Serious question: what do I do? SOLVED!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johntoyota, Jun 19, 2018.
  1. Jun 20, 2018 at 2:06 PM
    #241
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
  2. Jun 20, 2018 at 2:12 PM
    #242
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    WarrenG likes this.
  3. Jun 20, 2018 at 2:12 PM
    #243
    johntoyota
    johntoyota [OP] "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    3 allen bolts.
    TexasTacoLT[QUOTED] likes this.
  4. Jun 20, 2018 at 2:19 PM
    #244
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    Same here. This is not a lesson I wanted to learn the hard way. A good torque wrench is a must for anyone who regularly removes their lugs, or any other critical component fasteners for that matter (wheels, suspension, engine, drive train, etc).
    I've only had a shop mess with my lugs once, and of course, I got home and they were ridiculously tight. One of these lugs torqued to 83 ft/lbs is super easy to take off with a 4-way. I'm 6'2" 220lbs, and it took quite a bit of effort to get those things off that day. I also would highly recommend retorquing after someone else messes with your ride.
  5. Jun 20, 2018 at 2:19 PM
    #245
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  6. Jun 20, 2018 at 2:45 PM
    #246
    Velequez
    Velequez Well-Known Member
    Austin
    2020 TRD Sport DCLB - Quicksand
    OP - Given the amount of :popcorn: I think you have a lot of people that are ready for you to get home from work and start drilling. Tell that Uber to drive faster! :thumbsup:
  7. Jun 20, 2018 at 2:46 PM
    #247
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    I'm surprised no one has suggested to glue the bits of lugnut back on and go trade the truck in for a new one.
  8. Jun 20, 2018 at 3:14 PM
    #248
    Therby
    Therby Well-Known Member
    Kitchener
    Jeep JL
    Thats what i did, was to much work. Bought the zr2, heard it had better lug nuts.
  9. Jun 20, 2018 at 3:23 PM
    #249
    Travis17
    Travis17 Well-Known Member
    Travis
    2017 Tacoma Limited
    Why would you not recommend Gorilla lugs?
  10. Jun 20, 2018 at 3:28 PM
    #250
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    :rofl:
  11. Jun 20, 2018 at 3:29 PM
    #251
    OnHartung'sRoad
    Well, I meant for theft prevention, as there’s lots of how to remove them without key videos out there. As for strong lug nuts, then ok.
  12. Jun 20, 2018 at 3:37 PM
    #252
    JRMiller
    JRMiller Well-Known Member
    James
    2017 Tacoma TRD Off Road
    A buddy of mine had a flat on the side of the road with a locking lug nut that had a broken keyway, I used a 3 inch concrete chisel and was lucky enough to catch an edge of the lug with the chisel and mini sledge and broke it free, saved him a tow.
  13. Jun 20, 2018 at 4:54 PM
    #253
    pyankura
    pyankura Well-Known Member
    17 TRD SPORT QUICKSAND
    Didn't read every word, or even half. Any chance for using a small chisel and splitting the rest of the nut? Or like above working them off with it?
  14. Jun 20, 2018 at 5:03 PM
    #254
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    No room to do it
  15. Jun 20, 2018 at 5:08 PM
    #255
    pyankura
    Maybe a hardened punch to split them? I had some small chisels at my old, machinest, that were maybe 1/4" and could take licken!
  16. Jun 20, 2018 at 5:15 PM
    #256
    Otto Mation
    Otto Mation Old on the Outside, Young on the Inside
    West Texas
    2018 TRD Sport 2019 Limited
    He is drilling them out, a little at a time as he should. When he steps up to the drill bit just a bit larger than the stud the remnants of the old lug nut will fall off with no damage to the wheel or the hub. Once that is done and the wheel is removed the spacer can be unbolted with no damage to anything except the stud on the spacer that was drilled.
  17. Jun 20, 2018 at 5:29 PM
    #257
    JRMiller
    James
    That’s what good friends call each other, my friend and I do the same, good luck with the wheel, give it hell!
  18. Jun 20, 2018 at 5:32 PM
    #258
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    Just be sure get quality hardware an use a torque wrench. Afterwards.
  19. Jun 20, 2018 at 5:45 PM
    #259
    scocar
    scocar hypotenoper
    Did anyone say EZ out yet?
    Oh fuck, NM. I was having a perception problem on the wheel pics.
    Need a deep, thin-wall bolt extractor.
    FUK. That's fucked.
    DoorDing likes this.
  20. Jun 20, 2018 at 5:52 PM
    #260
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    There's nothing to ezout
