Serious question: what do I do? SOLVED!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johntoyota, Jun 19, 2018.
  1. Jun 20, 2018 at 6:38 PM
    #281
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    You know, looking at the pictures above I think that hole saw idea would work great if you could get one a hair larger or smaller than the stud. There's more stud sticking out than I thought from the previous pictures.
  2. Jun 20, 2018 at 6:41 PM
    #282
    Velequez
    Velequez Well-Known Member
    Austin
    2020 TRD Sport DCLB - Quicksand
    Glad to see I'm not the only one with a ridiculous number/amount of weights on one side of the tire to balance it out. o_O
    SR-71A likes this.
  3. Jun 20, 2018 at 6:43 PM
    #283
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Yeah, he just needs about 1/4" of stud to work with. Hold the drill with both hands while kneeling, and rest his head against the fender so he has complete control of the drill. Start out really slow with some oil, and let the saw scratch a groove into the nut shoulder. Increase speed slightly to make progress, checking it often. Stop just before breaking through and just pick the remaining thin material away with a pick.
  4. Jun 20, 2018 at 7:23 PM
    #284
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I read the first few pages so dismiss if this has been talked about.
    1. Heat is your friend and aluminum will expand faster then steel.
    2. If drilling, don't get a spring punch, for precision work they suck, get a standard punch and prick.
    3. Get a center drill/drill countersink, like this
    https://www.google.com/search?q=cen...hUBmVkKHZXgBE4Q_AUIEigC&biw=360&bih=512&dpr=4
    4. After center drill use a 3/16 or 1/4 drill and step up from there.
    5. Use the low setting on your drill once you get your first pilot hole drilled.
    DoorDing likes this.
  5. Jun 20, 2018 at 7:36 PM
    #285
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Just wanted to drop in and say................Bitch
  6. Jun 20, 2018 at 7:42 PM
    #286
    Velequez
    Austin
    The center drill is interesting. I've used a countersink bit for woodworking but never thought about something like this that would keep you on center while drilling in metal.
    nagorb[QUOTED] likes this.
  7. Jun 20, 2018 at 7:46 PM
    #287
    nagorb
    Alabama
    2001 dbl cab 4x4
    Yep, they're used in machining all the time, but work well in hand drills also.
  8. Jun 20, 2018 at 7:50 PM
    #288
    Velequez
    Austin
    @johntoyota So, do you have a plan for being able to drive tomorrow once you get the one spacer off and still have three on the truck? Are you going to drive it all wonky (technical term there) or is it Uber FTW tomorrow, too?
  9. Jun 20, 2018 at 7:54 PM
    #289
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    The real question here is what about those other 18 lug nuts....
    johntoyota[OP] and Spare Parts like this.
  10. Jun 20, 2018 at 8:04 PM
    #290
    Velequez
    Austin
    Yeah....
  11. Jun 20, 2018 at 8:05 PM
    #291
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    That's what I was going to ask, that's a lot of hours.
  12. Jun 20, 2018 at 8:07 PM
    #292
    weefek
    weefek Well-Known Member
    J
    2017 OR ACLB
    On the next 3 wheels, use a breaker bar ffs
  13. Jun 20, 2018 at 8:09 PM
    #293
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s how he broke these ones
    Spare Parts, Skydvrr and jberry813 like this.
  14. Jun 20, 2018 at 8:09 PM
    #294
    weefek
    J
    2017 OR ACLB
    Thought he used an impact?
  15. Jun 20, 2018 at 8:10 PM
    #295
    weefek
    J
    2017 OR ACLB
    In that case blowtorch the rim and then breaker bar
  16. Jun 20, 2018 at 8:12 PM
    #296
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    OP, I admire your spirit, but man i'm glad that's not me in your shoes.
  17. Jun 20, 2018 at 8:12 PM
    #297
    nagorb
    Alabama
    2001 dbl cab 4x4
    Heat, penetrating oil, and lots of in n out.
  18. Jun 20, 2018 at 8:15 PM
    #298
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    That's what she said............
    Lawfarin, tonered, SR-71A and 4 others like this.
  19. Jun 20, 2018 at 8:15 PM
    #299
    Velequez
    Austin
    That sounds like a good night!
    tonered and nagorb[QUOTED] like this.
  20. Jun 20, 2018 at 8:15 PM
    #300
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No, he said he tried an impact to no avail. Then broke them off with a breaker. He did use an impact to tighten them.
