Serious question: what do I do? SOLVED!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johntoyota, Jun 19, 2018.
  1. Jun 20, 2018 at 9:32 AM
    #201
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    What color loctite did you use?
  2. Jun 20, 2018 at 9:33 AM
    #202
    johntoyota
    johntoyota [OP] "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Do what? Toast my powdercoat?
    Red.
  3. Jun 20, 2018 at 9:37 AM
    #203
    BlazingTaco
    BlazingTaco ~,!,,___(•v•)___,,!,~
    Exile
    2016 Tacoma SR5 BBP DCSB 4x2
    Mall landscaping pin stripes.
    Yes.
    If you hulked those too, that might add to the fun...
  4. Jun 20, 2018 at 9:41 AM
    #204
    BlazingTaco
    Exile
    All I can really add to this besides the obvious damage you'll have to do to get those wheels off and the expense of replacing the damaged pieces - a nice torque wrench would have been far less expensive.
  5. Jun 20, 2018 at 9:44 AM
    #205
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    No way. For real?
  6. Jun 20, 2018 at 9:46 AM
    #206
    johntoyota
    Down yonder in TN
    16 truck
    Yes way. For real.
    la0d0g likes this.
  7. Jun 20, 2018 at 9:48 AM
    #207
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  8. Jun 20, 2018 at 9:50 AM
    #208
    la0d0g
    running for the hills
    For crawling not hauling
  9. Jun 20, 2018 at 9:52 AM
    #209
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    :notsure:
    I've always ran red thread locker...when I had wheel spacers anyway.
    la0d0g[QUOTED] likes this.
  10. Jun 20, 2018 at 9:53 AM
    #210
    Wyckedan
    Dan
    Woodinville WA
    Biscuits likes this.
  11. Jun 20, 2018 at 9:54 AM
    #211
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Easyouts will do it. Get the largest size that you can but small enough to not hit the threads.
    Edit: oh never mind- didnt realize the lower end of the nut was still on it.
  12. Jun 20, 2018 at 9:58 AM
    #212
    johntoyota
    Down yonder in TN
    16 truck
    SpiderTrax was even nice enough to send me a bottle with each set of spacers so I felt pretty ok using it.
    remgu2000 likes this.
  13. Jun 20, 2018 at 10:03 AM
    #213
    la0d0g
    I'm probably going to now too.
  14. Jun 20, 2018 at 10:04 AM
    #214
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I was gonna say the same. Spidertrax includes red loctite with their spacers. I used it on mine when installing them, and a month later had to remove one to change a wheel bearing. Came off with minimal fuss with an impact.
    scottalot and johntoyota[OP] like this.
  15. Jun 20, 2018 at 10:12 AM
    #215
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Here you go with your fancy talk. Next you will be doing a Nitori size write up on the coefficiency of liquids and lubes . :boink:
    SR-71A and Biscuits like this.
  16. Jun 20, 2018 at 10:14 AM
    #216
    Hellapeno
    Hellapeno Well-Known Member
    Austin
    2016 TRDOR
    Choice Goodies
    Hole saw was my original idea as well, but id see if they make any with reverse pitch so you can hammer it into the lug and then slowwlyyy reverse it. If not, best of luck with the normal ones. Also, not sure what kind of clearance you have in there, but you can always cut two arches from a socket to essentially make a two-toothed socket. then drill two holes into the broken lug at 0 degrees and 180 degrees, where the two teeth on the socket would fit and then sloowwwllyyy try and torque them off. Extraction of these suckers will have to be methodical IMO. Where you located?
    la0d0g, johntoyota[OP] and scottalot like this.
  17. Jun 20, 2018 at 10:18 AM
    #217
    johntoyota
    Down yonder in TN
    16 truck
    They were actually very quiet. I thought they had just loosened. Until I finished backing them off and saw only half of the nut in my socket. :annoyed:
    Biscuits and scottalot[QUOTED] like this.
  18. Jun 20, 2018 at 10:19 AM
    #218
    Hellapeno
    Austin
    2016 TRDOR
    Choice Goodies
    i mean, fire is the least of your concerns right now... :sawzall:
  19. Jun 20, 2018 at 10:30 AM
    #219
    Hellapeno
    Austin
    2016 TRDOR
    Choice Goodies
    Two more ideas. First slightly better than the second.
    1) With a punch or phillips head, try and hammer a small divet into the aluminum of the spline lug (starter for drill bit). Then take a small drill bit (big enough to not break) and try to progressively create a larger bore on one location of the lug, by stepping up the drill bit diameters slowly. This is hopes that the lug with essentially break at one point, forming a "C" and then removal will be much easier.
    2) Put a high lift jack and a spare in your truck bed. Go wheeling somewhat hard. Profit.
  20. Jun 20, 2018 at 10:32 AM
    #220
    johntoyota
    Down yonder in TN
    16 truck
    Step 1 is my exact approach. I just have to go pick up some better bits today.
    Step 2 is my second option. Only in my driveway so I am closer to home when it fails.
    scottalot likes this.
