Serious good mpg
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jimmywestco, Sep 21, 2022.
  1. Sep 21, 2022 at 6:28 PM
    #61
    Kllrbee
    Kllrbee Well-Known Member
    Tim
    Bloomfield, WI
    22 Army Green DCSB Sport
    Hand calculating is the only way. Whatever the onboard says, its usually off. Sometimes by alot.
    FWIW, Ive only had my truck little over a month. Filled up 4 times so far. Each time the truck says Im getting around 23.6-23.9 mpg per tank. When I hand calculate by dividing the number of gallons put in by the miles driven since last fillup (reset Trip 1 at every fillup), I get closer to 22. Thats quite a bit off.
    Im still happy as heck with 22, as thats very good for a truck. But I also drive like a grandpa (cuz I am one) and I live in flatland midwest.
    BigEasy, zoo truck and southwestorv like this.
  2. Sep 21, 2022 at 6:34 PM
    #62
    JustJon
    JustJon Well-Known Member
    MI
    18 DCSB OR
    I used to get like 24-25 when it was that new… it’s broken in now and gets a healthy 18… downhill…. With a tailwind…
    RIX TUX[QUOTED] and southwestorv like this.
  3. Sep 21, 2022 at 6:45 PM
    #63
    grizz_wi
    grizz_wi Well-Known Member
    Green Bay, WI
    2022 Lunar Rock AC 6MT
    Idk why people think the cluster is remotely accurate. I use fuelly for all my vehicles, will see how the Tacoma treats me!Screenshot_20220921_204403.jpg
  4. Sep 21, 2022 at 7:01 PM
    #64
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    All depends how you drive it. My truck will usually give a 385-416 miles to empty reading after filling up. I usually don't let it get much below a half. However, two days ago I went until it said I had 5 miles until empty and only ended up having to put 18.6 gallons in. Based on the 19.7 MPG I was getting on that trip I could have gotten to 413. Another caveat is that it will begin to drain the "miles to empty" meter faster once you get around a quarter tank. I noticed mine ticking off a mile roughly every .6 miles.
    cryptolime likes this.
  5. Sep 21, 2022 at 7:04 PM
    #65
    RedWings44
    Michigan
    What tires do you run and when was the last time you used any fuel system cleaner or replaced your air filter?
    On that note: after 75k, I asked my dealership if they'd ever replaced my air filters since I'd never seen it charged and the inspection was always checked green. Sure enough, they hadn't and, as if by magic, it was ticked yellow after that. They changed it at the next service. My most recent service was the first one since the change and they ticked it yellow again despite no driving out of the ordinary. Can't find good help these days.
    myn75, cryptolime and southwestorv like this.
  6. Sep 21, 2022 at 7:42 PM
    #66
    southwestorv
    southwestorv Well-Known Member
    2022 TACOMA TRD OFF ROAD 6-SPD
    I have a brand new 2022 Tacoma TRD Off Road, V6, 6-spd manual transmission. I filled it up tonight. Here’s what I can report:
    • 2199 miles on the odometer
    • My last fill up was with 89 octane fuel
    • 18.296 gallons
    • 438.3 miles
    • 23.96 mpg
    • Mixed driving, about 50/50 city/hwy
    • Seems to match what people are reporting on here.
    Junkhead likes this.
  7. Sep 21, 2022 at 8:22 PM
    #67
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Not really, YMMV but its basically all the same and even your own experience is confirming that. The onboard calculation is based on 19 gallons but as I said we are all basically getting the same regardless of how you drive.
    RedWings44[QUOTED] likes this.
  8. Sep 21, 2022 at 9:13 PM
    #68
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    Pfff i got 53.4 mpg once*
    *once, going down hill, never had to touch the gas. Down hill. I average 18, but we wont talk about that mmmkay.
    TexasWhiteIce likes this.
  9. Sep 21, 2022 at 9:23 PM
    #69
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    First tank, 383 miles traveled, 17.5 gallons pumped.
  10. Sep 21, 2022 at 9:38 PM
    #70
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  11. Sep 21, 2022 at 10:12 PM
    #71
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    You must be driving like 55-60 or have the wind helping significantly. 70 in 6th gear in mine is about 16.5-17 mpg max. Maybe 18 on the very best day which is almost never.
    southwestorv[QUOTED] likes this.
  12. Sep 21, 2022 at 10:53 PM
    #72
    southwestorv
    Yes. On an earlier tank I saw that this truck really starts to hurt (MPG’s) above 65 mph. I do drive 60 mph on the highway, and the MPG’s are even really good chugging around town at 40 mph.
    BLtheP[QUOTED] likes this.
  13. Sep 22, 2022 at 4:29 AM
    #73
    JustJon
    MI
    18 DCSB OR
    Toyo open county at3, 265/75, air filter should probably be changed. And could run some cleaner too
  14. Sep 22, 2022 at 5:45 AM
    #74
    stftaco
    Don't write "chugging". I've begun to notice also the chugging the vehicle will do between 40 and 43MPH, with the engine turning crazy low RPMs. :frusty: I try to get out of that region of operation. Going up steep inclines, I sometimes engage ECT. I've never owned a vehicle in 40+ years of vehicle ownership that behaved (? behaved is a poor word choice here) in this manner.
    For a 2022, should I believe it came from the factory with the latest and greatest flash to avoid "chugging" or is that "stuttering"? I have zero hesitation which is nice, but it is turning very low RPMs in that speed range.
    It's so new, I dare not get a non-OEM ECU tune. With all respect to the tuners out there, you cannot be sure that will not be used as an excuse to deny a warranty claim during the warranty period for an engine or transmission issue.
    cryptolime and BigEasy like this.
  15. Sep 22, 2022 at 6:06 AM
    #75
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    I'm gonna leave this right here, to stir the pot even more. And before you ask, yes, this is my truck. It was a road trip I took from Ft Worth to Austin and 99% of it was highway miles on cruise control set at 65MPH.
  16. Sep 22, 2022 at 6:23 AM
    #76
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I agree getting nearly 24 mpg with 50/50 city highway especially if carrying anything. Thats better than what i'm getting. I'd be lucky to get 22 mpg with a 50/50 mix.
    southwestorv likes this.
  17. Sep 22, 2022 at 6:35 AM
    #77
    RedWings44
    Michigan
    I haven't run any fuel system cleaner in a while, but I've done several very long road trips this year. But changing the air filter made a big difference for me. Probably 1-2 MPG consistently for about 21 MPG at 70 MPH on my commute while still carrying my RTT all year. My tires did cause about a 1 MPG drop from the stock ones. Stock size, but slightly beefier.
  18. Sep 22, 2022 at 6:54 AM
    #78
    JustJon
    MI
    18 DCSB OR
    OEM filter or something like a wix
  19. Sep 22, 2022 at 7:16 AM
    #79
    RedWings44
    Michigan
    I just went with OEM. I ran a K&N on a Mustang back in the day. I found it had slightly more power, but ran worse overall and got worse MPG than stock so these days I just stick to stock.
    zoo truck likes this.
  20. Sep 22, 2022 at 7:20 AM
    #80
    Tacospike
    Two Trucks
    65 mhp? I do 80 mph on that same trip.
