Serious question: what do I do? SOLVED!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johntoyota, Jun 19, 2018.
  1. Jun 21, 2018 at 10:17 AM
    #361
    johntoyota
    johntoyota [OP] "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    I’m not worried about bothering the threads since they are coming off anyway and have been trashed during this whole ordeal anyway. Just need to get the wheel off.
  2. Jun 21, 2018 at 10:19 AM
    #362
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    @teamhypoxia beat me to the punch with the hole saw suggestion, I missed his suggestion. He gets the beer.
  3. Jun 21, 2018 at 10:21 AM
    #363
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    I was thinking if you tried driving it to snap the remaining stud, you may crack the wheel. That wouldn't be good.
  4. Jun 21, 2018 at 10:22 AM
    #364
    johntoyota
    Down yonder in TN
    16 truck
    That would be a great option...... but I don’t have a dye grinder here.
  5. Jun 21, 2018 at 10:23 AM
    #365
    johntoyota
    Down yonder in TN
    16 truck
    I think the remnants of the lug nuts would keep that from happening. I’m just talking about back and forth while I walk beside it so I can see when it starts to separate a bit and then I can jack it back up and work it off. They are just hanging on by a “thread”.
  6. Jun 21, 2018 at 10:23 AM
    #366
    la0d0g
    running for the hills
    For crawling not hauling
    Good job.
  7. Jun 21, 2018 at 10:23 AM
    #367
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Here borrow mine. Wait, dang it you are too damn far away.
  8. Jun 21, 2018 at 10:24 AM
    #368
    johntoyota
    Down yonder in TN
    16 truck
    Yeah. Mine is in TN.
  9. Jun 21, 2018 at 10:27 AM
    #369
    Pot_Lickr
    Pot_Lickr Well-Known Member
    Ontario, Canada
    2017 Access Cab TRD Off Road
    Hard to believe when this thread is about how you cross threaded... Sorry, I mean over tightened your lugs...lol
    Just sayin..
    Good luck!
  10. Jun 21, 2018 at 10:28 AM
    #370
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Dude, mistakes happen. That is how we learn.
    More importantly, is how we undo mistakes.
    That is what this thread is about.
    He's getting there. Soooooo close!
    johntoyota[OP] likes this.
  11. Jun 21, 2018 at 10:33 AM
    #371
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Good thought. However, he would need a center punch harder than the drill bit, but then the center punch would probably shatter as well. :frusty:
  12. Jun 21, 2018 at 10:35 AM
    #372
    StrangeDuck
    StrangeDuck Well-Known Member
    San Diego
    07 Prerunner AC TRD Offroad; 4.0 6-speed
    265/75 Bridgestone Dueler ATs, 5100s all around, OME 883s front, EL095R Dakars rear (overload removed), custom sliders, Clazzio seat covers, Softopper, KB Voodoo URTC
    Note to self: lug nuts are not torque-to-yield :D
    Good luck OP...hopefully the other wheels aren't as much of a PITA but they probably will be. If you can... you should heat the other lugs before trying to wrestle them off with your breaker bar.
    When you finally get your wheels off make sure to replace ALL of the lugs studs on actual truck as I'm sure they've been stretched if you used the same impact gun to fasten the spacers to the truck!
  13. Jun 21, 2018 at 10:36 AM
    #373
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    I've busted many taps in stainless, just bust em up with a pinch and keep going. Never had a punch shatter
  14. Jun 21, 2018 at 10:38 AM
    #374
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Worth a try. I wouldn't think the punch would be hard enough to do anything to a drill bit.
  15. Jun 21, 2018 at 10:41 AM
    #375
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Wow, just saying.
  16. Jun 21, 2018 at 10:43 AM
    #376
    Wyckedan
    Dan
    Woodinville WA
    I've only done it to taps which are super hard and super brittle. I'd give it a shot not expecting a whole lot. Depends what size bit too
  17. Jun 21, 2018 at 10:45 AM
    #377
    johntoyota
    Down yonder in TN
    16 truck
    Spacers were put on with a 4 way.
  18. Jun 21, 2018 at 10:52 AM
    #378
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Do you have an air compressor on hand?
    Any Harbor Freights in your location?
  19. Jun 21, 2018 at 10:54 AM
    #379
    johntoyota
    Down yonder in TN
    16 truck
    Air compressor, no. Unless you count a 12 volt for airing up after rides.
    Harbor Freight, yes.
    sdsurfer likes this.
  20. Jun 21, 2018 at 10:57 AM
    #380
    johntoyota
    Down yonder in TN
    16 truck
    I went ahead and ordered a new wheel just in case. If I dont fuck this one totally, at least Ill have a matching spare.
    rsimi72 and EatSleepTacos like this.
