Serious question, Cummins diesel swap into a 1st gen
Discussion in '5 Lug' started by CorysTaco, Apr 19, 2018.
  1. Apr 19, 2018 at 6:56 PM
    CorysTaco
    CorysTaco [OP] Active Member
    Cory
    2004 White Tacoma
    Wheels, Tint, Subs/Amp
    Hey guys, I have a serious question. I got a 04 Tacoma 5 lug, 2.4l I’m wanting to drop the 4BT Cummins diesel into it, I bought the truck off a 17 year old kid and he laughed and said the axels will fall off from the torque and weight. Do you guys think the axels will actually fall off or take toll on the frame or do you think he was just jealous the trucks gonna be something it wasn’t when he had it?
    musher and ChadsPride like this.
  2. Apr 19, 2018 at 6:58 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    I can't help with your question but
    :popcorn:
    Brice, 4drtaco03, Toyko Joe and 3 others like this.
  3. Apr 19, 2018 at 6:59 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    You're definitely going to need to stiffen the frame, with only 265 Lb/Ft of torque your rear axle might survive, I think the 5 lugs used the same rear axle as the 6 lug.
    You will need to do a body lift or serious trans tunnel modification to run a trans behind the 4BT.
    ChadsPride likes this.
  4. Apr 19, 2018 at 6:59 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Theres a guy on the you toobes
    4drtaco03 and ChadsPride like this.
  5. Apr 19, 2018 at 7:01 PM
    CorysTaco
    Cory
    2004 White Tacoma
    Would I get the same transmission that comes with the 4BT?
  6. Apr 19, 2018 at 7:01 PM
    inwood customs
    Dave
    You already bought it... what exactly is asap?
  7. Apr 19, 2018 at 7:02 PM
    CorysTaco
    Cory
    2004 White Tacoma
    Haven’t bought it yet, but I’m going to. That’s just why I’m trying to get some answers as soon as possible.
  8. Apr 19, 2018 at 7:03 PM
    inwood customs
    Dave
    We need moar popcorn
    Toyko Joe likes this.
  9. Apr 19, 2018 at 7:10 PM
    95 taco
    95 taco Battle Born
    I would use a trans that is typically found behind the 4BT so you know it can handle the torque of the stock motor as well as any mods you have planned, I imagine there is decent aftermarket support for those transmissions.
  10. Apr 19, 2018 at 7:29 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    4bt is to heavy...
    your gunna wanna go with the R2.8
    smw62891 likes this.
  11. Apr 19, 2018 at 7:37 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    4bt 782 pounds
    R2.8 502
    2rzfe around 400 pounds
    So with out seriously beefing up your front suspension its not gunna happen.
  12. Apr 19, 2018 at 7:42 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    What axel do you have? The 7.5”? 8”? 8.4”?
  13. Apr 19, 2018 at 7:45 PM
    95 taco
    95 taco Battle Born
    There are only 2 options that I'm aware of for the front suspension that will work for the 5 lug with extra weight.
    Long travel (Expensive, not a good option, but it's an option)
    Custom Coilovers (Expensive, should be great quality, tunable, and should ride the best)
  14. Apr 19, 2018 at 7:46 PM
    95 taco
    95 taco Battle Born
    I think it might be the 7.5, I had a '95.5 5 lug with the 2.4 and 5 speed, if I remember correctly it had the 7.5.
  15. Apr 19, 2018 at 7:48 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    With out alot of fabrication you arnt putting coil overs in the front, lock travel isn’t designed to handle weight, just soft and ment for off roading, im sure you can put beafy coils in the coil overs for the lt kit but then that is gunna stiffen your ride
  16. Apr 19, 2018 at 7:53 PM
    95 taco
    95 taco Battle Born
    There was a company that made coilovers for the 1st gen 5 lugs, it's possible, but they will be custom.
    As for the LT, if you get the spring rate correct and then tune the shock you will have a very nice ride, it will just have a wide track width as well as some squeaks (probably couldn't hear them over the diesel though)
  17. Apr 19, 2018 at 7:53 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    There is no physical way you are going to add an extra 400-500 pounds up front on a 5lug and think you will be fine. With a 7.5” axel it will probably break. You want the 8” axel with cromeoly shafts
  18. Apr 19, 2018 at 7:57 PM
    95 taco
    95 taco Battle Born
    Not stock, but with frame plating (strengthening) and modified front suspension he would be fine*, although I would recommend a brake upgrade.
    *Not sure about the rear axle, I think the 8" would be a great idea, but I don't know that I would say it's a necessity
  19. Apr 19, 2018 at 7:57 PM
    inwood customs
    Dave
  20. Apr 19, 2018 at 7:58 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Have you ever noticed that pretty much all 4bt swapped tacomas also are sas
    And all the ones that arnt are hella lifted with really beafy springs
