the distributor one tooth over.
    Skiddz_2j[OP] likes this.
  6. Jan 1, 2018 at 6:11 AM
    Skiddz_2j
    Wendall
    Forgot to mention that, I have also used a timing light on it, lol
  7. Jan 1, 2018 at 9:24 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    I suggest before reloading the parts bazooka doing a leak down test with the engine cold.
  8. Jan 1, 2018 at 9:27 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Have you checked the coil? 3rz’s share coil packs between 2 cylinders. I can’t recall if 1 and 4 are shared, but worth a check.
  9. Jan 1, 2018 at 9:28 AM
    Skiddz_2j
    Wendall
    It's a 95. It has one coil for all 4 cylinders. I wish that were the issue.
  10. Jan 1, 2018 at 12:17 PM
    Skiddz_2j
    Wendall
    One thing I was thinking about was the reluctor ring on the crank shaft is maybe missing some teeth? The fire to those effected plug wires seems to be some what intermittent, but from what I can tell by having the motor out of my other "98 tacoma 4x4" the timing cover has the oil sump pick up tube on it which means I will have to pull the oil pan, and that looks next to impossible unless I ether lift the motor or pull the motor. So I was leaving that for last. But is it possible that if it were missing teeth, it would cause an Issue like this?
    MrCrowntown likes this.
  11. Jan 1, 2018 at 4:14 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    What was the code?! Fallow the test procedure in the repair manual for that particular code.
    The computer will try to adjust the timing as much as possible, but if the distributor is off by one tooth it can't adjust it enough to fire the spark at the correct time under all engine conditions (RPM, load).
    What was your timing? Timing should be 3-7° BTDC @ idle with TE1 and E1 jumpered in the data link connector.
  12. Jan 1, 2018 at 6:03 PM
    Skiddz_2j
    Wendall
    I've tried it 1 to 2 teeth in ether directions. I'll look further into that tho
  13. Jan 1, 2018 at 6:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    Possible the harmonic balancer has failed and is allowing timing to jump around?
  14. Jan 1, 2018 at 6:19 PM
    Skiddz_2j
    Wendall
    Ehh I was thinking that but I have rechecked the timing a number of different times and it is always dead on.
  15. Jan 1, 2018 at 6:28 PM
    Clearwater Bill
    Billy
    Largo Florida
    Checking base timing with ECU jumped out?
  16. Jan 1, 2018 at 6:40 PM
    Glamisman
    Glamisman Well-Known Member
    my wiring manual is for a 96... maybe this helps, maybe not. All of those components listed are grounded through a splice that ultimately ends up on the engine block ground. Disconnect the battery and the CPS see if there is an open between the "E" brown wire and the engine block ground. Have someone wiggle the harness at various places to see if it is an intermitent.
  17. Jan 1, 2018 at 6:46 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Plug wires in the correct order?
  18. Jan 1, 2018 at 6:59 PM
    Skiddz_2j
    Wendall
    Yeah I believe they are. I've tried about 3 different firing orders that I have found online and only one of the ways work to let it run. So I believe it's right.
  19. Jan 1, 2018 at 7:00 PM
    Skiddz_2j
    Wendall
    I will check this out tomorrow. This is some great information. Thanks a lot man!
  20. Jan 1, 2018 at 7:41 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    If you unplug the MAF or TPS then the computer goes into fail-safe mode and it will run like crap even if everything else is working. Without the MAF the timing is fixed at 5° BTDC, so it's hard to do any meaningful timing checks with a timing light this way.
